I ave a Kenmore model 110.20924990 S/N CK2220475 Mother tells me that it smells like something burning. I removed the cover and run the machine I notied the start switch in the motor is slipping, not spinning at the same speed as the motor rotating very slow and then I see smoke and fluid coming from the start capacitor. I turned off the machine. I replaced the motor and capacitor. I now get a burning smell when the machine goes into the drain mode or the spin mode. please help... Chris
  • 2 more comments
  • ferrari52000 Mar 07, 2009
    The burning smell is coming from the motor.
    Chris
    The smell is coming from the motor
    There is no spark when I plugged the motor in. I don't see any burned wiires or loos connections on the motor. I did remove the pump and look at the connections.
    Still looking for help
    I stil need help
  • Washing Mach... Master
  • 19,396 Answers
Check the motor control unit, that is the electronic board sealed in plastic for protection located near to the motor, ensure also that the smell is not coming from a rubber gasket.
If the smell is coming from the motor assembly, then better replacing the motor assembly, even if the motor is still running.
Posted on Mar 09, 2009
    Genius:
  • 1,102 Answers
If you have nothing stuck anywhere in the machine and it smells like a wire burning then you may need the control switch on the panel replaced.
At times the wires behind the panel become worn and or loose
causing a burning smell.
Posted on Mar 08, 2009
  • 728 Answers
Make sure there is enough oil or grease in the motor so that certain parts will not rub together and make that burning smell. Also check and see if there are any gears in the motor and if so, make sure they do not have any broken teeth on it because that could cause the motor to skip and make a burning smell during it trying to drain or spin. And make sure they are the right sizes and are not out of there positions, or else that could cause a burning smell also.
    Guru:
  • 462 Answers
Chris you have a description of a pump that may have a sock or panty hose in it or just a string (my wife has washed a few old rugs and they came apart and stopped up the pump and caused me a few hours of messing with it) Remove the belt or loosen it, see if the motor then will run ok. If not proceed to way down the page under if it still dosnt work. If the motro will run ok here then the problem is most likely the pump. Try to spin the pump by hand both ways see if its tighter one way that the other. Some have a more clear case and you can see inside it to verify if there is someth9ing big in it or not. If it spins free both ways try the basket and make it go in the direction of the spin. SOmetimes there is a brake that has to release and it may have to be energized to allow it to spin. Usually the transmission works the agitate part turning 1 way =wash. the the trans locks up going th other way =spin out. The belt could have an idler to keep it tight too and it may not be turning freely (not on the older models though if its a top loader).
if it still dosnt work:
You may have very complicated wiring problem here. The motor you have is 1 reversible, 2 muti speeded, 3 I suspect trying to go in 2 directions at once.
OR did the new motor come with all the same terminals as your original? And did it come with a new switch?
If you can trace the wiring down to the speeds (usually 1 2 or 3 speeds depending on agitate speed IE Gentle, medium or normal, and hi agitate. The reversing sends you into spin out and causes the pump to pump out. If you find the main speed going into the motor and the one speed that reverses the motor and remove the other speed wires from the circuit, and retry it.
Posted on Mar 07, 2009
    Top Expert:
  • 79,865 Answers
The windings of the motor are covered with a special lacquer insulating material, when the motor is running and drawing excessive current this coating gets very hot and starts to carbonize, I suspect something is causing excessive drag on the motor like the washer transmission, it may have defective bearings, this is what most likely burned out the orig parts and will do the same to the new ones if u don't correct the excessive drag on the motor.
    Sergeant:
    Novelist:
  • 277 Answers
click the links 1 and 2 and get the required information.
Motor helps for a no go problem...iIlistration1 -  iIlistration2
    Sergeant:
  • 320 Answers
As there is motor problem its confirmed.the motor needs replacement.do not on the machine till the motor gets repaired or replaced.to avoid the further damage.replavcing the motor is much advisable then reparing as reparing does not last longer.
    Brigadier General:
  • 8,619 Answers
Hi
It sounds like you may be having problems with the motor. It may be overheating or it could be as simple as a bad wire (judging from the burnt smell and the spark when you plugged it in).
The whole cabinet on kenmore washers come off so you can get a good look at the motor. Unscrew the screws on the console. They'll be on each end, either on the front or back depending on age. Rotated the console forward and up to lift it. Pop out the clips on each side of the top (under the console) with a screw driver. Disconnect the lid switch harness. Now you can tilt the cabinet forward and remove it.
Take a look at the wire harness on the motor to see if there are any bad wires.
Take the water pump off the front of the motor to see if anything is caught inside.
See if the motor turns freely. Please revert for any clarifications. Thanks Rylee
  • 154 Answers
There is some internal burning on the machine.
  • crysiszone Mar 07, 2009
    check out the control board of the machine.
    check that there is something stucks on machine motor. so, due to load motor smells like it burnt
Kenmore washing machine ultra fabric care model #92282800. Stop woking suddenly and smell like burned.
Thanks for choosing FixYa and welcome. You need to check the control panel. There is a good chance you can visually see some damage since you smelled the burnt smell. Check your belt(s) as well. Check to make sure the motor is running. Something inside may have burned up. If you have no power, check these below.
May 12, 2011 | Washing Machines
I have a Sears Kenmore washer (Model # 11092281100). I replaced the motor coupler, and I checked the alignment of everything before reconnecting the motor clamps/clips. It seemed like the motor shaft was...
It could be the grease. It could run without noise if it was not installed all the way. Here is a link for properly installing Motor coupler video Now if everything looks right it is probally just the grease.
Nov 09, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore series 90 washing machine clunking and burning smell
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.26902691
See the section on the Machine Base.
There are a number of balance springs and vibration pads that help keep the tub from vibrating and going out of balance.
It's possible that one or more of these is broken, loose or damaged.
Following is a description of how to remove the cabinet to get access to them.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=135
Also see the Whirlpool Service Manual for their direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
For the vibration, I'd check the springs and vibration pads.
While you have the cabinet off, I'd pull the pump and motor and check the Motor Coupler. This could be the cause of the "burning smell"
Nov 22, 2009 | Kenmore 24902 Top Load Washer
Kenmore Electric Dryer Series 80 Model
Disconnect the dryer from your vent completely,. pull dryer out 3 ft. from wall and test to see if the smell continues, You have to test for a few minutes to clear out any burning lint from vent restrictions. If the smell hoes away then you know you have venting problems. Also check on the grate that covers the element( the part you look through when you see the orange glow from the element) sometimes plastic or clothing burns onto this grate and needs to be cleaned off. I the smell remains, you will have to tear down the dryer to see if you can find the cause of the smell.
Sep 21, 2009 | Kenmore 62802 Electric Dryer
Kenmore washer Model 110 suddenly poured oil from the bottom--what happened? It lost oil and my mom continued to use it. We now smell something like burning rubber. The barrel still spins but could the...
You lost a seal in the gear-box, needs a new one, burning rubber smell is from the belt slipping and the gear-box being low on oil giving too much resistance on the belt.
Don't run it until you solve the oil leak and refill with oil
Aug 22, 2009 | Washing Machines
The Kenmore Model 70 Smells Electrical Burning,
Hi..
You need to unplug the washer. Locate the source of the odor then read the instructions in the related section.You need to open the back cover, Check the parts which is spark, and become faulty, there is a short circuit, that become loose contact.
Regards
PCmania
Jul 15, 2009 | Kenmore 22422 Top Load Washer
Kenmore Elite washer, model # 22942101 Spin cycle not working. The water drained out but the drum does not spin. It smells as if something burned out.
If the water drained out, then it sounds like the motor is still good.
I would check if the brake were failed in some manner since you smelled something, and if that is OK, then it's probably a failed gearbox.
Jan 27, 2009 | Kenmore 24032\24036 Top Load Washer
Smells hot and doesn't work
Unfortunatley, with laser printers it is not unusual to notice a burning smell. Sometimes that could mean that there is paper jammed inside your fuser assembly and it is being burned when power is applied. However, there could be a number of reasons why the machine won't function. My recommendation is to have a certified technician look at the machine for you. It may cost you $45-$75 to have someone check it out for and tell you what the cost would be to fix.
Jan 03, 2009 | Brother IntelliFax-4100e Fax
Kenmore Washer Won't Drain
yes, check the drain, could be clogged, or check the water pump assembly as well, the clothe could be stuck in the impeller.
the burning smell could be coming from a separate electric water pump and it can not turn that is why it is burning already.
tnx 4 using fixya,
drcool
Oct 07, 2008 | Washing Machines
Smells like it is burning up when I use it!
You should unplug the machine, then remove the plate that covers the beater bar. Remove all debris from the beater bar, (strings, hair, etc.) and insure the belt is in proper position. If you have run it very long out of proper position, it may require replacement. Next before you put it back together remove any debis that may have collected in the intake behind the bar. You can also lubricate the bar with machine oil or WD-40.
Mar 09, 2008 | Kenmore 23313 Whispertone Bagged Canister...
Washing Machines Logo
Top Washing Machines Experts
