Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
Condisation line freezes backs up in freezerthen drips in fridge
Had it fixed last year but it only lasted about six months for 250.00
  1. fridge line on the back is freezing up any help to what the problem is
Posted on Jul 08, 2009
    Problem Solver:
  • 10 Answers
I have had to install a mullion heater on problems of this nature and it will solve the problem forever. Check with your local appliance parts dealer and tell them your problem and they will fit you with the correct heater size and instructions. It can be wired to stay on all the time as it is a small output of heat that will not effect your temperatures inside the box and will cost very little to have in use each month
Posted on Mar 07, 2009
Kitchen aid ktrs22k
You must have a defective defrost timer.
Jul 22, 2017 | KitchenAid Refrigerators
Ice maker spout starts to freeze up (6years old Viking side by side), is there a solution?
low water pressure or faulty valve
low water pressure the valves do not seal proper and slow drips freeze up in tube
are you on well/?
last time fridge filter was changed?
if all good faulty water valve
Mar 28, 2017 | Viking 48 in Built In Professional...
LG LMX28988ST freezer at 30 degrees
What it the reason that my fridge is freezing my food. The temp. IS set to 37 F. Why
Mar 14, 2012 | LG LMX28988 (27.5 cu. ft.) Bottom Freezer...
Our fridge is not working properly for the last six months now.there is excessive cooling in the lower portion of fridge.everything in this part is getting frozen.how to rectify
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Dec 15, 2010 | Refrigerators
HOT POINT FRIDGE - FREEZER DRIPS WATER
The evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help. Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the back of the freezer.
Jul 12, 2010 | Hotpoint HTS16HBR Top Freezer Refrigerator
Water dispenser worked perfectly for 9 months. Today, no water comes out at all.
hi michael! you may have to get out your owner manual and read about how to change the water filter. get back if u need assistance
May 09, 2009 | Refrigerators
Blinking temperature control
You need to check the limit thermostat for the defrost in the back of the refrig section. I replace it with a standard bi-metal type from a Frigidaire to keep the problem from reoccuring.
May 16, 2008 | Refrigerators
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
177 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
