Question about GE GDS18LBR Bottom Freezer Refrigerator
Evaporator fan stops working due to ice buildup around fan.
Ice buildup around the Evarorator fan causes the fan to make noise then eventually stop. The drain hole below the fan gets clogged with ice causing the ice buildup. Produce in the vegtable bins above the bottom freezer become frozen. The upper portion of the refrigerator works fine. Problem seems to happen February/March in the Northeast, has happened twice since we purchased the refrigerator in 2005.
  • terry266492 Mar 07, 2009
    Do you know the GE part number for this Drain Tube Heater and how it gets installed/attached to the defrost heater in the refrigerator?
    Thanks
  • Anonymous Mar 25, 2014
    The Freezer is at around 30 degrees and the refrigerator is around 42 degrees. One month ago we had a technician in and he cleared ice from around the fan, and he found no other problem. The noise started again last week, then stopped. 3 days later the temperature is off. Maybe the fan stopped or it is iced up again?
  • 3 Answers
I finally added a piece of #12 copper wire, three wraps around the defrost element, leading down into the top of the drain tube. Now, when the defrost comes on, the wire is heated, along with the metal fitting at the top of the drain, avoiding build up of any ice in the area around the top of the drain after the defrost cycle.
Posted on Dec 21, 2016
    Problem Solver:
  • 5 Answers
The heater line is the companies solution to charge you more money, this is not required and playing with live home-made heating lines is not advisable as this could cause more problems than it solves. Most-likely the problem stems from a design flaw in GE fridges. Access the evaporator fan through the bottom of the fridge by removing the bottom drawers, the floor and insulation of the fridge and de-ice the area around the fan by using a hair drier and hot water. After completing this you will then want to move to the back of the fridge where you will remove the metal insulated cover covering the upper drain section of the water drainage system. This will expose a snake-like section of tubing, this is where the underlying problem stems from. Remove this section and clean it out with warm water, a turkey baster can make this a little easier. If you notice that the blockage was caused by a build up of dirt and mould then re-install the section of line and replace the insulated metal cover. If the blockage seems to be caused by a ice build up, then re-install the section of line and do not re-install the insulated cover, this will prevent this section from getting too cold and causing a blockage.
Posted on May 22, 2011
  • enteremail Sep 12, 2011
    I have a GE Profile Brita Type 5 bottom freezer model. Approximately 3 weeks ago a very annoying sound began to emit from the refrigerator compartment until the ice build-up eventually ceased the compressor fan and refrigeration of the fridge compartment leaving the freezer as the only operating unit.
    I read the many different GE internet sites, the comments from the hundreds plus frustrated owners and the How to Fix blogs for help. It seems to be a common problem where some frustrated owners decided to video tape the loud annoying noise to alert the internet world and to voice their dismay with GE customer and technical service support. (Deplorable!) I followed one of the suggested internet solutions where I used a hair dryer to heat the build-up of ice in the condenser compartment and the fridge worked for a few days before the repeat of the ice build-up froze over the fan and condenser again. This next time I left the refrigerator turned off for 3 days allowing for all ice to melt. Once again the unit worked extremely well for a few days until the ice build-up surfaced again. This time I left the Styrofoam cover off and condenser open. As crazy as it may be, the refrigerator operates without problem and even is colder than the setting. The defrost cycle works and the water appears to evaporate as expected but as soon as I return the Styrofoam covering the ice build-up problem returns. I have a refrigerator operating with an exposed condenser – not the best solution. I am aware that many GE owners have experienced this problem but has anyone found the solution? My attempts to work with GE failed and their answer was simple – this is a problem that requires a trained technician. I have read that it may be the motherboard, a blocked tube (where?), the need for a drain tube heater (but everything appears to work with the condenser area exposed) and last may even be the thermostat. Any solutions are welcomed.
    President:
  • 2,976 Answers
Use wire ties or garbage bag twist ties to secure it to the hot line running next to it from the compressor.
Posted on Mar 07, 2009
  • 163 Answers
You need a drain tube heater.it is like a chain fence tie made from alluminum,you can actually use the fence ties,wrap one side around defrost heater and stick the other side in drain.that will prevent it from happening again
  • mike cooksey Mar 07, 2009
    i do not know part #,but i use chain link ties.make sure it is alluminum.you can get a bag of them at most hardware stores for around $3.00 or so for 30.but they work great.very easy to install.take back cover off in freezer and you heater will be at bottom wrap one side to heater and stick the other end in drain.good luck
Ice buildup by evaporator fan down into drain in back of unit. I melted ice using steam and heat, but it has happened 4 times.
Your defrost id not working, you didn;t leave a model so that is all I can tell you now
Mar 26, 2016 | Refrigerators
How do i fix a loud noise coming from my frigidaire glrs264za refrigirator?
Sounds like you have ice buildup next to the evaporator fan that circulates air inside the fridge. Ice buildup happens due to too much moisture - door open for extended periods, leaky door seal, heating system meant to de-ice the fridge not doing its job. You can approach this two ways. Unplug and leave both sides of the fridge open for at least 24 hours to let it thaw, or open up the fan cover and thaw it with a hair dryer (fridge unplugged ofcourse). Option two is faster, but more labor intensive. This wont solve the underlying problem of ice buildup, but will get rid of the noise for some time (likely months).
Sep 06, 2014 | Refrigerators
Have a loud humming noise
You probable have ice buildup around your evaporator fan. You would need to remove the evaporator cover inside the freezer to expose the fan and see if you have ice around it.
Mar 13, 2013 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Samsung RF26XAEBP frig a little over 2 years old sounds like fan motor is rubbing behind icemaker area when i open the door it stops close the door it starts again how to resolve?
You need to unplug and then remove the rear panel inside the back of the freezer and look over the fan assemblies to insure they are not hitting accumulated ice. Ice buildup around fans can be caused by leaving refrigerator or freezer door open over extended times or defrost component failure. Either way it's a good idea to have a look at the inside of the evaporator compartment to prevent damage to fan blades and food loss. Click HERE FOR=>> Samsung Refrigerator Model RF26XAEBP Parts I will be here if you have questions, Thanks Sea Breeze
Jul 03, 2012 | Samsung RF26XAEBP
The fan is making a weird noise and when i open the door it stops but when it stops in makes a loud noise and the temp on the fridge wont stay down but the freezer is fine what is the problem
You have a twin cooling unit and the refrigerator fan is getting clogged up with ice possibly due to a defrost problem. You will need to remove the back wall panel of the refrigerator to access the evaporator fan motor and clean it out of the excess ice buildup. Check the defrost circuits and also the defrost drain to make sure it's clear.
Jul 20, 2011 | Samsung RS2630SH Side by Side Refrigerator
LG french door fridge - makes hideous noise - loose bearings? - whenever fan is running, which is several times an hour. Any idea what is causing it? Husband tried to grease the fan. It's really...
A broken fan blade can cause a noisy motor. or a buildup of ice can cause some noise. If thes aren't the case you will need to have the fan motor replaced.
Jan 04, 2011 | LG LRFD25850 French Door Refrigerator
Electrolux commercial fridge with bad noise now ice
easy replace it bearings have failed
Jun 02, 2010 | Refrigerators
Freezer fan is making noise so I took all food out used a hair dryier to try and melt some of the frost/ice behind the back panel. Before this all the food had frost on them. This is the second time I did...
you need to have someone check the defrost circuit. if the unit does not defrost properly , ice will accumulate on the back panel where the evaporator is, blocking the evaporator fans completely, and the circulation fan will eventually stop working because the ice buildup contacts the blades all the fan motor, and eventually the refrigerator compartment will start to get warmer and warmer because there is no circulation of cool air.
Mar 16, 2010 | LG LFX25960ST Stainless Steel French Door...
Had a loud noise coming from the freezer, water all over inside.
Hi, what sounds to me what happened, is the evaporator fan motor prop (blade) has hit a patch of ice that had built up and temporally caused the unit to stop and warm up. I have seen this happen on commercial units to where after the unit has went through its defrost cycle as you will have on this system, not all of the ice was melted away and the fans stopped due to ice build up. When the defrost cycle happened, this caused the water at the top back and after the fan began to run again all is freezing and back to normal. When a evaporator fan stops during the regular cooling cycle, the freezer section will start to over freeze very badly due to no air flow across this coil. I would keep an eye on it as you may be loosing this motor. It is called the evaporator fan motor, 120 volts/a/c, 60hz. small sealed, single phase. R.P.M.s and H. P. should be noted on a data plate on the unit maybe inside, you will need to look. In any case, keep a close eye on it for now if it is working correctly. You may not have this problem again. If it does happen you can contact me and we can go into more detail to solve the problem.
Sincerely,
Shastalaker7
Mar 10, 2010 | Samsung RS2630SH Side by Side Refrigerator
GE GDS18LBR Bottom Freezer Refrigerator Logo
2,126 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
