Question about Acer Aspire One N270 Notebook
Computer is very slow - Acer Aspire One N270 Notebook
  • Jay Glendenning
    Jay Glendenning May 11, 2010
    Have you checked for viruses, spyware, malware, etc?
  • 741 Answers
4 things you can do to speed up your computer.
1) Empty Recycle Bin
2)Run disk cleanup under accessories>system tools
3)Run Defgrag also under accessories>system tools
4)if that does not help then adding more RAM will be the next step. Good luck, let me know if you have any questions.
Rate with 4 diamonds.
Posted on Mar 07, 2009
Tip
Computer Running Slow?  The guaranteed way to speed up your computer!
<span>Computer running slow? Nothing is more frustrating than a slow computer. Speed up your computer now with our proven computer optimization service. As a leading Microsoft&reg; Partner in the online computer repair industry we have access to the latest tools and resources from Microsoft&reg; and others to </span><span>speed up computer</span><span>, </span><span>computer running slow</span><span>, <a href="http://www.mycomputerexpert.com/speed-slow-computer.php">fix slow computer</a> and Netbooks running Windows 7, Vista and XP.</span>
on Jun 26, 2011 | Computers & Internet
Tip
If your system is too slow for you
Are you still looking for a proper computer repair solution for your slow computer? Well, to repair your slow computer, you can follow these easy steps and make it run faster again in just minutes. You do not need to purchase a new computer to replace the slow one.
Another computer repair solution is to disable unnecessary Windows services and remove programs on the startup. How long does your computer take to enter the whole system? My PC boost up time is less than 30 seconds normally. By typing msconfg in the start-run menu, you can get to the right place to disable unnecessary Windows services and startup programs. This computer repair method can speed your slow computer up.
To repair computer slow problem, you also can update the device drivers regularly. There would be some conflicts among those outdated device drivers and that is the reason why you often get blue screen of death. If you want to repair and avoid system errors such as blue screen of death, system boost failure, don't be lazy to update device drivers in your computer.
on Feb 20, 2010 | Computers & Internet
Slow computer
Improper computer maintenance may result in slow PC. To fix computer running slow you are required to clean junk and windows errors from your PC using a System Utilities program.
To download a reliable System Utilities, go to famous website download.cnet and search there Reginout. Which I personally use and recommend the friends.
After downloading run all of its tools one by one except Internet Optimizer, to clean all the junk and error files from your computer.
Jan 01, 2014 | Computers & Internet
My computer starts at the blue start up screen and it takes it about 10 minutes to load the log in screen. It wasn't doing this at first. I have done multiple system restores, but it hasn't helped....
hi Jamiekom.
Slow Running Computer Fix. Use MSCONFIG to improve computer's speed at startup. You can disable certain programs that auto-start at startup and spend less time waiting for your computer to fully boot. Simple tip to improve your computer's performance.
Why is computer so slow to startup? My Windows computer boots up slow. A slow Microsoft Windows boot up can be caused by a number of different issues. The following document contains various suggestions and tips that can help improve the overall speed of your computer's startup.
Why does it take so long to boot up my computer?3. Upgrade your hardware. A new computer is naturally going to start up faster because it has faster hardware, and a clean operating system. ... As we said above, computer startup is slow because you're moving information from a slow hard drive to faster RAM
Computer running slow at startup Check out this Quick Tip
computer slow on start up Google Search
Dec 07, 2017 | HEWLETT-PACKARD Black 20" TouchSmart...
My laptop is running slow? when im in the internet my computer runs slow
Available RAM is very important for speeding up your laptop while surfing. Check your available RAM by:
  1. Starting the Task Manager (Right click on taskbar and select it)
  2. Select the Performance Tab
  3. Compare the Physical Memory vs Commit Charge numbers.
For example, my fast computer has 3600 megs of total physical memory compared to a commit charge of 1200 megs. Meanwhile, my older, slow computer has only 650 megs of total physical memory with a commit charge of 1400 megs. This means the slow computer is always making 'pretend' memory from hard drive space, and that is why it is so slow. This is most likely the case with your computer as well.
I hope that helps.
Jul 14, 2010 | Toshiba Satellite A135-S2276 Notebook
Runs slow on video downloads
Hello Sir,
downloading speed depends on internet connection not on PC specification.
If your transfer is low then downloading will also be low.
Take note that source from which you are downloading also must have reliable connection.
cheers,
Mike
May 08, 2010 | Gateway 832GM PC Desktop
My hp pavilion a800n's fan won't turn off
It is possible that your computer is simply overheating causing it to slow down. There are a few ways to check this. Enter the BIOS and go to the hardware monitor, what temperatures does the computer read both for the CPU and the Motherboard? Another option is to install and run a program called HWmonitor that can be found here. Report back when you can.
Mar 18, 2009 | HP Pavilion a800n (PP163AA) PC Desktop
Problem in scanned images uploading
If you have 50 units of computer working the same time such as uploading big files, the problem for the rest among your 7 computers that work fast is between the hub connectors on the network system. You can check this connectors by replacing those slow ones to that faster computers.
Then if your faster computers slow down and the replaced connectors from slow working bacomes fast then the problem is in your hub distribution connectors.
If you had trace to that problem, then replace the whole unit of hub connectors.
Aug 08, 2008 | Microsoft Windows XP Professional With...
Acer Aspire One N270 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
