Question about Hoover U6476-900 WindTunnel Vacuum
My Hoover Windtunnel does not clean carpet. The machine keeps grabbing the carpet. It appears that even with the switch set for carpet, the machine keeps acting as though it were set for a hard floor. How can I fix it?
  • 76 Answers
Move the height adjustment up a little
Posted on Aug 22, 2009
How do I repair Hoover Windtunnel floor/carpet switch? Brush will not turn but belt is not broken. I believe setting was hard floors and son forced the switch when the vaccuum was running.
The lever that switches from carpet to hard floors may be broken if it was forced, remove the cover to gain access. Replace both belts too. They may be stretched or worn even though they look good.
Dec 31, 2016 | Vacuums
I replace both belts on my hoover windtunnel and the small belt has no tention why.
Be sure the selector switch is set to carpet and not "floor" would be the easiest thing to check first.
Sep 17, 2014 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover U5780-900 Windtunnel Cyclonic Bagless
You probably need to change the belts. Here are the belts you need and the manual:
Hoover 5780-900 Belts
Manual
Dec 22, 2009 | Hoover U5780-900 Windtunnel Cyclonic...
Carpet/Floor Switch problem on Hoover WindTunnel Vacuum
Well, you have to deal with it, you have to play with this electrical things if you want to fix this problems.
The good news is, the sources of the problems is the switch already broken.The first things before you do anything is, find this switch on the market first to changes the old ones.Then, remove the power cord from the outlet of course.
After have it, then you must open the old switch, and remove it from the unit by cutting the cables using cutter/ pliers or anything.But remember, you must remember the locations of each cable that been cut, you can use Camera Cellphone to make sure of it if you like.
Then put the cables back together with the new switch, after all done, clean all the mess and try operate it.
Hope it works!!!
Dec 09, 2009 | Hoover U5753-900 WindTunnel Bagless...
How do I fix the carpet/floor switch on a hoover windtunnel bagged self propelled
The carpet / floor switch is a mechanical assembly. the bottom cover needs to be removed to expose the screws for the hood cover to be removed. then the switch can be accessed for repair
Oct 04, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Beater bar
There may be a shutoff switch, located on the hood, that shuts off the agitator to permit bare floor cleaning. Return the switch to carpet mode.
Sep 29, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover 6616-900 keeps ja,,img due to shedding new
this is going to happen untill the carpet stops shedding. you can try to go to the highest setting to see if this helps
Jul 17, 2009 | Hoover U6616-900 WindTunnel Bagless...
Hoover Windtunnel carpet level adjustment
The suction is so great that it sucks up your carpet, then nothing works. I get my children to stand on the corners/edges of the rug so that it stays perfectly flat on the floor while I vacuum. Or, you can turn off the brush roller (set it to "hard floor" setting). Or, tip the vacuum cleaner's front up slightly while vacuuming, to reduce suction.
Oct 28, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Self-Propelled WindTunnel by Hoover U6445906
· Sometimes grabs the carpet for no reason.
· Comes back too fast when I push it back.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Self-Propelled WindTunnel by Hoover U6445906 Without knowing the brand name or model number you may have the height adjustment to low and the vacuum will say “bite down” on the carpet of which will make the belt burn and might leave marks on the carpet – and if you have a self-propelled vacuum it does come back fast if you because you have a transmission just like a car and you have to control the speed of the vacuum or because it may have a weak belt the vacuum will pull back easier – I really would like to know the brand name and model number so that I could accurately give a better answer . Recommended belt change for flat belt(s) are 4 to 6 months for better cleaning and one a year for a geared belt – both can stretch and lose their cleaning function
Apr 05, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover windtunnel
would suggest the drive belt is stretched and thus is slipping when contact is made with the carpet.
Jan 14, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover U6476-900 WindTunnel Vacuum Logo
294 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
