Question about Mitsubishi WD-62827 62" Television
Mitsubishi TV WD-62527 will not turn on
The Power/Timer Indicator blinks rapidly for a short time the stops then after about thirty seconds starts blinking rapidly again. I can hear the click like the TV is trying to come on but there isn't any picture just the green rapidly blinking light. I'v tried to reset using the reset button, I've unplugged the TV from the outlet, even disconnected the cable box in case the TV was recieving an abnormal digital signal. Nothing has worked. Any ideas what's wrong and how to fix-it? Thanks
  • 6,784 Answers
Hi there, this is most commonly known as power board failure in the industry. the capacitors are blown. if you are experienced in inspecting circuit boards this will be helpful. you will have to disassemble and pull the power board and preform a break point test. the bown capacitors are easily picked out. they will be swollen and discolored. If you are not comfortable with disassembling this set, i suggest a service call. just tell the tech you are experiencing a power board failure.
Posted on Mar 07, 2009
My tv a mitsubishi d 62527 the green light kees blinking
Called the blinking green light of death---set should if power lost when put back blink for 70 seconds or so---digital unit booting up.
About the only simple cause is in the main power supply are four 1000 uf caps that puff up and fail--provide boot up voltage.
follower power cord to supply and look for bad caps (they will be easy to spot) and see attached photos of what to look for.
Nov 06, 2012 | Mitsubishi WD-62527 Compatible TV Lamp
Mitsubishi wd 62527 blinking status light what can I look at? No Picture, Flahing TImer light goes off agter 2 min then tv turns off and if you power it on it flases Lamp and Status multiple times?
This is a common issue with bad capacitors in the TV. You can call in a shop or repair it yourself. You can google the parts using this number Z1234TV
Mar 31, 2012 | Mitsubishi Televison & Video
Hi, i have here a mitsubishi WD-57733. once the unit is switch ON, green LED light and a few seconds the status LED light then shuts off. I think light engines good since i just replaced a new lamp.
hello i've just checked the manual for here is some information
None TV is powered off. Normal operation.
Green TV is powered on. Normal operation.
Green 1. TV just plugged into AC outlet.
Wait until blinking stops before turning on (approximately 1
minute). Normal operation.
2. AC just restored after power failure.
3. TV Rebooting after System Reset was
used.
4. TV Rebooting after power fluctuation
or receiving abnormal digital signals
from digital channel, or digital device.
5. You have begun the procedure to
update software from an authorized
flash memory device.
For detailed information, see the instructions that accompany
the authorized software update. IMPORTANT: Do not
use unauthorized software at any time.
Green TV just powered off and lamp is
cooling.
Starts to blink 30 seconds after turning off TV. TV can be turned
on before blinking starts or after blinking stops, but not while the
indicator is blinking. Normal operation. hope it helps regards shaun
Green TV powered off and auto-on timer is set. Normal operation. TV can be turned on at any time.
Dec 06, 2010 | Mitsubishi Televison & Video
Flashing green light
Did you try this yet
SYSTEM RESET
If the TV will not respond to either the remote control
or the front panel controls and/or will not power Off,
press the SYSTEM RESET button with a pointed item
like the end point of a paperclip. The TV will turn Off
and the TIMER light will flash quickly for about one
minute. When the TIMER light stops flashing, you may
turn on the TV again. Changes you made the last time
the TV was On before you used the SYSTEM RESET
button may be lost, however, the changes you made
previously are not lost.
POWER/TIMER Indicator
The green light is a multi-function indicator. This light
will flash rapidly for about one minute each time the TV
is plugged into the wall electrical outlet, when power
is restored after a power failure, or using the SYSTEM
RESET button. Do not attempt to turn on the TV again
during this period. Wait for the flashing to stop and
the light to turn off, before attempting to turn the TV
on. While the TV is powered on, the light illuminates
steadily. If the TV has been programmed to turn on
automatically using the Timer feature,
Sep 21, 2009 | Mitsubishi WS-65515 65" TV
Error 37
HELLO. the fist this is turn on the set and just let it do it's own thing.!!! for around 7mins to 15 min's and see what happen's and then tell me ok. let me know ok
Aug 18, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Television
Press menu and the device buttons on the tv both in together and hold them in for 5 seconds and see if the led will blink a two digit error code, then let me know the blinks.
Jul 06, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Blinking green timer light
i have seen a couples mitsubishi and i all ready talked with a tech suport from mitsubishi but they said change the capacitors in the shop were i work we do the same but the tv still doing the same then we send the dm module to them and they fixed we asked whats the real problem and they said the capacitos the best i think is send the module to them
May 07, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Green Blinking Timer Light Mitsubishi WD-62527
hold the menu bottun for 10 seconds
after press power
see if that works
Sep 22, 2007 | Mitsubishi WD62527 62 in. LCD HDTV
Tv 62527 light goes off when after a few seconds when turned on
This is generally a Power Supply problem, usually the SMPS so it's replacement or repair.
Jul 15, 2007 | Mitsubishi WD-62327 62" Rear Projection...
Mitsubishi WD-62827 62" Television Logo
367 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
