Question about Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony Bravia 46S2010 no picture only glows but, only sound on
Hello, I need help! someone that's an expert regarding my Sony Bravia 46" LCD 46S2010 (manufactured 11/2006). I have this strange problem with the LCD panel. The TV powers on, no trouble red lights, the sound is on and clear, but I don't get a picture. I can switch channels by hearing it, but there's no menu on the screen. I only get a low glow from the LCD backlight which I can see it slightly flicker as I switch the menu button.
I have a broken screen Sony Bravia 40" LCD 40S2010, and this TV works fine, except it has a cracked LCD. I can still see snow flakes, and distorted image coming on the screen. I open the 40S2010 and all the components internally matched, except the LCD controller board, and LCD inverters, because the screen sizes on both units. The 46" has TWO inverter boards on each side, and the 40" has only ONE on the right side.
So, I swapped the power board, all the audio/video components, but I still only get the low glow, nothing on the LCD, but there's sound. It's the same problem. Can anyone tell me what am doing wrong, or am I missing something? Or how do I know if the LCD panel is bad? If the power inverters on the 46" is bad? Please help, thank you in advance!
  • Tyler Mar 07, 2009
    Thanks for your help bucdon!
    I was thinking about replacing the inverters boards, but from what I experienced. If the inverter boards are bad, the TV fails to power on, goes to stand by, and the red lights starts blicking. What do you mean by Tcon? and attack to the panel? thanks!
Sound like you had problem with the lcd display panel. The Tcon had problem that attack to the panel.
Posted on Mar 07, 2009
NO PICTURE ON SCREEN. HAVE A LINE AT TOP OF SCREEN WITH A NO SIGNAL ON LEFT SIDE AND NUMBER 3 ON THE FAR RIGHT SIDE.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
May 30, 2015 | Sony BRAVIA KDL-46S2010 46" LCD TV
ON THE VERY TOP OF SCREEN, I HAVE LINE WITH "NO SIGNAL" ON LEFT SIDE AND A NUMBER 3 ON THE RIGHT SIDE. ANY SUGGESTIONS
You might just need to press the source button on TV remote so a box pops up on the screen giving you options like tv,hdmi1,hdmi2 or av1,av2. Hopefully its a little helpful.
I have a 46" Sony Bravia. Approx 5 years old. Screen was replaced a couple years ago under Target extended warranty. Now the center of the screen is black. Audio is fine and you can see the picture about 6...
I have a "Home-fix" for you, you should watch this you tube video on how to repair a symptom such as yours even though it is a sanyo tv the fix is pretty much the same for your television and may save you oodles of money!
http://www.youtube.com/watch?v=purk_SyiT44
Good Luck!
Rich Lilja
Nov 17, 2013 | Sony BRAVIA KDL-46S2010 46" LCD TV
Problem with Sony Bravia 46" TV (Model
blow out fan in mother board tower mother is over heating and not geting enough of air leting the mane chips over heating makes computer stop so it doesnt catch fire.
Feb 22, 2011 | Sony KDL-46S2010 46 in. LCD Television
Needs some help figuring out what causes colored vertical lines on an lcd panel on model kdl-46z4100 sony bravia I have a picture of it but can't post it on here. I have a link of someone who actually has...
Plasma has a problem that if you do not use it for even a short period, the liquid inside the layers of the screen will get hard because of cold , it needs to be running or in room temperature. so kindly get it repaired by a TV expert if that's the problem , then you have to buy a new plasma..
thanks for rating Good luck
Jan 12, 2011 | Sony Bravia KDL-46Z4100 46 in. LCD HDTV
L have a sony bravia KDL46v4100 the problem is the picture goes completely black for 3 to 4 seconds then comes back on and it does this every 20 to 25 minutes
You should repair this TV quickly.Some of components are go to bad.If you are very late it goes danger,So you need repair by a expert this TV.
Nov 20, 2010 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Sony bravia 46 lcd The picture dims and
set has a light sensor. go in menu and turn light sensor off
Jul 01, 2009 | Sony Televison & Video
Sony Bravia KDL-46S2010
Try plugging the coax directly into the T.V. or from you VCR or DVD player then to the TV. The bravia sets also have various picture mode settings as you will discover when you go through your manual. Cable boxes or splitters can cause problems also is they are not of good quality. I love my 40.
Jul 13, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony BRAVIA KDL-40S2000 40 in. LCD HDTV Logo
725 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
