Question about Philips GoGear HDD075/17 MP3 Player
Phllips gogearSA3025/37 where can i find a philips battery
  • 8,596 Answers
There are no proprietary batteries for the Philips SA3025 - if it is not working, and it was purchased within 1 year, call Philips and see if you can get an in-warranty repalcement. If you are out of warranty, the spec sheet and manual on this model lists the generic type of battery that you will need:
Battery capacity: 310mAh
•Battery Type: LI-Polymer
Posted on Mar 25, 2009
Orange light blinks and tv wont turn on
First, check the wires properly, adjust them or try at another power point.
Rerview your User Guide for settings properly.
If this does not solve the problem, I suggest to contact this definitively establishing technical service, including technical service Phllips recommended when warnings occur leds.
Hope helped.
Nov 26, 2009 | Philips 42PFP5332D 42 in. Plasma...
How do i remove the centre console on a ford focus c-max
Remove the twi phllips screws under the cup holders. Remove the cover in back of the arm rest. Remove the two phillips screw. Remove the cap covering the last screw in the back of the console. Remove last phillips screw. pull up parking brake,remove console. Good luck.
Nov 12, 2009 | 2000 Ford Focus
I dont know how to change my case on my phone sony ericsson w810i i need to know how to change it ?
you need a t6 screwdriver and a phllips screwdriver. 6 screws holds the handset together. hope this helps...
g
Oct 25, 2009 | Sony Ericsson W910i Cellular Phone
Phllips Projection tv no pcture
hello check the glass fuse inside the tv good luck
shaun
Jul 29, 2009 | Toshiba 53H71 53 in. Rear Projection...
I have installed windows xp onto my phllips freevents nb5800 laptop, everything seems to have installed properly appart from the sound card driver, could this only be availiable with vista as this was the...
check for the update of your sound card driver. xp has the support for all drivers. their is a compatible one. download and install it. your sound card works then
goodluck
Jul 25, 2008 | Computers & Internet
Is the screen gone?
if the unit is out of warranty try reseating the LVDS cable. that is the cable that joins the panel to the scaler board inside the set. becareful when removing the cable, don't pull from the wires but remove from the connector. reseat the connector a few times. if this does not solve your problem then replace the scaler board better known as the SSB
Feb 03, 2008 | Philips 32PF9966 32 in. HD-Ready LCD...
Philips GoGear HDD075/17 MP3 Player Logo
61 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
