Question about Sony Handycam DCR-DVD108 DVD Camcorder
My Sony DCR DVD 108 has no image at all with or with out disc says lens cap may be closed but it isnt flashing E:61:11 top right hand side of touch screen plays previously recorded dvd fine but thats it.
  • Anonymous Mar 17, 2009
    I have the same problem - none of your suggestions worked, any other ideas.
    Thanks
  • otinydancer Mar 25, 2009
    Help! I have the same problem, other than sending it back to Sony for minimum of $141.00??????
    Scholar:
  • 124 Answers
You may have lost your image sensor.
  1. Take lens cap off.
  2. Look in lens make sure there is nothing on or blocking lens.
  3. Find bright room & see if image comes up.
  4. Make sure your in video record mode.
  5. If you have eyepiece lens look to make sure it is off. {Most cams will not let you use both at same time.}
  6. Still no image try recording on blank disk then play back see if image is recording.
If that does not work MSG back.
Posted on Mar 08, 2009
How do you delete videos from your sony handycam DCR-DVD405
This Sony camcorder uses mini-DVDs to record and there are certain restrictions when DVD is used, it is not like videotape. For a DVD-R disc, you cannot delete video once it is recorded because this type of disc is a record once only. Depending on which other disc type you use and how it was initialized, you MAY be able to delete video. For a DVD+RW disc, or a DVD-RW disc initialized in VIDEO mode, you can delete the last scene IF you have not removed the disc and not recorded any new video. For a DVD-RW disc initialized in VR mode, you can delete anytime. And here is how:
Turn on camcorder and press PLAY. Select the video or still image tab that contains the data you want to delete. Touch EDIT. Touch DELETE. Select what you want deleted. The selected scene is marked with a checkmark. Press and hold the image on the LCD screen to confirm. Touch RETURN to go back to previous screen. Touch OK - YES. You cannot recover data once deleted. There is also a DELETE ALL to delete all video or images.
Mar 22, 2011 | Sony Handycam DCR-DVD405 Camcorder
Hello. My DCR-DVD105 has the plastic lens cap broken, where can I found a replacement? Many thanks.
If you are asking for following lens cap as shown in below image then it is available in Part Store.com for $13
Thanks.
Oct 23, 2010 | Sony Handycam DCR-DVD105 DVD Camcorder
E6100 flashing on lcd screen
The E61 is an internal error code shown when the motor is not moving. I will look up the specific details when I get to the shop and update this with the required fix.
Dan
Oct 15, 2009 | Sony DCR-HC18E Mini DV Digital Camcorder
Sony DCR DVD108 not finalizing disc, lost data
I noticed that too with my "VR" (and NOT "Video") formatted disks. I don't think you can finalize the VR ones. Instead you have to use the Sony Import tool to grab the videos. If you are like me you probably remember using the import tool with Video formatted disks BEFORE finalizing them and it takes forever to copy them. They must be finalized to view on other devices, copy using the import tool quicker, etc., but VR formatted disks seem optimized for importing (and can be edited on the camcorder directly.
Sep 26, 2009 | Sony Handycam DCR-DVD108 DVD Camcorder
Need a owner manuals
DCR-DVD108 Click for a PDF version of your manual.
Thanks for using FixYa - a fixYa rating is appreciated for answering your FREE question.
May 25, 2009 | Sony Handycam DCR-DVD108 DVD Camcorder
Problem formatting mini dvd+rw disc
The full user manual is available at:
http://pdf.crse.com/manuals/2587623111.pdf
If the procedure fails, the disk may be corrupt but you might try formatting the disk on your pc.
Hope this helps. Please rate reply if it does thanks.
Feb 24, 2009 | Sony Handycam DCR-DVD92 DVD Camcorder
Sony handycam not recognizing memory stick
i think the 108 will only put pics on card- may not show card unless in camera mode-put in camera mode w/no disc and see if it shows how many avail pics-i don't think 108 records video on card
May 21, 2008 | Sony Handycam DCR-DVD108 DVD Camcorder
Sony DCR-DVD 108 disc won't play or record
Movies shot DV Camcorder forms mpg files when down loaded in computor and can not be converted to a CD. Problmes comes in conversion of mpg files to AVI, WMV, AVSEQ or MPEG2 etc.
Oct 29, 2007 | Sony Handycam DCR-DVD108 DVD Camcorder
Disc access error
check for smudges on the disc or on the laser optic sensor. cleaning liquids and cleaning Disc kits may be found in Camera and PC stores. if you need extensive services we can provide the service manualat a reasonable cost.
Dec 04, 2006 | Sony Handycam DCR-DVD92 DVD Camcorder
Sony Handycam  DCR-DVD108 DVD Camcorder Logo
388 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
