1985 steiger panther powershift.computer won't start up,and will display codes on dash-help
  • dxid Mar 07, 2009
    1985 steiger panther powershift computer will NOT display ANY codes on dash ??, fuses are good
  • dxid Mar 07, 2009
    head's fine problem not w/ motor and clys are good.. we're talking strictly a computer problem here, on a steiger farm tractor.. computer does'nt start thus not displaying any codes..
  • 19,396 Answers
Check the connector to the computer module, you should test that there is power getting to the computer. Check if this is a dirty battery post as suggested, but if computer does not give sign of life it should not.
If the connector is good and computer is dead, then replace the computer module on your tractor.
Regards.
Posted on Mar 09, 2009
    Sergeant:
  • 320 Answers
You have a dirty battery post .
Well first push down on the inch pedal (clutch)then put the tractor in gear (actually in this case its called a range not a gear) then move the power shift one shift at a time then move the throttle. To stop pull back on throttle , pull back on power shift then depress inch pedal. To pull heavy loads at higher speeds (wagons on the road) start in 3rd range, increase throttle, move powershift to 2, then depress inch pedal , move range to 4th then release inch pedal, increase throttle , then move powershift to 2nd then 3rd.
DO NOT PULL BACK ON POWERSHIFT WHEN CLIMBING STEEP INCLINES WITH HEAVY LOADS AT FULL THROTTLE!!! YOU WILL ONLY DO THIS ONCE!!
Always pull back on throttle to slow down then on powershift. When coming to a stop sign on the road and u have to stop ....pull back on throttle to an idle then depress inch pedal fully (powershift will return to 1st) then use your brakes.
Posted on Mar 07, 2009
    Sergeant:
    Novelist:
  • 277 Answers
The head is aluminum and is possibly warped. you need to do a compression and cly leak down test
  • 154 Answers
What codes displayed?
  • crysiszone Mar 07, 2009
    If the computer is plugged into a surge protector, see if the surge protector has a reset switch that you can push. (If it doesn't have a reset switch and the problem is with the surge protector.
    If you can hear the computer's fan or hard-disk drive, or if you can see indicator lights on the main unit but the monitor stays dark, make sure that the monitor is connected to a working power source.
Where can I a purchase, or have a controller repaired for a Panther MX-4?
Hi , sounds like a Rhino ,is it possible for a picture of the controller in question ?
are you uk based ?
Regards
Rob
www.gewizrepairs.co.uk
Aug 01, 2014 | Invacare Panther Mx-4 Havy Duty Delux...
What are a panthers behavioral adaptations?
The answer is:
Black panthers are nocturnal predators. Nocturnal animals tend to have proportionally bigger eyes than diurnal animals and human beings do. They also tend to have pupils that open more widely in low light. Their superb night vision allows them to stalk their prey in the middle of the night.
other than the superior intelligence and tree-climbing skills displayed in its hunting activities, a black panther has some unique adaptations and features to help it achieve its hunting tasks.
Black panthers are not the biggest cats, however, they have well-built muscular bodies, powerful jaws, and long and sharp canine teeth. They are superb athletes of the animal kingdom. These make them extraordinary fighters and warriors in the wild.
The dark coat color of black panthers certainly camouflages them well at night or in dimly lit forest areas.
When they stalk their prey, black panthers retract their claws to silence their movements. When they get close enough to their prey and ready to spring, they extend their claws.
Black panthers have long and sensitive whiskers, which can help them feel their way through thick undergrowth in the dark.
Black panthers also have a keen sense of smell and exceptional hearing. They can locate prey without seeing them.
Apr 15, 2014 | Office Equipment & Supplies
Panther 110 won't stay running
It might be overheating. Make sure the fan is running. Try raising it up slightly so it can draw more air to cool. Set in on a hard surface.
Apr 03, 2012 | Computers & Internet
1985 gmc vandura 2500 will not fire when trying
Sounds like you may have problems with the ignition switch. The starter is turning over? But the motor doesn't fire, until you turn the key off?
Mar 16, 2010 | 1985 GMC C2500
Self-diagnosis System
Autozone Chilton manual or they do this for free
Oct 03, 2009 | 1985 Oldsmobile Ninety Eight
1985 190e Engine turns over, won't start
when the car ignition is turn on all accessory lights should lite up telling the computer everything is in good contact. If none of the dash lights is not lighting up you don't have a good ignition contact and computer is not getting any power. your stater will crank and turn the engine over only but the fuel pump and ignition module and other accessary is not turn on, the car will not start. What turn everything on is your computer, computer; control all items like fuel pump, sparks etc. You have to get all dash light working again in order for computer to turn on. Check all the fuses and relay under the hood, next your ignition switch in your steering wheel may be faulty allowing only starter to work and not others. this unit wear out and common problems to all cars, parts is 35 buck to replace and you going to have to take the steering columns apart to get to it. Not easy but it will take time. Get all the dash light working and you will be back in the game. good luck and hope that help some
Aug 06, 2009 | 1985 Mercedes-Benz 190
Computers & Internet Logo
47 people viewed this question
David Payne
David Payne
