Question about Whirlpool LER5636P Electric Dryer
Can't make the dryer heat
My first was making a lot of noise. Someone gave me their old one, after changing the pig tail it won't heat. I was given the third one, it won't heat either. What am I doing wrong?
  • Lee2fixit May 11, 2010
    Was your old dryer electric? You said you changed the pigtail... why? Do you have 240 volts at the outlet?
  • Whirlpool Master
  • 8,220 Answers
can't make the dryer heat - 64c4e1e.jpgYour 2 outer wires which are hot go to the outside and the middle wire is neutral The green wire is a ground wire to frame.
Posted on Mar 07, 2009
2002 FORD FOCUS NEW YAW RATE SENSOR WIREING DIOGRAM FOR 6 WIRE PIG TAIL
They gave you the wrong one. If it didn't come with a new plug to wire to the car. The one you got won't work. Even if you hard wire it.
Dec 30, 2015 | Ford Cars & Trucks
Tip
We recently installed a new dryer and everything worked but it did not heat. We...
This advice is for all ELECTRIC Dryers that have a "No Heat" problem.
Symptom: Dryer turns on, drum spins, but you have no heat.
Any of the following components are more than likely suspect as being bad:
Heating Element
Thermal Cut-Out
Hi-Limit Thermostat
All these components COMBINED, should cost less than $100. If you fix it yourself, you will avoid the additional cost for labor.
If the dryer isn't blowing ANY air at all, but the drum still turns, you may have a bad blower fan assembly inside the dryer. Or, the blower fan assembly may be clogged.
If your dryer performance has been failing (i.e., clothes taking longer to dry), it may be for a reason. You need to ask yourself when the last time you cleaned the dryer ventilation. If you can't remember, or if it has never been done, this can contribute to the dryer failing. All dryers need proper air flow in order to dry properly. If the ducting becomes clogged, the heating circuits will actually overheat and eventually fail. This usually results in the Thermal Cut-Out (TCO) blowing or the Heating Element failing or BOTH. When these components fail, they must be replaced. Remove the dryer hose from the back of the dryer and inspect it thoroughly from where it leaves the dryer to where it exits your home. It should be clear with no kinks or clogs. If your vent line runs under a crawl space make sure it is suspended above the ground and has no sags where lint could collect. RULE OF THUMB: The SHORTER and STRAIGHTER the vent duct, the BETTER. After you inspect the vent ducting, turn the dryer on and make sure you have forceful air flow coming form the dryer. This will prove that your blower fan is working properly or not. Since you stated that your dryer is not currently heating, the air will be cold, but you should still have some force behind it. If the air flow is weak, you need to clean the duct work INSIDE the dryer. It is important to keep a dryer checked routinely. I recommend once per season (that's 4 times per year). Dryers are the cause of many house fires. These fires are due to lint accumulations inside the unit catching on fire. A little preventive maintenance can prevent significant problems in the future.
Getting to the heating circuit to determine if the components are good or bad is the next step. If your dryer has the lint screen on the top of the unit, you will need to remove the back panel of the dryer to expose the heating circuits. If the dryer has the lint screen in the door, you will need to remove the lower kick panel under the door by using a putty knife to release the retaining clips. They will be located along the seam in the front about 2 inches in from each side. If this is a Kenmore Elite or Whirlpool Duet, the lower lick panel comes off by removing the screws under the bottom edge of the panel. (HINT: placing a block of wood under the front feet of the dryer can make access much easier). If your dryer has no lower kick panel, you have to remove the entire front panel on these models. This is accomplished by lifting the dryer top and removing the screws that hold the front panel in place.
NOTE: The heating circuit should be troubleshot with the dryer UNPLUGGED. Dangerous voltages are still present with the dryer turned off. Resistance readings are as follows:
Heating Element (located inside heater box) – remove the two leads from the ceramic terminals on the heating element and take a reading across the terminal points. It should read 9 - 13 ohms.
Thermal Cut-Out (TCO) (mounted to the heater box.) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
Hi-Limit Thermostat (mounted to the heater box, closest to the heating element leads) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
If any of the above readings are abnormal, replace the component. NOTE: If the TCO or Hi-Limit Thermostat is defective it is highly recommended by most manufacturers to replace BOTH components at the same time. They are often sold as a set. Without doing so, these components can cause potentially fail again.
I hope this information is helpful to you. If you need further assistance, please go to my profile at: http://www.fixya.com/users/jsrock516 and use the "Ask Me" feature for a quicker repsonse to your questions/comments.
on May 02, 2009 | Kenmore 62602 Electric Dryer
Trailer Lights, I have a polarity problem. The LED tail lights on my trailer only work if I reverse the plug-in, any idea on how to fix this polarity problem.
Possibly the person that borrowed your trailer changed some of the wires. Old-type bulbs don't care about polarity, but LEDs do.
Oct 18, 2015 | Cars & Trucks
Dryer wont heat up
Is the circuit breaker a duel bullet type fuse (2) in the case for the 220 line? Try changing them and see what happens.
Apr 07, 2013 | Dryers
Hey,I have an 03 chevy s10,I recently tried putting a pig tail on it (straight wired) and had no luck,gave up and crimped all the wire back together,and today a guy at work noticed I had no taillights,but...
I would check your tail light fuse first then test the brown wire in the tail light harness where you origionally cut into it. With the lights on there should be around 12v on it. if not you may have pulled the wire too hard and broke it upstream. Test to see if there is 12v at the fuse ad if there is, your trouble should be in the wire between the fuse and the spot where you cut into it.
Mar 25, 2013 | Cars & Trucks
TED8740PQ0 ESTATE DRYER WON'T START.
First, take a look at this video to be sure the plug is correctly installed. Be sure to unplug the unit before making any changes! Post back your results.
Nov 17, 2012 | Dryers
Electric dryer heats up and trips breaker
you need to turn the power off to the dryer outlet then to make sure it is off try turn on dryer if it doesn't turn on you may now unplug dryer and remove screw in the center of the outlet then check to make sure all wires are tight if they are then you need to check the wires on the dryers plug "the pig tail" make sure they are tight.If all are tight then you have a problem internally and should contact a repair professional.
May 06, 2012 | Whirlpool Dryers
Changing pig tail from three prong to 4 prong on maytag dryer where do i put the red black white and green wires on the pig tail connection on the dryer
the red black and white wire go in the same place as the other wires and the green wire gets screwed to the green ground screw.
the white wire goes in the middle red to the left and black to the right.or just look att he wires and match them
Mar 09, 2010 | Dryers
Making a lot of noise, heats up but the clothes stay wet
DRYER HEATS UP AN CLOTHE FEELS HUMID,,,,,,YOU GOT BAD COILS......HEAT IS NOT CONSTANT..POWER TO THE COILS DROP AN THEN COMES BACK UR MAGNETIC COILS ARE BAD
YOU NEED NEW DRYER COILS
May 28, 2009 | Maytag Dryers
Electric dryer internal short
Make sure that the dryer is disconnected from the wall outlet before doing any repairs on it. Electric dryer work on 240 volts AC and this could hurt or even kill you. loose connection on the terminal block will cause the wires to get hot. and melt the terminal block and wires and the pig tail wires. you will have to replace the terminal block and pig tail wires and make sure you use the correct bolts and make sure you tighen them. let me know if this helps.krazytech
Sep 09, 2007 | Magic Chef CYE4000AWW Electric Dryer
Whirlpool LER5636P Electric Dryer Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
