Question about Napoleon 36" Zero Clearance Top/Rear Vent Natural Gas Fireplace with Black Door
Thermopile replacement for Napolean Fireplace
Does anyone know how to replace a thermopile in a Napolean Fireplace Model gds 60?
  • fireplaceman May 11, 2010
    Is this the exact model number? If so how old is the unit? And lastly, how do you know it's the thermopile that's giving you an issue?
I have a regency E33 gas fireplace. after 6-7mins with fire on, fire and pilot both go out. any suggestions?
thermopile should show 600mv clean thermopile . clean pilot so its strong and blue . see how that goes, may need new thermopile .
Oct 20, 2017 | Heating & Cooling
Lennox Gas Fireplace. How do you replace a thermopile on a Lennox Gas Fireplace, Model # MPD4035CNM?
First take a picture of the logs so they go back in the same position . re move logs to gain access to pilot block thermopile is the lager probe of the two it comes undone by undoing the hex nut below it and removing the two wires on the gas valve its easy but fiddly.
Nov 11, 2016 | Heating & Cooling
Where can we find thermocouple for adru richelieu fireplace?
I apologize I do not recognize the brand but since a month has passed without an answer I can tell you we have often had to find a replacement without being able to go through a manufacturer. For a fireplace we would need you to upload pictures of the control valve because it is very common for a fireplace valve to have a thermopile and not a thermocouple. If the valve has a battery pack or a electrical plug then the chances are that you have a thermocouple but if there is not an external power source the flame is probably heating a thermopile in order to generate the power needed for the controls.
If that is the case you would need to physically bring it to a shop to be tested for the proper amount of power needed because thermopiles can have a tremendous range.
Oct 23, 2014 | World Marketing 24-3508P Thermocouple Vent...
Ambient remote control 5884 won't turn fireplace on and off
  • Make sure your valve is in the "on" position and not "pilot".
  • Install fresh batteries in both remote and receiver (remotes are finicky about good batteries.
  • Ensure the switch on your receiver is in the "remote" position.
  • Follow manual to re-sync handheld to receiver if necessary.
  • A burner not lighting could also be the fault of the appliance (bad thermopile). Check this too, and replace if needed.
  • Replace remote if necessary: Universal Fireplace Remotes
Dec 28, 2012 | Ambient Tech. Rcmt Manual Fireplace Remote...
How to check a thermopile generator
Log in to the Honeywell internet site and ask the question using yur model generator! It is probably supposed to produce a spark that may be regulated.
Dec 24, 2012 | Honeywell Q313a 750 Millivolt Thermopile /...
Napolean fireplace burner wont light
If your pilot is running fine, but your burner will not light:
  • You may have a bad thermopile.
  • There may be blockage in the burner orifice.
You can test the voltage of the thermopile per your owner's manual (replace if necessary).
You can clean out the burner orifice with some compressed air.
Nov 15, 2012 | Pool & Spa
Have winrich perfecta ventfree lp model 6380. Very hard to start. Ignition switch never worked correctly. Pilot and ods showing corrosion. Doesn't stay lit very long. Can I replace the pilot/ods a
First clean out pilot light with can of air , or blow down it with a tude.
Then brush electrode clean with a clean paint brush ,chech to see if electrode is in the right postion to light the gas not too far away and the spark is strong , Clean thermopile head if fitted, then check thermocuople /thermopile connections are tight . see if this helps .
Oct 28, 2012 | Heating & Cooling
I have a desa fireplace and it is not working. it is model T36N and would like to know where i can purchase parts to fix it. I live in las vegas nevada zip 89141 thank you
Most parts in gas fireplaces are universal, the valve/thermopile and thermocouple are generic parts and should be found at your local gas fitting supply stores.
If you describe what you tried to fix the fireplace thus far I could give you better advice to which part you need to replace in order to get it running.
Jan 11, 2010 | Desa International Heating & Cooling
I installed a Napoleon Gas fireplace model BGD33NG . I get pilot lite but no flame . Can you tell me what I'm doing wrong ?
Make sure the pilot is turned to the ON position, otherwise you might have a broken thermopile which will need to be replaced as it controls the burner.
Dec 30, 2009 | Napoleon 36" Zero Clearance Top/Rear Vent...
Fireplace doesn't turn on
check the pilot injector might be blocked
Dec 08, 2008 | Desa International Heating & Cooling
Napoleon 36" Zero Clearance Top/Rear Vent Natural Gas Fireplace with Black Door Logo
982 people viewed this question
Top Napoleon Pool & Spa Experts
John Rodgers
John Rodgers
Craig Butler
Craig Butler
Paul Carew
Are you a Napoleon Pool and Spa Expert? Answer questions, earn points and help others
