Question about Vacuums
I have a miracle mate platinum vacuum. How do I
I have a miracle mate platinum vacuum. How do I get the vinyl seal off (its on middle of canister)?
  • Anonymous Mar 24, 2014
    schematic
You can always call the toll free number on their paper bags and ask for a service tech. They have walked me though a motor replacement after my kids sucked up water.
Posted on Jan 18, 2011
You pull really REALLY hard! Don't worry, you won't break it. I promise. I've had a miracle mate for 7 years now and we remove that thing all the time to blow up air matresses and intertubes and such. :) Hope that helps.
Posted on Jun 27, 2009
Chef mate butane stove, CM1000 by Keromate, is leaking when I try to install butane canister.
check for a missing very small
"O" ring around the area where the canister fits to the stove
could be the seal where the canister goes in is damaged
Jan 22, 2017 | Vacuums
Miracle Mate Platinum. Why does it get hot & turn off?
Carmen,
Sounds like the motor is overheating possibly because of a clog or maybe a filter that needs to be cleaned. Make sure you have a new bag and clean all the filters and hopefully that will take care of your problem. Hope this helps!
Jun 04, 2015 | Vacuums
Miracle mate vacuum will not turn on
put a brand new switch on it and that should solve your problem the switches on vacuums go out all the time causing people to through a great vacuum out and I pick them up put a new switch on them and then they work like new
Mar 20, 2014 | Vacuums
I need a operators manual for a miracle mate platinum vacuum
Hello Skip798,
Please visit the link provided below for all detail for Miracle Mate Platinum Vacuum :
http://miraclemate.com/platinum.html
Dec 26, 2011 | Vacuums
I have a Kenmore canister vacuum cleaner. The
check the reset button or the wire that goes into the powermate sometimes it frays and breaks
Dec 29, 2009 | Kenmore 25614 / 25615 Progressive Bagged...
Have a kenmore canister vacuum cleaner which the power-mate parts don't work. I had loaned the vac out it came back with part of the hose smashed. I don't know if that is the problem.
The hose conducts power to the "power Mate"
There are wires running end to end through the hose and handle. If your hose is grey with hard plastic cuffs at both ends, it is repairable, but you will need to locate the Smashed parts.
If your hose is almond or gray with ribbing like miniature spider web between the corrugations and vinyl cuffs molded onto it , it is likely a non serviceable hose and needs to be replalced, Sears or a Panasonic vac warranty repair shop should be able to supply the parts.
Lesson learned, give the bill to whoever borrowed it
Sep 09, 2009 | Vacuums
Dead Miracle Mate Vacuum cleaner
You don't have to open the cannister. You can easily remove the black plastic collar through which the cord is supposed to emerge. The collar has a little springy tab that holds it in place. Once the collar is removed, you can reach in and grab the cord and pull it out.
Steve
Aug 02, 2009 | Vacuums
Canister motor not on - power to power mate is on
if its a long plastic tube with snaps on it that is where the fuse is.open it up and you will find the fuse
Apr 28, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Kenmore canister power-mate
I was able to get the whole thing reassembled.  If there is something specific that you are having trouble with let me know.  Everything snaps into its specific spot--it is just tricky to get it all lined up.
Sep 19, 2008 | Kenmore 25512/ 25513 Progressive Canister...
Vacuums Logo
1,426 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
