Question about T-Mobile MDA
Charging Problem I have an older model Tmobile htc and it will very seldom charge. I replaced the battery, I had the battery charger checked, it was fine. This a 2006-2008 model three little lights up to one for blue tooth the other for charging, and the other for wifi. It has a camera email button, speaker button, scroll down button, touch screen, email button, and the usb port on the bottom
  • 154 Answers
There is some short in the pins.
Posted on Mar 07, 2009
  • T-Mobile Master
  • 19,396 Answers
Clean with cleaning solution the battery charger contact on phone.
  • Ginko
    Ginko Mar 07, 2009
    Use contact cleaner solution, or isopropyl alcohl to clean charger contact on the phone , removing oxide and dirt.
    If that does not help, then the problem is usually the charger, even if there is voltage on charger contacts, if some of the contacts is not getting well in contact with the phone socket, that is the cause for the problem.
Charge htc evo 4g lte with broken charging port or how to fix charging port
unless you can open the phone and have soldering skills, take it to a local repair shop to replace
Mar 07, 2014 | Cell Phones
Htc wont charge and turn on
If it won't charge then you may have a defective charger, a failed battery or a loose solder joint at the charging port. If your charger plug is fitted with a fuse then consider checking the fuse is okay by trying a new one. Also, check your charger on a friends HTC, check their charger on your HTC. It really is a process of elimination to find the issue yourself.
The HTC won't turn on because it isn't charged, until you fix charging prob it won't turn on.
May 02, 2013 | HTC Flyer 7 inch 32GB Android Tablet PC...
Dear, Sir i have htc desire mobile .it,s have
Check the voltage at the output of the charger unit, check the voltage at the pin. Now remove the battery and check the voltage, check the charge voltage at the pins of the battery terminal in the phone. If there is no voltage then there is fault in the mother board.
If the battery does not charge then the battery is a suspect , allow it to drain fully and then try charging once again before you can try for warranty claim if the phone is new.
Jul 07, 2011 | HTC Inspire 4G Smartphone
I just bought a new battery charger cable called (Sealed Lead-Acid Charger) to replace an older (Lead Acid battery charger). The New Battery charger will charge for about 2 to 5 minutes and then stop...
ismail the charger you bought should do the job. By stop charging do you mean the light on the charger turns from yellow to green? Your scooter has small batteries 12/12 and don't require along period of charging. Now the scooter has a heat sensor for the batteries and will cut off charging when temp of the batteries gets too high. The older charger could have overcharged your batteries and made them weaker instead of stronger. I would suggest you replace the batteries (2 12/12AH) and charge them with the new charger. Remember to reinstall the heat sensors on each battery when replacing. If you have a digital voltmeter set it to 200 v dc and put the leads into the 2 outer plugs in the charger port on the battery pack. You should read 24-26 volts dc when the batteries are fully charged anything less would mean weak batteries. Hope this helps you
Oct 03, 2010 | Pride Mobility Products Go-Go Elite...
Suspect the charger is shot on a seldom used like new Companion II. The batteries are at 3 volts but the charger red light wont illuminate when plugged in. Green light comes on, but not the red. I did see...
MStrong The charger will not charge batteries that are reading that low Replace the batteries and try the charger again. Remember to always charge before use and never charge longer than 12-16 hours. Get into the habit of charging overnite on scooters used everyday and once a week on seldomly used scooters always sore the scooter fully charged and if storing for a longer time remove the batteries and store fully charged. ope this helps you
Oct 03, 2010 | Golden Technologies Companion II Travel...
Why doesn't my htc phone charge while plug in?
First, you need to check to see if the problem is with the phone - the battery - or the charger.
If you have a car charger, try to charge the phone with it. If it works, you'll need to replace your home charger.
If the car charger doesn't charge the phone - you'll either need to replace the phones battery or your home charger. (Sometimes the battery will go bad if you use a car charger not made specifically for the phone.)
If you replace your battery and it still doesn't charge you'll need to replace your home charger.
If after you've replaced the battery and the home charger and it still doesn't charge - your problem is with the phone and it will either need to be replaced or repaired.
Apr 07, 2010 | HTC FUZE Smartphone
HTC Touch Viva is not charging
You have to check first the charger you can used multitester in position DC volt to make sure the voltage no problem, if in the plug no voltage maybe the cable damage, or the soldering on pcb circuit bad,you can try with another charger first to make sure where is the problem.
Jul 12, 2009 | HTC Touch Viva Cell Phone
Htc 8125
there will be some problem in the charger or in the charging port of your cell ..
just have a check with the charger first with another mobile if needed replace it ..
if you still persist the same problem then there may be some problem in the charging port of your cell ..
the charging port may be is in loose contact ie it might not be touching the motherboard of your cell correctly just have a check by opening the cell if you are good at opening if needed replace the charging port ...
rate my solution
Sep 07, 2008 | HTC Touch Cell Phone (Unlocked) - Soft...
T-Mobile MDA Logo
14 people viewed this question
Top T-Mobile Computers & Internet Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
