Question about DISH Network DVR-625 DTV Receiver / 100-Hours Video Recorder
Dish Network DVR VIP722 freezing up during playback
My dvr vip722 freezes, & locks up. i thought I fixed the problem by unplugging it. It worked for 4 days, during which time I refused the new dvr they had sent me. I searched for an external hard drive, found one, & WAS in the process of transfering my programs to the hard drive. (already ordered a ner dvr, should be here Monday). My problem is, I can't get the dvr to work at all, after last night, & everyone tells me that all is lost. I am a HUGE boxing fan, studying to be a judge, & only have 3 out of 49 fights on the hard drive. Can anyone help, I am ready to pull my hair out! Please, I am begging, I just want to transfer my fights to the external hard drive! Thanks!
  • Jane Scholl Mar 07, 2009
    I need the dvhave hooked up!r to work, so I can transfer my fights to the external hard drive I
    I don't understand that?
  • 6,784 Answers
Due to the serious meltdown of this device, the hard drive may be damaged and it may be impossible to retrieve anything from it. unfortunately, all is lost. without the use of the on board programming, the hard drive in this failed unit it useless and inoperable.
Posted on Mar 07, 2009
  • 583 Answers
As you are getting your new dvd just connect that new dvd and remove the old dvd.and it should be ok.and connect the wires properly and also connect the exrternal hard drive to the unit.and then select the files and folders to transfer .as the dvr is new it will properly transfer all your data to new external hard drive.it will done.nothing to worry.but yes your old dvr which ias gone will not work.
  • 479 Answers
Take out the HDD and connect it to any system and u can transfer the data from it.
  • Gyanendra Kumar Mar 07, 2009
    Your receiver is having a SATA drive which is compatible with computer systems as well.
    S open your box and attach that SATA drive to your computer and when u will turn the computer on you will find another drive in my computer from there u can transfer your data to external or any drive as your receiver is dead so there is no use of any external usb drive with that.
    President:
  • 1,952 Answers
You more than likely are 100 percent correct.This is often the cause of the issue you had. The good news is that once the new receiver is in place you normally will not have any other issues as this receiver model is very reliable. One thing to consider is that Dish has some HD receivers available e.g. 222 etc that are non DVR but can act as a DVR unit with an external hard drive connected to the USB expansion port. This option gives you greater control of your recordings and eliminates the monthly DVR fee. There is a one time fee of 39.99 to make the USB port active but within the normal 24 month contract period that customers are often under one will have recovered all of the cost a the hard drive and the port activation fee. Just fodder for thought.
  • 1 more comment
  • mohammed marika thambi
    mohammed marika thambi Mar 07, 2009
    what is the model of your DVR? some allow you to connect to a computer
    and grab the files, others require you to capture the saved video files
    to your computer - you should have a USB or Firewire port on your PVR
    SATA is a interface that allows you to connect a external hard drive to
    your DVR. If you have it on your computer as well it should be no
    problem except for the price of the hard drive.
    Sorry about my earlier post. Didn't realize you didn't have DVD on it...
    Its pretty simple. Get a capture card and get a set of RCA cables. Put
    the cables out from the box into the capture card and your set
    That SATA should allow you to do
    somehow. Usually that is a type of drive port. The question at that
    point would be how to access that port and whatever device you had to
    it.
    I'am not to familier with DVR's but I'd be willing to bet that it's
    more or less a hard drive recorder. So you should be able to access all
    those...... Dude I just checked the manual online for you. 160GB hard
    drive.
    First off..... there is a usb port on the front
    I suggest just trying to run a usb cable from that to your usb port on
    your computer and see if you can actually get into it that way. Then
    you should be able to pull up the hard drive in my computer just like a
    plug and play device. Then find the video files, which depends on how
    the DVR saves the file type as. Then copy those files to your computer
    and convert them to .avi or .mpeg or whatever you like using. Then burn
    it out. If the DVR records the files as something that your computer
    doesn't have a program that will read it, you'll have to find a program
    that will. Just check the file extension to find out or if it gives you
    the full icon for the file. Also you may have to make some adjustments
    on the box itself so your computer can access it.
    Ports maked 1394: if you box has this that is the number for a firewire
    port. Which is more or less the same as a USB just 2x faster. You will
    have to have a firewire port on your computer. (if you don't go get one
    there like $30 for a decent one, it'll be worth it in the future if you
    do this often). This should let you do the same as the USB port. Find
    the files, plug and play style device, copy to your computer.
    According to the manual the SATA drive is as stated above pretty much
    for a external hard drive that supports SATA. You'd have to go into
    your box and send record shows to that HD then take the HD to your
    computer and copy files from it to your computer.
    Try that!!!! i'd try the above to first if you have those options and
    if your not sure whats what on the box check the manual for a
    description of the inputs and outputs.
    __________________
    you can update the firmware on your box as well as any digital TV. I
    just did mine for my tv a week ago. Thats really what the USB is used
    for in most of those cases or to hook up a key board to it.
    Scholar:
  • 124 Answers
I had a Box just like that. I called Dish Network, and they had a Tech come out and switch the Box for no charge. I would call them again and get a new one. I know you most likely don;t want to do that, but the Box you have is no good. I hope this helps.
Feel free to ask any questions.
Thank you for using Fix Ya!
Don't forget to rate the overall satisfaction of this solution.
    Sergeant:
  • 320 Answers
Nothing will be lost just take the hdd to the local repair shop .they have data recovery software and get you hdd to connected that software and every thing will be recovered in any case.also take it in coming days not very late.as it is seen the hard disk not used for much days the data gets corrupted in the hdd and will be very hard to recover.
    Sergeant:
    Novelist:
  • 277 Answers
Its a circuit short internmally that getting overheated and causing it to freeze.chgeckj the sense capacitor and ic number i 65 small.and i567 big on the main board of the unit.they need replacement.
  • 154 Answers
Try to reset your player and check again.
  • crysiszone Mar 07, 2009
     Change the cables on the back of the receiver. Move the cable on the in home distibution to the 3-4 out and vice versa. At TV1 change the TV itself to the channel TV2 was modulated to and see if you can watch tv error free for awahile.Do likewise on the TV2 location by going to CH3-4. Let them stay like this for an hour or so to replicate the issue. If the problem does not appear it would seem as though the receiver is fine. It also would appear that the cabling is fine also. If you are not having to reset the modulator than I would expect that the receiver is good once again. I would send a tech to your home and have him break the system down to the most basic configuration and progress from there. I personally suspect that there is a piece of hardware that is heating up and shorrting out such as a barrel, wallplate, or even an improperly prepared connector.
    plese add some comment for more help.
    thanks
For the past couple of days, every show our DVR has recorded freezes a couple of minutes into playing it and the DVR reboots itself. This always occurs at the exact same time on that show. We don't have...
Hi, Mary with Dish Network Customer Service. Since the DVR is the only thing having the freezing issue, it sounds like it maybe a hard drive issue. I would recommend resetting the receiver. Unplug it from the power supply for 10 seconds and then let the receiver reboot itself. If you are still having this issue, I would recommend calling Dish Network and we will need to replace the receiver. Hard Drive issues do not resolve themselves and only get worse over time. Please let me know if I can be of further assistance.
Jan 13, 2011 | DISH Network ViP722 DTV Receiver /...
I have a DISH Network ViP722 DTV Receiver / 350-Hours Video.... Whenever I have my brightness setting below 40 on my LG TV, my Dish DVR will no longer respond to its Dish issued remote control. If I turn...
Hello! Daniel Busa with Dish Network. That would be a case of remote interference. You'll need a model 6.3 or 6.4 remote. You can set it to a uhf frequency instead of an ir that will correct the issue.
Aug 26, 2010 | DISH Network ViP722 DTV Receiver /...
I have an LG 42LG70 42 in. HDTV LCD TV. Whenever I have my brightness setting below 40, my Dish DVR will no longer respond to its Dish issued remote control. If I turn the brightness anywhere above 40,...
Tries unplug,replug the DVR box an hour later.The box should reset itself and update it software.The box should work normal again.Not,call Dish Network to replaced the box,have intermittent problems.
0521 code on dvr
Hello! Daniel Busa with Dish Network I saw your post and would like to apologize for the inconvenience. If you've gotten that error message it may be a sign your hard drive is down. If you reset the reciever by unplugging it and it keeps happening you will need a replacement.
Jul 21, 2010 | DISH Network ViP722 DTV Receiver /...
DVR LOST ALL RECORDINGS (EVEN PROTECTED RECORDINGS), ALL HISTORY OF SEARCHES. TALKED WITH DISH & THEY HAVE NEVER HEARD OF SUCH A THING. RECORDED SEVERAL MORE PROGRAMS & IT DELETED THOSE AS...
Hello, Daniel Busa with Dish Network. If this is still persisting you may need a replacement give us a call or you can contact us on twitter and we will get it resolved.
Jun 28, 2010 | DISH Network ViP722 DTV Receiver /...
Recently whenever we try to watch a recorded item on our dvr or try and rewind a live segment the show acts very jumpy and then eventually freezes. Nothing we do can change the frozen picture changing...
Guest,
Are you still having problems with your DVR receiver? Try unplugging the receiver for 10 seconds and plugging back in. The receiver will reboot and acquire satellite signal. If this doesn't fix the problem there may be an issue with the receiver. I hope this helps.
Ray Calo
DISH Network
Jun 10, 2010 | DISH Network ViP722 DTV Receiver /...
Dish 622 freezes up
You have a hard drive failure and will need the unit replaced. Thanks for using Fix Ya.
Jan 29, 2010 | DISH Network ViP622 DVR DTV Receiver /...
Program sony remote to operate dish vip722
The Sony RM-YD029 Remote control will work with the Dish Network VIP722 DVR HD Satellite Receiver, but the Dish Network VIP722's Primary remote address must be set to 1.
The procedure below will allow Sony RM-YD029 remote control to operate Dish VIP722.
Using the Dish Network Remote Control -
1. Press menu 2 times to get to system info page
2. In the system info page the primary remote address is in a white box (bubble) followed by a Green TV (1)symbol that says IR and indicates you the channel your remote control one is configured. The Sony RM-YD029 will work when this primary remote address number (in the white box) is set to 1.
If the Primary Remote Address of your VIP722 Remote control 1 is not set to channel 1, here is how to change it:
1. While displaying the system info page, press and hold the SAT button on your dish network remote until all other modes are flashing, about 3 seconds.
2. then press the '1' button on the numeric pad of your dish remote
3. then press the '#' button on the numeric pad of the dish remote
4. then press the 'record' button (red dot button - stores setting)
5. At this point you should see a number 1 in front of the primary remote address on the dish system info page
Ensure you enter the corresponding IR code into your Sony remote control per the instructions in the manual or Sony's web site. My 722 works with Sony IR code - 01775.
Sep 08, 2009 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
Dish network dvr vip722 freezes
I am sorry to hear of your issue and I wish I was able to bear better news but I am afraid that once there is an issue with the internal hard drive there is no way to retrieve the information off of it using common methods such as using on screen prompts or at least that is what technical support has stated.I am sure you already know that Dish charges a one time fee of 39.99 to make the expansion USB port active so that what you are asking is possible. If you have not paid the 39.99 yet I would call customer service to see that if you do so and the receiver is downgraded to a non dvr unit would they transfer that fee. I expect they would not and my suggesting that is that on a non dvr unit I know you can access the information on the hard drive if the receiver is malfunctioning. I know you are probably very frustrated to say the least right now but if you are interested is discovering other possible set up configurations Dish offers a Sling box which is integrated with your internet connection and is very fascinating with the possibilities it provides. Thanks for using Fix Ya and if I can be of further assistance please let me know.
Mar 07, 2009 | DISH Network DVR-625 DTV Receiver /...
Need Dish DVR ViP722 remote code.
If you are looking to have the Dish remote operate your TV, just do a random search for your tv. First, hold down the tv button on the dish remote until all the rest of the light up. Next press the tvpower button on the dish remote. Next, press the channel up button (this is the up arrow button) until the set turns off. When it does turn off, press the # key at the bottom right of the remote. The tv button will light and flash twice. That's it. Your done. Hope this helps.
Feb 20, 2009 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
DISH Network DVR-625 DTV Receiver / 100-Hours Video Recorder Logo
307 people viewed this question
Top DISH Network Televison & Video Experts
S. Gontko
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
