Question about Maytag MDB7100AWB Dishwasher
Maytag MDB7130AWB dishwasher blows circit breaker.
I ahve a Maytage MDB7130AWB dishewasher that sometimes blows the circit breaker. It is 7 years old and has been doing this for a few monthes. Sometimes it runs a full wash cycle fine, the next time tou have to reset the circit breaker 4 or 5 times to fet a full wash cycle. I have looked for pinched or cut wiring but have found nothing wrong. Any help or ideas would be great. An electrical diagram may help too.
  • chvlldreams Mar 11, 2009
    I've had the door panel off, a little water at the botton, but on the opposite side from the wires. All of the wires and connections look good everywhere I can see. I have replaced my breaker , outlet, and the wire between the two. So far it has not blown since, but have only run the machine twice.
  • 318 Answers
These have been known to leak water into the door panel. If so the water can cause a short. Your breaker is keeping the machine from lighting up. Check any seals that may have been braeched in the door. Start at the dispencer latch
rubber.
Posted on Mar 07, 2009
  • toyotech6 Mar 11, 2009
    It sounds like you may have fixwed the problem. It is good to have the dishwasher on it's own line. I hope you used 12/2 wire instead of 14/2.
    I know it sounds far fetched but there should be no water in door panel. If it blows again you might have to revisit the panel.
How do I reset my mdbh955aws?
DIY fix your Maytag dishwasher on the cheap - Instructables
www.instructables.com/.../DIY-fix-your-Maytag-dishwasher...
InstructablesLast week my 1.5 year old Maytag dishwasher suddenly quit working. ... of its own for about 2 years, shutting off the breaker to reset it has worked until today.
Oct 19, 2015 | Maytag Dishwashers
MDB7130AWB thermal fuse
This might help. This is the thermal fuse you need if you need a replacement. Cost is somewhere around $25.00
Thermal Fuse
PartSelect Number PS342838
This part is used as a safety device to protect the dishwasher circuit from overload. If the temperature gets to high it will shut off the electrical current to the heating unit in the appliance.
This part works with the following brands: Whirlpool, Admiral, Estate, Inglis, Kenmore, KitchenAid, Roper, Maytag, Kenmore, Admiral, Crosley, Jenn-Air, Hardwick, Magic Chef, Amana, Caloric & Glenwood.
This part fixes the following symptoms:
  • Not drying dishes
  • Will not start
See part 26 in the diagram
Apr 08, 2013 | Maytag 24 in. MDB5600A Jetclean II...
My Maytag dishwasher will not run. It is completely dead. Nothing lights up, etc. It is only a few years old.
Many newer dishwashers are wired to a switch on the wall as a means of service
disconnects in new homes. Also I would check the GFCI outlets in the kitchen area
and possibly the bathroom as well to see if they are tripped. (Press the test button and
then the reset button on them to test). The next thing I would check is the breaker
panel to see if the dishwasher is on it's own breaker. And lastly I would check the
connections to the dishwasher itself (after making absolutely sure power is off to the
wiring feeding the dishwasher at the breaker panel). I hope this is helpful.
Aug 06, 2011 | Maytag Dishwashers
Dishwasher Maytag model MDB7130AWB does not clean well leaves residue of food. Have tried standard dishwashing solutions does not help. Trying to clean the flilter below the lower arm and arm itself....
Check the drain line from the washer out, to the drain in the sink. Some how the restriction is causing residue to backup and your not getting a free flow out to the drain. If its a HOSE, disconnect it and blow it out with a vacuum and replace again.
Feb 17, 2018 | Maytag Dishwashers
Blew a circit breaker this morning dishwasher wont start all power in kitchen is working this is a 1 1/2 year old dish washer
I am sure that you know that the dishwasher is on its own circuit... and that, in an older home that has been upgraded, the dishwasher may be on a GFI circuit.... If I am correct, you have an open GFI circuit somewhere in the kitchen or in a first floor bathroom.... that is feeding the dishwasher...
If all breakers are 'on" and no failed GFI is found, the the bad news is that the program chip in the dishwasher has been fried...
If that is the case, you may be better off replacing the dishwasher than in replacing the chip in the old one.
-Jim
Oct 17, 2009 | Dishwashers
Electronics problem with Maytag Dishwasher
the outlet pump may have become clogged, try removing and cleaning it.
Mar 26, 2008 | Maytag 24 in. MDB9150A Built-in Dishwasher
MAYTAG DISH WASHER MODEL 41-ESP4-DISH
I suggest calling Maytag and have a tech come out to look at it. Appliances come with a one year parts and labor warranty.Use it before your one year is up.
Nov 17, 2007 | Maytag 24 in. MDB3700 Built-in Dishwasher
Maytage dishwasher
Hi Fix it mom, If your courageous, pull the trays out of the way and remove the screen in bottom of the dishwasher to see if something is getting into the pump. By something I mean undesired matter. Straw, Twist tie, knife, toothpick, etc... I hope this helps
Sep 25, 2007 | Maytag 24 in. MDB4651A Built-in Dishwasher
Maytag MDB7100AWB Dishwasher Logo
358 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
