There is no "reset" button on the ds light but you could flip the power switch and flip tp turn it off and again to turn it back on (incase you didn't already know that)
Hi there, whilst in game go to the options menu then go to "Save". Press the R, X and B buttons at the same time which unlocks the delete option. If you delete the save you will start the game all over again.
With your console powered off insert the Action Replay DS
Hold down buttons A+B
Turn your console on
With A+B still held down, as soon as you see the Action Replay DS license screen press and hold down buttons START+SELECT so that you now have 4 buttons held down
Hold all 4 buttons down for around 10 seconds until the Action Replay DS loads to it`s home screen
If Action Replay DS doesn’t hold on the license screen for around 10 seconds when you do this, you may need to turn off and try again
have your ds dropped and if it is it must have been damaged the inside part (i don't really know the name) but it might been cracked, i've never solved this hard problem before. --------------------------------------------------------------------------------------------------------------------------THE END--------------
well to wash the pets you select the pet out of the big blue thing then you press the foward button on your ds when the arrow goes there you click A then you can wash your pet
There is no reset button, however there is a way to reset it.
Take out the games in the DS Lite
Then take out the battery and leave it for about 120 seconds
Then put in the battery
It should have reset itself, if not take the battery out and leave it for a little longer and then put in the battery.
Now it should reset itself and then put in the name and other info.
I hope this helps
