Question about Refrigerators
Wine Frig - Way too cold
I have a Kitchen Aid Wine Cellar (KUWS246ESS2) and the temp is way too cold, even when I have it on the lowest setting. Is there an adjustment, or do I need a new thermostat?
  • Refrigerators Master
  • 8,220 Answers
$95
Posted on Mar 07, 2009
I have a wine enthusiast Model 2720206 and I don't know how to set the temp?
The answer is partly incorrect. This type unit DOES NOT USE freon as it is thermoelectric utilizing a heat pump. Unfortunately, part of the answer is correct. It likely will cost about $100 to "ring the door bell".
Sep 19, 2013 | Wine Enthusiast Grand Cru 1600 Wine Cellar...
Black and Decker Wine Cellar getting warmer when bottles are put in.
Take it back and get an exchange. If you have all that done truly, then you have probably a situation of a manafacture defect(which could be one of MANY diffrent things) and there is no use in trying to fix what shouldn't be broken.
Jun 25, 2012 | Refrigerators
Kitchenaid KUWS246ESS2 need Manual PDF - have not manual to use in my new home.
Many KitchenAid appliance manuals are available here: http://www.kitchenaid.com/flash.cmd?/#/page/customer-service . Click on Locate Manuals and Guides. Then fill in the model number and click Go. The direct link to the KUWS246ESS02 Wine Cellar manual is http://www.kitchenaid.ca/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%204344600.pdf . (There is no KUWS246ESS2 listed by Kitchenaid.)
I hope this helps.
Oct 23, 2011 | Food Mixers
My thermostat is reading 48 and I can't get it cool enough in my wine cellar to turn off the unit so that I can adjust the temperature up to 55. Is there a place that I can put some ice on to lower the...
IF THE CELLAR TEMPERATURE IS AS YOU SAY 48 DEGREES AND IF YOU ARE TURNING THE SCREW ADJUSTMENT ALL THE WAY TO THE WARMER SETTING COUNTER CLOCK WISE AND THE UNIT DOESNT SHUT OFF YOU HAVE A BAD THERMOSTAT AND NEED TO REPLACE IT
Aug 04, 2011 | Breezaire WK2200 (265 cu. ft.) Wine Cooler
Viking Wine Cellar Temperature Near-Freezing
Viking wine coolers are made by Marvel.They all had issues with freezing the contents. If you replace the electronic cold control system it will be fine.If you don't, it will freeze the wine popping the corks and leaking in the unit.If you get the parts from Marvell they are much cheaper.
Jun 01, 2010 | Viking VUWC141 Wine Cooler
My kool space wine cellar is not holding temperature
has the cellar ever worked right in your home? These small refrigeration units basically move heat from a conditioned space to another space that is not objectionable such as your home where your central air system then moves the btu's. This being said, the cellar has a ventilation system that must pull in room air and push out the box air. these vents must be clean and clear of obstrucions to ensure proper performance by the equipment
Nov 26, 2009 | Vintage Keeper Koolspace Wine Cellar
Temperature too cold even when on lowest
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Jul 12, 2009 | Refrigerators
Oster 12 bottle wine frig, how to set temp instructions please
I suggest you return that puppy as fast as you can.
The company that makes them took bankruptcy and warranties are no good.
To top it off the fans usually **** out in 6 mos or so.
May 15, 2009 | Oster 12-Bottle Wine Cellar - Black
Refrigerators Logo
191 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
