Question about Kenmore Vacuums
Take apart 8020 kenmore vacumm
Kenmore vacumm model 8020
I have a kenmore progressive vacumm when plugged in it has no power to it what can i check
Most vacs have a reset button by the coard where coard goes in to the housing there is a small pin hole about the size of a ink pin insert til it ckiks ,but there mak be dust obstructing vents causing it to over heat always unplug proir to working on any mechanical or electrical device ane it yuo tahe it apart put ti back togather prior to powering it up.
Feb 20, 2015 | Kenmore 25512/ 25513 Progressive Canister...
How do I take the handle apart on my Kenmore Progressive vacuum model 116.21614011? I removed the screws but it won't come apart.
There are catches that snap the handle together. It's hard to separate the handle without breaking the catches. Replacement may be required
Oct 05, 2013 | Kenmore 25512/ 25513 Progressive Canister...
Kenmore model 116 58015700 power mate beater bar stops working
Just pulled mine apart and the bearing on the belt side is toast. In the past five years I have had several items fail due to less then optimal bearings. Including a transmission in a Vibe and a front load washing machine.
Mar 30, 2013 | Kenmore Vacuums
Kenmore vacumm cleaner power head
Whats the problem. Brush don't turn or etc.
Jan 13, 2012 | Kenmore Vacuums
Hoover Silver Steam Cleaner
If the solution chamber is full,there might be a clog in
a screen,or a bad pump,which circulates the fluid.
You might have to take the vacumm apart,if everything looks good from the outside. Good luck.
Apr 01, 2010 | Hoover SteamVac Carpet/Upholstery Deep...
Hi I have an electrolux vacumm cleaner, super J model. My problem is that the powerhead only works if the switch is in the off position. vacumm motor works in the on position, opposite of each other. Can...
Looks like there's an interchanged wires in your vacuum. Both the motor and the powerhead must go together. Check it up. Leave the
motor wiring connection intact. Just tinker and check the powerhead
wiring connection .
Sep 25, 2009 | Electrolux UltraLux 2000 Bagged Canister...
How do I open a Kenmore 116 Vacuum?
You shouldn't need to remove the cord just to put a new plug on. Just cut the end off about 2 inches back, strip the outer insulation and the wire ends and install the new plug. Make sure there are no stray strands of wire hanging out from under the screws. I always solder the ends, so that I am dealing with a solid wire rather than twisted strands.
Sep 19, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Cost Kirby Vacumm
you can find used models fairly cheap. i have one we paid about $60 for. look around the internet in places like craigslist or ebay.
Aug 24, 2009 | Kirby Ultimate G Bagged Upright Vacuum
I need to replace the belt on my Sharp Vacuum Cleaner: Model ECTU4609. Can't find Owner's Manual and can't figure out how it goes on .
i have replaced vacumm belts before .. Normally it is located underneath..flip over the vacumm unscrew some screws.. open the cover..youll see a large roller pin type object remove it carefully noting how it is placed..pull it out.. and replace the belt...you can also clean off the debris while doing this..an added plus..for vacumm maintenace..
PLease indicate whether this has helped you at all ..Thank You
Jul 05, 2009 | Sharp Twin Energy EC-TU4606 Bagged Upright...
Prolem putting parts together
Heres the link to the manual
newzealand.bissell.com/images/UserGuides/6594.pdf
Nov 19, 2007 | Bissell 6594 PowerForce Bagless Upright...
Vacuums Logo
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
