Question about Eclipse PA5422 Car Audio Amplifier
Tuning I have the Eclipse PA5422 and I'm not getting good sounds in the mid range, do you have any suggestions
  • 3 Answers
Try turning down the lows and highs to bout 3/4 then adjust you mid
Posted on Mar 11, 2009
Oven shuts off while baking and will not restart till oven cools off??? thanks mark
Good Afternoon Mark,
I see that you're having trouble with your Frigidaire range, model# PLCS389DC, shutting off in mid-baking, and will not restart until the oven has cooled. It sounds like it is either the temperature sensor, that is sensing a runaway oven temperature, or the control board itself that might need replacing. I suggest contacting you local authorized technician for further assistance. They will be able to determine what exactly is causing your oven to cut off in mid-baking.
-Best Regards-
WP
Apr 01, 2014 | Frigidaire PLCS389DC Dual Fuel (Electric...
Hooking up speakers
first off stock wiring for speakers,and or amp are with minimal wiring.Rewire system for better sound quality,also use noise suppresors if needed.
Jan 18, 2014 | Toyota Cars & Trucks
Thanks for the answer - If we have 3 controls as Bass, Mid and Treble. If we keep those in 12 O Clock position, will the output level be equal. In using the Bass and Treble control only (if we have...
If all are in 12 o'clock position they are "flat" (nothing has been added or subtracted foam input signal) If you only have bass & treble, yes adjusting will affect "mids" but Mids change can go both ways dependent on increase or decrease of Bass and /or treble. By increasing bass you will pull some mids up also. By increasing treble you'll subtract some mids.
Mar 17, 2011 | Audio Players & Recorders
How do i connect a single 12" subwoofer to an Eclipse PA5422 amp?
Make sure your switch on the amp is on lpf (low pass filter)....You should be able to bridge that amp....Look where you hook up speakers and see if it has a line over one negative and one positive....Should be outer two screws.
Oct 16, 2010 | Eclipse PA5422 Car Audio Amplifier
Have a yz 125 2001 help coughs and sputters mid range reves
Have you checked the condition of your reeds? This sounds like a good place to start troubleshooting.
Apr 09, 2010 | 2003 Yamaha YZ 125
I was given the amp and I want to test it with a volt meter to see if it even works. I currently dont have a system .
Easiest way, get any old speaker 4 or 8 ohm and hook it up to channel 1 then plug an rca lead into channel 1, power up amp and touch finger on rca and you should hear pop or scratchy sound from speaker . Audio circuit for channel 1 is good . repeat for channels 2 3 4 .
Mar 17, 2010 | Eclipse PA5422 Car Audio Amplifier
Installing PA5422 in two channewl mode
Since your first paragraph is leading to your question paragraph, I'll adress that. "what is the difference amongst the MONO/STEREO/L+R switch options available on both Front and Rear AMP X-over Sections of the PA5422?" Mono is same sound output on each channel, stereo is what you want as it gives out stereo sound, and L+R is most likely blending the channels together.
Sep 23, 2006 | Eclipse PA5422 Car Audio Amplifier
Eclipse PA5422 Car Audio Amplifier Logo
62 people viewed this question
Top Eclipse Car Audio & Video Experts
xxxxxx xxx
Are you an Eclipse Car Audio and Video Expert? Answer questions, earn points and help others
