Question about MyMusix PD-6070 MP3 Player
Reformat to fat16
I turn on my musix player it says error reformat internal media as fat16
  • 3 more comments
  • stumiister Mar 07, 2009
    I turn on my musix player it says error reformat internal media as fat16 the player has an internal battery that is not removable
    I have a my musix mp3 player when I turn it on it says error reformat internal media as fat16 how do I reformat the mp3 with that software
    I have a my musix mp3 when I turn it on it says error reformat as fat16 it is plugged into my computer and I click on the start button and then my computer button I dont see the icon for my mp3 player
    I have a my musix mp3 player when I turn it on it says error reformat internal media as fat16 I don't care about losing my songs I want the player to work again the battery doesn't come out and I don't see an icon when I click the start button then click the my computer button
    I was able to acess the firmware I needed from the manufacturer and I was able to fix my mp3 with out FIXYA's help so thanks for wasting my time and my 10 dollars
  • 479 Answers
plug in your music player and find it in my computer.
open command prompt and type the letter assigned to player(say this is E then type E:) and enter
Now the prompt will be the players drive letter then type
format drive(assumed E:)/FAT 16 and press enter
Posted on Mar 07, 2009
  • Gyanendra Kumar Mar 07, 2009
    the player will be formatted
    Master:
  • 404 Answers
Yes plug it to your pc, then go to my computer then right click on it and select format
but select NTSF and quick.
ntsf better, fat is okay but you do this when you
want to use it on a mac.
  • lotfi bouakaz
    lotfi bouakaz Mar 07, 2009
    if its powering on without being connected to anything do the following.
    connect it via usb cable to your pc
    click on start, right click on my computer and go to manage
    in the table select, "storage" then "disk managment"
    in that table find the drive that relates to your mp3 player
    if its not there "buy a new mp3 this is faulty" if its there
    then right click on it and select "new partition"
    you just next next everything and then format it and after
    a while it shows "healthy2
    unplug it, plug it back on and that's it your drive is fully working
    now move what ever you want to it just like before.
    Sergeant:
    Champion:
  • 224 Answers
It seems the file system on the player is corrupted asking for a re-format. I don't believe you may be able to et your music back. It would be best to fornat and start over.
If however, you get the same error after the format, it may mean that your player has a physical fault. Needs replacement...
  • Shakeel Muradali
    Shakeel Muradali Mar 07, 2009
    ok try this
    connect the player to your computer, on the computer, right click on "my computer" and click on "manage"
    On the left you shoudl see disk management, click that.
    on the right, see if you can find a removal disk or drive. That should be your player. Does it have a partition? right click it and create a new partition and format it using fat32.
    Please advise if this works
    Brigadier General:
  • 8,619 Answers
Hi!
Plug in your mp3 player.
Go to My Computer-> Right click on the mp3 player-> properties-> format-> format it using FAT file format and then re-connect it with the computer.
Please ask for further clarifications.
Thanks
Rylee
  • Rylee Smith
    Rylee Smith Mar 07, 2009
    Go to control panel-> administrative tools-> computer management-> from there select storage and under storage you will see disk management-> Can you see your mp3 player over there-> if yes then right click on it and select the option change drive letter path-> change it to K or L(drive letters which are not used).
    Sergeant:
  • 320 Answers
Here are two ways to format an Mp3 player - one on the computer itself, and one in Windows Media Player. Both methods will end up erasing all the songs on the player, but the player will be "good as new" after that. Sometimes reformatting in this manner will override the player's native formatting and cause problems - this can be reversed in most cases by updating the player's firmware. Firmware upgrades are available from most manufacturers' websites.
WARNING: The following procedures will erase all songs on the player.
Check if the file system is NTFS. If yes, format it to FAT or FAT32. - Connect player to computer, double-click my computer, right click on icon of mp3 player and select format. This only applies to Windows-based computers.
You can also format the player in Windows Media Player itself:
Connect your Mp3 player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "name of Mp3 player here 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
also try this another method
go to my computer> properties>hardware > device manager >universal bus driver>right click on it> update driver>
then1
1.yes this time only> next 2.choose advanced option>next 3don't search i"ll update from........>next4.click on show campatible> next> next 5. now it updated then restart you computer
  • 6,784 Answers
Ok, power off and take the battery out. wait for 3 min, then put the battery back in and power up. it should work then.
  • MyMusix Master
  • 19,396 Answers
You need to reformat the internal media.
  • Ginko
    Ginko Mar 07, 2009
    Use the format command to re format the internal media , the disk had been formatted to the wrong FAT16 format using a computer, it need fat32.
  • Ginko
    Ginko Mar 07, 2009
    Connect the player to a computer, then go to My Computer, or Computer on vista, and find the player in there.
    Click the right button of mouse on player disk displayed under computer.
    From dropdown menu chose format.
    Under format command dialog box chose 'Complete Format' and set the format to FAT16.
  • 154 Answers
Please explain this.
  • crysiszone Mar 07, 2009
    connect it to computer go to control panel. click on preformance and maitenance. at the bottom click system look at the top, something should say hardware, click it. the clikc the device manager. make sure your device is plugged in click the + sign on mtp media devices or somthing like that. when option comes up clikc uninstall. it should reinstall by itself and see if it works for u.
    after the previous step, go to my computer and see there is a new drive blongs to the player right click on it and select format option.
Reformat
connect to your computer and then open "my computer" right click on the player, select properties and then tools. select format and set to fat16, you can also scan for errors from this tab by checking the box.
May 09, 2010 | MyMusix PD-6070 MP3 Player
When I turn it on I get an error message: Error: Reformat internal media as FAT16. If I let the screen go blank then turn it on again holding the button for about 10 seconds it does finally come on. What...
you may need to reformat it according to the computer you are using. If you, just select the drive in my computer(where your hard drive/cdrom/all that **** is) hit format, at the top there will be a drop down menu, click fat16 from there, then select quick format...should fix everything
Apr 01, 2010 | MyMusix PD-6070 MP3 Player
Is there mp3 players at the dollar general in kingwood because i want one for around 10 dollars
"Error! Reformat Internal Media as FAT16" what happened "Eroare! Reformata Interne Media ca FAT16," ceea ce sa întâmplat
Feb 05, 2010 | Creative Labs Zen Touch MP3 Player
It tells me i have no more space, but none of my music plays, i go in and no music comes up
Feb 05, 2010 | SanDisk Sansa E280 MP3 Player
Wow! FAT16! I wonder why it would want you to do that?
Here's how you do it on a Windows-based OS:
Connect mp3 player to computer
Double-click My Computer
Right-click the icon of the mp3 player
Select Format
When it gives you a choice between FAT and FAT32, choose FAT
-Tha Mp3 Doctor
Mar 01, 2009 | MyMusix PD-6070 MP3 Player
My mp3 player
Read the "Tips and Tricks" under my profile on formatting a player
Jul 25, 2008 | iLO (2 GB) MP3 Player
Error reformat internal media as fat16
Try formatting it with FAT32.
Mar 31, 2008 | iLO (2 GB) MP3 Player
Depending on the requirements of the mp3 player, you may just have to right-click format in Explorer, or a computer guru friend to format it for you with a partitioning program if it needs a partition table.
Feb 13, 2008 | RCA TH1500 MP3 Player
then1
your problem will now soved
May 20, 2007 | iLO (2 GB) MP3 Player
MyMusix PD-6070 MP3 Player Logo
15 people viewed this question
Top MyMusix Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a MyMusix Audio Player and Recorder Expert? Answer questions, earn points and help others
