My DIR 655 is able to conect to my laptop through wireless
My DIR 655 is able to conect(deceted) to my laptop through wireless but cant open the web page, But i am able open internet pages through wired conection I am Using Windows Vista
Yes I see wireless signal of my router from your Laptop,The signal is Excellent. The only problem is can't open Internet Explorer( connect to Internet) But able to connect with the LAN ports of the same DIR-655 Yes I see wireless signal of my router from your Laptop,The signal is Excellent. The only problem is can't open Internet Explorer( connect to Internet) But able to connect with the LAN ports of the same DIR-655
AnonymousMar 20, 2009
same thing, Sony Vista laptop cannot connect to a DIR-655 unsecured network (strangely same laptop can connect to a trendnet wireless router, with same settings), all other laptops can. Signal strength, etc., everything is fine. but connot connect.same thing, Sony Vista laptop cannot connect to a DIR-655 unsecured network (strangely same laptop can connect to a trendnet wireless router, with same settings), all other laptops can. Signal strength, etc., everything is fine. but connot connect.
You can't post conmments that contain an email address.
Got any other "wireless" device that you can try, such an iPod Touch, to try to pickup a signal from your router?
Does your laptop have a switch or slider or FN-key-plus-some-Function-Key-1-thru-12 to disable/enable the laptop's wireless adapter?
If you take your laptop to another location with "free WiFi", such as MacDonalds or Starbucks, can you pickup their wireless network? If not, then the problem is _NOT_ your D-Link router.
If you use your desktop to connect to the web-server "inside" the router, does the wireless transmitter on the D-Link show as "disabled" or "enabled" ?
Usually this is caused because the security settings on the laptop or PC do not match what is setup on the wireless router. Login to the wireless router and look at what is setup for security, WPA, WPA_PSK, etc, also the passphrase, it is case sensitive. The setup on your laptop must match.
1. Router's LAN1 connect to Apple through Ethernet cable.
2. Open your Dell Laptop's wireless network connection and search the network and then you can connect your Dell laptop to your router through wireless connectin.
You will need to check the wireless settings of the router is there any computer connected to the router ? If yes then you can open the router set up page on that computer. Router set up page is the page where you can check all the wireless settings of the router.
does it loose the conection constant over wireless, if so make sure u dont have two software wireless management programmes running try remove one of them and let windwows manage the conections for wireless
unfortunatly it is my understandingthat blackberrys require an ssid to connect as they are not as advanced as a laptop or wireless adapter on a pc...sorry
