Question about Bosch Washing Machines
How do I turn off the beepers on my Bosch washer
How do I turn off the beepers on my Bosch washer and dyer model #6400 and 6500
To turn the beep off (or volume down) on the Exxcel 7 (BOSCH WAE24468GB you do the following:
1. Turn setting dial to off. 2. Turn dial one step clockwise (wait for panel to light) 3. Keep finger on 'RPM' button and turn dial another step clockwise and release finger. 4. The default setting of '2' should appear on the display, this represents the Button Signal Volume 5. Pressing 'Ready in' button cycles through the volume settings from 0 (off) to 4 (very loud!). 6. Turn dial another step clockwise to set the 'Information Signal Volume', which is also set to '2' by default. This is the one that annoys everyone at the end of the cycle!
All the manuals are on the Bosch website, if you know the model code.
Posted on Jan 13, 2010
Turn the machine off, and then turn it on again. Select any programme. Hold down the Pre Wash button and keep it held for a second or two. The beep changes through four settings: loud, medium, quiet and off. Release the prewash button at the desired stage.
Posted on Nov 07, 2009
  • AbigailDavie Jun 01, 2011
    I can't turn it off it seems quieter but there didn't seem to be an 'off' stage to the beeps?
  • lindsay_t247 Apr 07, 2014
    Towner_glos, I did have the manual but that was impenetrable until I read your clear and concise instructions. Only now does the manual make sense. I had managed to turn of the button bleeps but not the infuriating end of cycle hysteria. You are a genius and I thank you.
Washing f15
Problem:
Bosch Classixx WVF 240S Front Load Washer/Dyer... Won't spin.
Solution:
Recently I had problems with both washer and dryer and I decided to fix them myself.. I did this successfully..
My washer had leaking pump..
The dryer wouldn't heat..
I did the following..
I went to Google and typed in the Make and Model number. I found some info on the Maytag units so I began a note pad on what I was finding..
I would recommend that you do the same...
I found the following:
https://www.youtube.com/watch?v=wlMoT9rgvAg
The information may prove to help you but sometimes calling the repairman may be the best solution.
I listened to a couple of videos on the Bosch and did not feel that I would rely on the information.
In your case I would go to the dealer and ask him what are the most common causes of a Bosch that won't spin.
Next I would ask if they have a manual to DIY as I would like to repair this myself.
Asking these questions from the parts department is also useful if I didn't get plausible answers.
I also found the following on Fixya:
https://www.youtube.com/watch?v=qqGWjxzY-tw
These machines have a level of complexity. I trained repairman is best. If you are very mechanically inclined you may be able to figure it out, order the parts, get a DIY manual (usually availble online through manufacurer), and have fun learning... That is what I did..I fixed them both and saved a few hundred dollars at the same time learned that I could do it (that is valuable to me)..
I hope this helps you,
cmilton111
Oct 28, 2013 | Bosch Classixx WVF 240S Front Load Washer...
The alarm goes off every time the wash is completed. How do I turn it off?
Select a wash cycle
Hold down the bleach button and the rinse plus button together til you hear a beep.
Jan 28, 2011 | Bosch Nexxt 500 WFMC3301 Front Load Washer
I HAVE MAYTAG MWU107ECWG WASHER AND DYER . I DON'T HAVE ITS OPERATION MANUALS. SO PLEASE HELP ME TO USE THIS.
I have Maytag 7 Kg washing machine model MWU107ECWG and no user manual. If someone can provide it will be a great help. My e-mail shijijosekn@yahoo.co.in
Dec 04, 2010 | Washing Machines
Beeping sound when cycle is finished just started after 8 years. how do I turn it off?
Welcome to FixYa.
I think can answer your question..."beeping sound when cycle is finished just started after 8 years. how do I turn it off?"
Follow these steps...
**How to Operate the Cycle Completion Signal**
1. Open door, hold down program button (see
Beeper Table below) and simultaneously turn the unit "ON".
MODEL Program BUTTON
SHU 9950 Delay Start Hours
**SHU 9910-9920 Delicate/Econo** should be yours
SHU 8800/8810 Quick Wash
SHV 6800 Delay Start Hours
SHV 4800 Delicate/Econo
SHV 4300 Delicate/Econo
2. Release program button.
a. For SHV 6803 and SHU9950 models:
The display will blink with a code of "0", "1" or
"2". You are in program mode.
? If the display blinks with a "0", you will hear
no signal (indicates OFF).
? If the display blinks with a "1", you will hear a
LOW volume signal.
? If the display blinks with a "2", you will hear a
HIGHER volume signal.
b. For all other models with the beeper
function:
? If the machine beeps, then the Cycle
Completion Signal has been enabled.
? When you push the button again and it does
not beep, it means that the Cycle Completion
Signal has been disabled.
3. To change the program, press the program
button until the desired setting is selected.
4. Turn the Dishwasher off to take it out of
program mode.
* At the end of a wash cycle, the beeper will sound
off two times, and again every 15 minutes until the
dishwasher is turned off.
Hope this answers your question and provides you with what you needed.
Thank you for choosing FixYa and good luck.
Please take a moment to rate the solution provided and a short testimony if you feel it's warranted, but also let me know if you require further assistance.
Regards,
Macmarkus :)
Nov 06, 2010 | Bosch SHU9915UC Dishwasher
How do you disable the cycle completion signal/beep on the Bosch SHU9915UC dishwasher?
Welcome to FixYa.
I think can answer your question..."How do you disable the cycle completion signal/beep on the Bosch SHU9915UC dishwasher?"
• If the display blinks with a "0", you will hear
• If the display blinks with a "1", you will hear a
LOW volume signal.
• If the display blinks with a "2", you will hear a
function:
• If the machine beeps, then the Cycle
• When you push the button again and it does
program mode.
Regards,
Macmarkus :)
Oct 07, 2010 | Bosch SHU9915UC Dishwasher
Can't turn off my signal
Short of disconnecting the beeper device wires inside the machine there isn't a way to do it. The Dryers have a signal button that lets you turn it off, the Washer's don't.
May 10, 2010 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Dyer will not turn on. I have cleaned the heat sensors, the lights go on, it is not over loaded..any thoughts
check the angle on the vent hose on the back of the machine and the vent flap hoodie thing outside also the vent hose should not exceed 11 feet. I had this problem and replaced the springy plastic covered vent hose with a rigid aluminum one and still have to check from time to time to make shore the hose is clear where it attaches to the machine. The lint from the extreme spin on the axxis washer is very fine and slightly damp it binds like paper mache.
Sep 29, 2009 | Bosch Axxis WTA 3510 Electric Dryer
Is there a way to turn off the cycle completion signal. I have a Bosch SHY66C02UC/14
OK, I think I have figured this out. Let me first give this important piece of information. The control panel for my dishwasher was replaced recently. That's why I now have to deal with this issue. I have a Bosch SHY66C model. As I stated in a previous post, the user manual I found on the web has identical structions for changing the amount of rinse aid dispensed and for changing the volume on the cycle completion beeper (or for disabling it). Following the instructions fixed the former.
Here is what I did
1) With dishwasher off, I pressed and held the "Delay Start Hours" button
2) I pressed the on/off button. The beeper begin to sound.
3) I released both buttons (not sure this step is necessary)
4) I repeatedly pressed the "Delay Start Hours" button until the signal turned off
(LED display showed 0)
5) I pressed the on/off button (not sure this still is necessary)
That seems to have fixed the problem. So, I don't know if the user manual is wrong or my control panel was replaced with one from a different model (such as the SHU9950 where I found these instructions).
Jul 24, 2008 | Bosch SHU9915UC Dishwasher
Dyer on combo won't start
This could either be a bad start switch or door switch
May 29, 2008 | Frigidaire GLEH1642DS Front Load Stacked...
Washing Machines Logo
2,793 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
