Question about Oregon Scientific Lwb0997110113004 Thermometer, Tht312/Blrw Clock Radio
Lost directions for digital meat thermometer
I recieved a Thermo Tech digital meat thermometer and I have misplaced the directions
Meat weighs 2llb 20oz how long should i cook it for we like it medium rare ?
The best thing you can do is to buy a BBQ digital thermometer that you place in the meat during cooking. They have a heavy duty wire with a temperature probe on the end. Sear the meat directly over the coals (or hot side of a gas grill), then move the meat to a cool side and then insert the temperature probe and close the grill lid. Cook until it reaches desired temp, for me 125 degrees is perfect. The total cooking time is hard to judge as it depends on your grill cooking temp, but the digital thermometer takes all of the guesswork out of the equation as to when the meat is done.
Apr 06, 2015 | Grilling
I lost the instruction manual to our Oneida digital meat thermometer
The buttons should tell you what to do, they are all made be same people just take a few minutes to play with it. Normally set temp you want, or set time you want, pretty easy
Mar 23, 2014 | Cameras
What are digital probe thermometers? Are they used for cooking meat?
yes - digital probe thermometers are very good for testing whether meat is cooked. The thin sensor is inserted into the fattest part of the meat. A wire then runs from the sensor out of the oven door, so that you can keep an eye on the temperature without having to keep taking it out the oven.
Feb 14, 2013 | Home
Hi! I just bought a Weber pocket digital thermometer and want to know if I shall leave it in the meat in the oven during all the roasting time or insert and check once in a while? Please help.
It is not designed to be left in the meat, while in the oven. It's an insta-read type of thermometer for occasionally checking the internal temperature, in the thickest portion of the meat, while cooking. Be careful not to insert it in such a way, that it touches a bone, It will give a false reading, if it does.
I hope this helped you and thanks for choosing FixYa.
Aug 14, 2011 | Weber-Stephen Products Weber Digital...
Can you give clear instructions on to use the weber pocket thermometer.The instructions i got with it i find are not very clear;and could you tell me the proper temperature for all the various meats.Thank...
Here's the general rule of thumb for cooking temperatures for meats. Remember though, you cannot leave the thermometer inserted in the meats while cooking. It's only for Instant Read.Always insert it in the thickest part of the meat away from any bobes.
BEEF RARE 14=30 - 140F
Jul 30, 2011 | Weber-Stephen Products Weber Digital...
Can i use a digital meat faberware thermometer on a outside grill? How do I use it?
Just to check the meat temperature, yes. Not to leave in to determine temperature of the grill. My propane grill heats up to almost 600F. That will destroy the digital thermometer.
I hope that answers your question.
Jul 18, 2011 | Garden
I've misplaced the operating instructions for my williams sonoma remote meat thermometer. I can't get the probe unit/base to sync with the remote transmitter or to show a temp on the base unit and find a...
This is for a model ET-903WS: Turn the base unit on first. This is the unit with the larger display & buttons. Hold the power/mode button (upper left) down until you hear 3 beeps and the display lights up. Mine then displays "BEEF" and shows 160, with 3 blinking spaces. Next, plug the probe into the smaller remote unit. You should get 1 beep, the remote will display the temperature and the base will now display the same temp where the blinking spaces were. The first couple of times I tried, the base would not display. Unplug the probe, turn the base off holding down the same power/mode button and start over. I've had to do this as many as 4 times but it has worked perfectly while I wrote this!?! I really like this thermometer because I can put the meat on the grill go inside and have a drink while watching the game and then a friendly voice comes on when the internal temp is within 10 degrees of your target and says: Your food is almost done...your food is almost done." If you sleep through that, she comes back on at temp and says "Your food I'd done...your food is done". I take most meat off at the first warning and wrap it in foil. Watch the probe and it will continue to rise for about 20 mins. Enjoy.
Aug 08, 2010 | Microwave Ovens
I have a Sunbeam digital meat probe thermometer used once. Now the display for thermo/temp comes up H instead of the temperature of the meat. What is wrong? Sunbeam digital meat probe thermometer has quit...
I left mine in a hot tub for well over an hour. It started reading room temp at about 125 degrees. It worked for me to put the thermometer in the freezer until the readings were correct. hope this works for you.
Feb 22, 2009 | Sunbeam 2370 MixMaster Series Stand Mixer
I have the same problem. The problem is the probe went bad. I had a friend with another sumbeam digital probe (the mavrick) put that probe into mine and the temperature reading was working properly. So, now I am looking for a replacement probe. but looks like I will have to just buy another digital meat probe.
Aug 16, 2008 | Sunbeam 4214 Iron
Oregon Scientific Lwb0997110113004 Thermometer, Tht312/Blrw Clock Radio Logo
1,701 people viewed this question
Top Oregon Scientific Audio Players & Recorders Experts
Mohammad Abumuailek
Mohammad Abumuailek
Gyula Lacz
Are you an Oregon Scientific Audio Player and Recorder Expert? Answer questions, earn points and help others
