Click-wheel and select button not responding
I have an older (4-5 years?) 60GB iPod Classic. The click-wheel and select button went dead. There is absolutely no response to anything. Can it be fixed or is it time to get a new one?
  • 28 Answers
We had a similar problem. went to all kinds of extremes with no success. unfortunately these things are not that durable, and it's probably time for a new one. getting a slicone sleeve will protect your new one. make sure the sleeve is the kind with a flexible clear cover over the click wheel and screen. keeps dust and moisture out. dust and moisture are not your friends.
Posted on Mar 07, 2009
How to reset my 60gb classic
Step 1: Hook iPod up to computer using the included cable that came with the iPod.
Step 2: Open iTunes and on the left side, your iPod should show up.
Step 3: Click on the iPod and your right screen should change to show your iPod and its current general information.
Step 4: Scroll down the right screen to find the "Restore" option. Click on that, and it will give you a warning telling you that it will erase everything on the iPod. Click Yes.
Step 5: Wait, and iTunes will prompt you in a few minutes with a welcome screen for your reset iPod.
Feb 28, 2011 | Apple iPod MP3 Player
Dont know how to change the time and date on my classic Apple ipod
Hello Skipjak309,
To set date and time options:
1. Choose Settings > Date & Time.
2. Choose Date. Use the Click Wheel to change the selected value. Press the Center button to move to the next value.
3. Choose Time. Use the Click Wheel to change the selected value. Press the Center button to move to the next value.
4. To specify the time zone, choose Time Zone and use the Click Wheel to select a city in
another time zone.
Oct 25, 2009 | Apple iPod classic MP3 Player
80 GB Ipod Classic shows locked and click wheel not working
Slide the switch on the top of the ipod to where it shows white instead of orange. If it is already off hold, then you may have a broken hold switch.
Aug 10, 2009 | Apple iPod MA446LL/A MP3 Player
CLICK WHEEL IS NOT RESPONDING
Hi!
Please try resetting the ipod by pressing the center and play button on your ipod until it displays apple logo. Also try restoring it to factory settings by seeing this link from apple---
Restoring apple ipod
Please rate this solution if you find this solution helpful.
Thanks
Rylee
Feb 08, 2009 | Apple iPod classic MP3 Player
DIFFERENCE BETWEEN IPOD CLASSIC & IPOD TOUCH
Ipod classic has at least 2 to 3 times the capacity of ipod touch.
Ipod touch is touch screen and has max 16gb capacity
whilst ipod classic only has click wheel.and is like 60gb or something.
ipod touch is the iphone but without the phone bit,
May 30, 2008 | Audio Players & Recorders
Restoring my Ipod!
Try resetting the iPod, this usually works.
As follows:
How to reset iPod To reset an iPod with a Click Wheel, including:iPod nano (3rd generation) iPod classic iPod (5th generation) iPod nano (2nd generation)iPod nano iPod with color display (iPod photo) iPod (Click Wheel) iPod mini iPod mini (2nd generation)
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds.
You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
To reset iPod, iPod (scroll wheel), iPod (touch wheel), and iPod (dock connector)Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step.
If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button.When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time is preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on.
Hope this helps
check out my blog
http://www.pchelpforanyone.blogspot.com
Mar 13, 2008 | Audio Players & Recorders
Sad face icon
To reset an iPod with a Click Wheel, including: ipodnano3.jpg ipodclassic.jpg icon_ipod_5g.gif ipodnano2.jpg ipodnano.jpg ipodphoto.gif ipodg4.gif ipodmini.gif
  • iPod nano (3rd generation)
  • iPod classic
  • iPod (5th generation)
  • iPod nano (2nd generation)
  • iPod nano
  • iPod with color display (iPod photo)
  • iPod (Click Wheel)
  • iPod mini
  • iPod mini (2nd generation)
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Dec 06, 2007 | Apple iPod MA446LL/A MP3 Player
Won't start.
  • iPod classic
  • iPod nano
  • iPod mini
Dec 04, 2007 | Apple iPod MA446LL/A MP3 Player
Ipod 30g
  • iPod classic
  • iPod nano
  • iPod mini
Nov 30, 2007 | Apple iPod MA446LL/A MP3 Player
Apple ipod
  • iPod classic
  • iPod nano
  • iPod mini
Nov 22, 2007 | Apple iPod MA446LL/A MP3 Player
537 people viewed this question
 Grubhead
Grubhead
