Question about Apple Computers & Internet
How to make computer fast at boot time? - Apple Computers & Internet
  • 479 Answers
For windows XP please try following.
1.START>RUN>MSCONFIG> select selective startup.
2.in MSCONFIG go to the startup tab and disable all.
3.richt click mycomputer icon>properties>Advanced>performance settings>advanced>virtual memory change and set it 2500 ad 3000 in custom size.
4.Move your mail data to non OS partition.
Posted on Mar 07, 2009
Tip
How to make computer to fast or fast boot ?
Do the following to make your PC Fast
Do 1
1. Turn on your computer, and hold down delete.
2. In the BIOS window, look for the Boot Menu option.
3. Choose the QUICK BOOT to turn off memory test
.4. Make sure the hard drive comes first in the BOOT ORDER.
5. Turn off any logo displays.
6. Restart
Do 2
1. Open your Start menu.
2. Click Run
3. In the command screen type msconfig
4. In the system configuration utility,click either BOOT tab.
5.In the boot menu, change the default setting for Time Out from 30 to 5 seconds.
Do 3
1. Click the Start button.
2. In the Start Search bar, type control userpasswords2
3. Load the User Accounts window
4. Uncheck User must enter user name passwords...
5. Click Apply
Do 4
1.Click Start button and load the Control Panel
2. Under the Control Panel menu, click Programs.
3. Under the Windows Defender heading choose View currently running programs
4. Choose Startup Programs from the Category option
5. Remove Programs that you feel unnecessary for startup
Do 5
How to disable this indexing service
1. Click on Start
2. Click Run
3. Type services.msc
4. Select Indexing Service and Double click on it.
Select Manual under Startup Type.
5. Click Stop
6. Click OK
on Jan 03, 2010 | Computers & Internet
Tip
How to: Faster Pc - Windows XP
To have a nice and fast boot up of your pc. go to start then run tipe in msconfig now click on the start up icon and unclick all the programs that you do not want to run next time your computer boots up. this way when booting your pc not only you will have a fast boot up your desktop will be alot faster because you have not got those unused programs clogging up your usage.
hope ive explained well and Enjoy
on Aug 28, 2008 | QuickStart PC Cleaner XP (798936829016)...
Bios speed slow fast karni hai
First of all, your computer must be completely powered down and turned off before starting this process. You won't be able to edit the BIOS in sleep mode or hybernation mode. Next, power on the PC and enter the system BIOS. How you enter the system BIOS screen will vary according to your computer's manufacturer. This usually involves a series of keystrokes. Which keys are used will depend on your system. Now that we are in the BIOS screen, we are ready to speed up Windows XP boot time. Find the Boot menu and select it using the arrow, Tab and Enter keys on your keyboard.In most systems, you'll find a Quick Boot option. Enabling this will skip common system self tests that occur automatically when the computer is powered up.
In the next step to speed up boot time, look for the Boot Device Priority option. You should change the first boot device to your hard drive. This will speed up boot time, but won't allow you to boot via a boot disk like CD or floppy. If you make this change, then need to boot from a disk later, you can re enter BIOS and change it back. Next, choose the option Exit and Save Changes and the computer will restart.
Always Remeber to do this process carefully because a wrong action will cause destruction and make your computer useless.
Dec 04, 2010 | IBM ThinkCentre 8172 Intel Desktop PC -...
Heater or ac wont blow air in my 2003 ford escort zx2. heat comes out when the heater is on and i am driving fast? is it the blower fan? where would i locate it at?
Try unhooking one of the battery cables and leave it off for at least 20 minutes. When you hook it back up the
computers should re-boot. That has solved problems for me with heater, interior lites, power windows, AC, day
time running lites, power mirrors, fast idle, rough or slow shifting, CD player, and wipers on GM autos and S-10
PU and Dodge trucks. None of the switches are connected to the device they control anymore. The switch tells the
computer to open the window and the computer sends a signal to the window motor. When the computer gets
confused strange things will happen or not happen. Things like one headlight stays off etc. I actually had to do it
twice on my Bonneville because the first time the AC blower would only work in low and medium. After the second
re-boot, everything was fine. Of course you may have to re-set your radio stations.
If that doesn't work, check the fuses.
Sep 03, 2010 | Ford ZX2 Cars & Trucks
5300 restriction code
Sir,Remove sim first,power on the phone.
After the phone boots up, press #
Press * 3 times fast for (p)
Press * 4 times fast for (w)
Press * 2 times fast for (+)
Verify code before pressing the last #.
"Phone restrictions off", it's unlocked
Dec 25, 2009 | Nokia 5310 Cellular Phone
Selecting booting device
Normally with the new laptops you have to press F2 to access your bios settings, you will definitely be able to select the boot device from there.
If F2 does not work startup your laptop and watch the screen, there must be an option that will tell you which key to press to enter bios.
If the screen comes and goes to fast for you, press the pause button on your keyboard so you can read it at your own time and do your actual selection.
Hope it helps.
Aug 29, 2009 | Microsoft EF1330255 Keyboard/Mouse
Booting up
try to go cmos then change the time and date and firstboot hardisc
Apr 05, 2009 | Computers & Internet
When i power up my Hp Proliant ML110 server, it will show start up screen and go blank without loading windows 2000
Try safe mode boot, hit F8 or F5 fast in beginning of boot process. You may have to try this a few times to get timing just right.
Mar 19, 2009 | HP Compaq ProLiant ML110 G4 Server
Computers & Internet Logo
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
