Question about NetGear WGR614 Wireless Router
Netgear WGR614 v7 router
So, I bought a Netgear WGR614 v7 router, and set my internet up. I got everything connected through 'Windows Connect Now' and I can connect to the internet, and play online games over the internet and through downloadable applications, but when I try to connect to Xbox LIVE, there is an error. The test goes through the IP Address, and so fourth, but stops at MTU. I have logged into my router, and changed the MTU setting to a suitable number, but it still doesn't work. I'm at a loss here. I'm really frustrated, and don't want to wait and call GeekSquad to come to my house and set-up my Xbox LIVE for me.Can someone help, please?
  • 854 Answers
Hello kidd08,
Step 1: Determining the IP Address of a Computer: Follow these steps to check the IP address of a computer for which the Ports are to be opened:
For Windows 2000/XP users:
a. Please click on Start and select Run.
b. Type in cmd and click on OK.
c. In the command prompt, please type ipconfig then press Enter or Return key.
d. Please make sure that the Ethernet adapter has an IP Address that is the same range as the router (e.g. 192.168.1.2 for the computer and 192.168.1.1 for the router).
e. Please note down the IP Address.
Step 2: Logging on to the Router Page:
a. Open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field. Click on Enter or Return key.
c. For security reasons, the router has its own username and password. When prompted, enter admin for the Username and password for the Password, both in lower case letters.
Note: If it doesn't take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you can't remember the password, you need to reset the router and run the Setup CD to reconfigure it.
d. You will then see the setup page once you have successfully logged in.
e. A menu will be seen on the left hand side of the router configuration page. Click on the option with the name Port Forwarding/Port Triggering under the Advanced. For older firmware version, click on Port Triggering tab or just click Port Forwarding on Please select the service type.
f. Click Add and another window will pop up.
g. Type Xbox for Name. Set the radio button to Enable.
h. On Outgoing Port Range, set the Start Port and End Port to 3074.
i. On Incoming Port Range, you also have to indicate 3074 for Start Port and End Port. Save the settings by clicking on Apply.
j. Please repeat steps 4 to 7 and indicate 88 for Start Port and End Port. Then change the Name to Xbox2.
Other things to check:
A. Lower down the MTU.
a. Access the Setup page of the router (refer to Step 2 above).
b. Click on the WAN Setup under Advanced tab.
c. Lower down the MTU size to 1492, 1400, 1358 or 1300.
d. Click on the Apply button.
B. Enable UPnP.
a. Go to UPnP tab of the router.
b. Enable UPnP and then save the settings by clicking on Apply. Some websites and devices require UPnP or Universal Plug and Play. Just make sure that it is enabled on the router.
C. Upgrade the firmware.
Note: Follow the steps below if the above troubleshooting still do not allow Xbox to connect using the router.
a. Please verify the router version and model either underneath or at its side panel.
b. Go to http://kbserver.NETGEAR.com/downloads_support.asp and please select the model of the router.
c. Click the appropriate version of the router.
d. Select the link of the latest firmware. Click the button Right-click and Save to Download. Save the file to the Desktop.
Note: Please perform firmware upgrade with Wired or Ethernet connection only.
e. Before upgrading, please write down all current settings since you need to enter them manually.
f. Using the computer hardwired on the router, please launch Internet Explorer and access the Setup page of the router (refer to Step 2).
g. Click on Maintenance and then Router Upgrade.
h. Click on Browse and locate the upgraded file in your Desktop. Then click on Upload.
i. Please wait for the router to reboot.
j. After a successful firmware upgrade, you need to reset the router.
k. Please push the reset button at the back of the router and release after 30 seconds.
l. Unplug the power adapter for 10 seconds and then plug it back in.
Posted on Apr 11, 2009
I'm using a Netgear WGR614 router that is working fine to connect to the internet via Comcast only when I'm hard wired. However, I'm not able to connect wirelessly. I can see the available network, I have...
I am guessing you are using a new computer with windows 7?
I find the router works great with PC's running XP or vista; only my new w7 doesn't connect either!!!
Jan 02, 2011 | NetGear WGR614 Wireless Router
I dont have the drivers for NETGEAR 54 Mbps wireless Router WGR614 v7. I want to connet my BroadBand connection to my Router I want to use my LAPTOP without wireless. kindly assist me about the...
Hello, I dont think you need the drivers for Router. And first of all you need to connect your modem to your router through ethernet cable. And after connecting your modem, configure your wireless router by typing this IP address in internet explorer: 192.168.1.1 The user id is admin and the password is password. Then detect your broadband connection by using the option in the router. Try connecting your Laptop to wifi after setting the connection.
Nov 02, 2010 | NetGear WGR614 54Mbps Wireless Router...
PS3 and Netgear WGR614 V7 Router
Basically the PS3 wireless settings needs to be configures with the Netgear wireless router settings.
To test if the modem is connects to the Internet, connect a computer into the modem, if it works then the modem is configured correctly. If it doesn't work, then contact your ISP and get them to test your modem connection.
For details on how to configure the PS3 click on the WEB link :-
wii.php">http://fixhomenetwork.com/xbox-play-station-wii.php
Dec 20, 2009 | NetGear WGR614 Wireless Router
Cant find the wep key for net gear wgr614 v7 wireless router to connect my xbox 360 wirelessley
You need to log into the router setting using a pc.On the pc go to a browser like internet explorer and type the router address which is something like 192.x.x.x which you can obtain from its manual or sometimes is printed underneath the router...Now once you logged in then go to the wireless security tab and find your key or you can make a new wep key.Hope this helps.
Dec 12, 2009 | NetGear WGR614 Wireless Router
No Setup CD
Are you trying to set up the router ?
You can do it without the CD. You can do it manually.
First make sure that your computer is able to go online when connected directly to the modem.
Then connect the modem and computer to the router and check the settings of the router.
Click Here for step by step solution
Nov 27, 2009 | NetGear WGR614 Router
Help
That means it hasnt picked up an IP from the modem.
Unplug the power to the modem and the router. Leave them off for a full minute. Pluge the modem in first , give it another full minute then power up the router. If you still have problems try another cable.
If you still have issues, Power off the modem and the PC and repeat the above process.Verify the PC is getting connection. If you cant connect then call the cable/DSL company.
If you can connect download the latest firmware from Netgear and flash the router.
http://kb.netgear.com/app/products/model/a_id/2589
Mar 04, 2009 | NetGear WIRELESS-G WGR614 802.11G WIRELESS...
Can't connect to the internet wiith new Acer Aspire One
so you are not able to connect wifi on your acer so please follow the steps to trace the problem.
1>check your wifi is installed and active
2>check you are getting single strength good or excellent
3>check whether dhcp is enabled and give the proper range ip is defined.
e.g type in start --> run -->http://default ip of netgear rotuer and login with admin & password admin.
4>right click on my network place and goto properties -->internet protocol tcp/ip and set it for obtain ip address automatically and dns also auto
This might help you in resolving it.
Dec 19, 2008 | NetGear WGR614 Wireless Router
We have the Netgear WGR614 v7 router to connect to Time Warner internet. It is hooked up on two computers, however, one of the computers recently needed to be reformatted and the OS reinstalled, so now...
check the Network adapter is installed properly. Check if the drivers had been installed properly.
Checking Device Status on the Device Manager
For Windows 2000 or XP:
1. Click on Start, go to Settings and then Control Panel.
2. Click on System, go to Hardware and then Device Manager.
3. Click the (+) sign on Network Adapters and select the adapter.
4. Double click on it and read the Device Status.
Dec 06, 2008 | NetGear WGR614 Router
How do I set up the router
Your answer is right here http://kb.netgear.com/app/products/model/a_id/2589 Manual, Documentation, everything that you need is on that page. Hope that helps.
Nov 17, 2008 | NetGear WGR614 Wireless Router
Wireless routers
Just plug the cable modem ethernet into the input to your router and you will be fine. Just remember, if you decide you want to make any changes to your router settings through your browser, make sure you hook up an ethernet line from your laptop to the router before making any changes. The reason for this is if you make a change in security settings on your router while wireless, the router will reboot and if your laptop did have the settings changed in it, you can be locked out.
Not that you can't get back in, but it is a pain to have to do.
Jan 14, 2008 | Arris SURFboard SB4200 Modem
NetGear WGR614 Wireless Router Logo
395 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
