Question about Shure Beta 58A Professional Microphone
Thred gone on where you screw the battery end
    Prodigy:
    An expert who has answered 500 questions.
  • Shure Expert
  • 611 Answers
If the threads are gone, you will need to replace the part. Replacement parts can be purchased from Shure Parts at 800-516-2525.
Posted on Sep 13, 2010
Screw struck
I suggest taking the machine to a sewing machine repair shop
Mar 01, 2012 | Baby Lock Evolve
When reinstalling the drain plug i that it was tight then it got loose i know i didn't over tighten it, then removed the plug and then noticed alum.on the threds the threds screwed off the plug easy in one...
Hello; Safe saves! If in doubt, take it completely out and give the threads a good visual inspection. Take a good look at the case threads also. Sometimes, when a plug is removed, the copper or nylon gasket creeps up the threads. when reinstalling the gasket then jumps the threads giving a sudden loose feeling,. After inspecting and making sure the seal, between the case and drain plug, is flat against the underside of the plug. When tightening, turn the plug slowly continue until the crush or sponge feeling is gone and the plug is firmly seated. Do not go past "STOP"! Good Luck and thanks for using Fixya for your answers. _Ned_
Apr 04, 2011 | Yamaha Roadliner Motorcycles
Taking off the top screw for elevation the unit below the cap came off also. how do you seperate the two? thanks jack
that what you get for doing them up so tight,,,if your lucky you should still have a little thred showing ,,get a hold of this thred in a very very soft vice and undo the cap,,,,if you bamage this thred the scope is going to be a scraper,,,when you get the top off put a spot of supper glue on the first thred and screw it back into the scope,,,you should now have the scope re-gased,,,
Aug 25, 2010 | Leupold 1 3 x 14 CQT Riflescope
The screws to put the crib together are stripped need new ones cant find it is simmons natural meridian collection bought about 4 years ago
if the threds are striped on the screws,,,,or are they "bolts?"
what are the threds like in the nut holders? if there striped as well,,,you need to replace the lot!
Aug 21, 2010 | Toys
Installation Directions were missing from a Delta #132900
first get pair plieyers and a x screw driver once u have ur tools first the shower head look behind the shower head their ull find were u unscrew it get ur plaiyers start unscrewin it after its off before u put the new one put plumbing tap around the threds were u screw the new one 6 in of plumbin tap rapit around the screw threds tighly then screw the new one on now for the temprature adjuster were u turn on an off the water all u need is a x screw driver un screw the screws it shud come off ez then jus do the same thing wit the new one just put the round back peace first get the screw and screw it on then then the water adjuster put it on then screw that part on tightly u shud be ready to go.
Aug 18, 2010 | Delta & Single Handle Shower Faucet
Thread mess at the underside of the fabric
On the bobbin holder there is a smaal screw, thghten the screw to set tention on the bobbin thred. The thred you use on top and in the bobbin can be the problem as well E-Mail me wcbotha@yahoo.com
May 10, 2010 | Singer 8280 Mechanical Sewing Machine
Striped transmission drain plug case
the only way to fix a striped thred is to fit a (hellycoial?) in it, its a kind of spring that winds its way into the old thred and gives you a new thred to screw into (but there realy not very strong) i have used them when i striped a spark plug thred out and it lasted for years,,,you could buy a kit or take it to the bike shop for them to fit one in for you its a lot cheeper than a new case,, and you can still use the same plug,after its been fitted
Nov 05, 2009 | 2004 Harley Davidson FLSTC - FLSTCI...
Oil pan will not quit leaking after replacing stripped drain plug
If it IS Leaking from DRAIN PLUG and You Can Not RE-TAP New THREDS into it ( REPLACE the OIL PAN) I Have never RE-TAPED Drain Plug Threds Because I Prefer Original Threds, So Any Customer wiht This Problem, I Advised them to Replace the Whole OIL PAN.
This is What I Would do, The Oil Avalability Is CRUCIAL to The Engines Survival.
Jul 28, 2009 | 1995 Jeep Grand Cherokee
2000 Chrsyler neon transmission fitting problem
You Must Gain Axsess to that hole and Inspect for Proper threds.
If threds are Too Damaged it must be rethreded, this can be costly so if at all possible D I Y. Gat thred type & Line nut size and go "1" size up.As I said this IS a HARD one to REPAIR so Good Luck on it.
P.S IF by chance the threds are Not Too Damaged RETAP The hole W/ Same Size & TYPE of THRED again GOOD LUCk
Mar 14, 2009 | 2001 Dodge Neon
Can not seem to losen nut on right front rotor 1994 mazda 323
The threds are standerd, I had to use a cheeter bar in order to get the nut to turn and then there is a threded hole next to one of the studs, useing a 12 MM course threded bolt screwed down into said threded hole the rotor came off as easy as can be.
Dec 27, 2008 | 1994 Mazda 323
Shure Beta 58A Professional Microphone Logo
80 people viewed this question
Top Shure Audio Players & Recorders Experts
Michial Gueffroy
Ben Armstrong
Vito Vacirca Jr.
Are you a Shure Audio Player and Recorder Expert? Answer questions, earn points and help others
