Question about LG 42LG50 42 in. LCD HDTV
DVD and LG50 remote controls interfere with each other.......
When using this older APEX Progressive Scan DVD player with the LG50 the DVD player remote interferes with the LG50 and the LG50 remote interferes with the APEX DVD player.
By "interfere" I mean that the DVD remote affects the TV and the LG50 remote affects the DVD player.
LG50 is about a week old.
  • Nash McQueen
    Nash McQueen May 11, 2010
    In what way does it affect each other?
shbuckler
  • 126 Answers
SOURCE: LG LCD TV Remote won't scan DVD
when you are teaching it, dont just hold down the transmitting remote button, instead press it on/off as fast as you can. This may help
Posted on Dec 25, 2008
SOURCE: I want my lg dvd remote control dvd player to also operate my tv
1. While holding down TV POWER button, press the
number buttons to select the manufacturer code
for your TV (see the table below).
2. Release TV POWER button.
Code Number
LG / GoldStar: 1 (Default), 2
Zenith: 1, 3, 4
Samsung: 6, 7
Sony: 8, 9
Hitachi: 4
Posted on Mar 05, 2009
  • 50 Answers
SOURCE: my tv will not shut off with the remote control
What type of tv was it and did you try to reprogram the remote?
Posted on Jul 10, 2009
dnewcombe1
  • 1564 Answers
SOURCE: remote control not working on brand new series 4 42 inch samsung
Make sure the remote is set to operate your tv and not a cable box or accesory. It's in the menu
Posted on Jul 24, 2009
roety
  • 585 Answers
SOURCE: interference problems
Hi my name is Roety,
I can help you with your issue ,
Please check any coaxial splitters, replace any defective splitters and install a signal amplifier to correct your issue.
If you have cable, the cable company will do this for free usually.
If I have helped you with your issue please click accept.
If you have more questions you can still respond
I will reply asap
Thanks
Posted on Oct 05, 2009
I can't turn the video ouput on.
It may be a variety of things:
1. Make sure your TV is set to the right input for the cable you are using (Composite, Component, HDMI, etc.).
2. More often then not progressive scan may be set. If your TV is not compatible with progressive scan then you must try the following to turn it off:
  • Look for an external button or remote control button that turns progressive scan on or off.
  • Remove any discs from inside the DVD tray with the power on, then hold down the Stop button on the front of the DVD player for about 10 seconds to see if this will reset the system to default (i.e. no progressive scan).
  • If this does not work, you will need to contact the manufacturer for the exact reset steps for restoring to default settings.
3. Lastly, the video processor could be malfunctioning. This would mean a technical repair.
Hope this was helpful. Thanks for visiting FixYa.com
Feb 15, 2011 | Apex Digital AD-2500 DVD Player
Trying to set up dish network remot to apex dvd player
dr172120,
I'm sorry you are having problems programming your DISH Network remote to your Apex DVD player. I looked through our remote codes but I don't show we have a code for an Apex DVD player. We do have remote codes for an Apex TV. You can run a power scan to see if you can find a code for the DVD player. I have provided the instructions to conduct the power scan below. If you have any other question, please post to this site.
Ray Calo
DISH Network - Executive Offices
Address To Other Equipment Using Power Scan
  • Remote: All Remotes (except Basic)
    1. With the desired equipment on, press and hold the correct Mode button until all mode button backlights illuminate, then release.
    2. Press and release the Power button. AUX Mode: Before pressing and releasing the Power button
      • Press 0 for a TV
      • Press 1 for a VCR/DVD
      • Press 2 for any other device.
      Then Press STAR (*)
    3. Press the Up button once a second while pointing the remote at the desired equipment. Note: If the code for the equipment comes up, the equipment will power off.
    4. Press the POUND (#) button. If the code entered is valid for the remote, the mode light flashes three times.
Jan 14, 2011 | DISH Network IR Remote Control
Only plays in black and white? what do we do?
Try a different cable, and a different TV if possible to help narrow down the problem.
it could be set for some other peculiar output mode; go into the configuration in the dvd player menu and verify that it is set for the type of TV you are using. normal composite video, (RCA), SVideo, Component Video, RGB, VGA, and Progressive Scan.
Dec 01, 2009 | Apex Digital AD-1110W DVD Player
DVD/VCR Combo - Zenith XBV342 Stuck In Progressive Scan
mi zenith xbv342 solo queda la pantalla azul y dice progressive scan mode como salgo de hay
Jun 14, 2009 | Zenith XBV442 DVD Player/VCR
Picture is split -- says P-SCAN. It's stuck
that means it is stuck on progressive scan.  If your tv is not able to handle progressive scan, you need to change it back or reset the player.
The DVD player may be set to Progressive Scan Mode. You will need to change it to Video Mode by using the remote control. Point the remote control directly at the DVD player, and then press the PSCAN button 2-3 times. If you are still encountering problems with the DVD player, reset the unit back to the default setting.
To Reset,
Make sure you do not have a disk in the tray. Using the DVD player remote control: 1) Press the “Setup” button. 2) On the “Down” arrow, press it three times. 3) On the “Right’ arrow, press it once. 4) On the “Down” arrow, press it three times. 5) On the “Right” arrow, press it once, then press “Enter”. 6) Press the Setup button. *The default setting will take affect as soon as you press the setup button (step 6).
Hope it helps..please rate!
Mar 07, 2009 | Coby DVD-224 DVD Player
Color in black and white
Possible solutions....
1) These Apex players can handle multiple sytems (NTSC/PAL)
Is it possible it is switched in the wrong mode?
Follow the jumpy picture and enter the menu to see if it is switched in the PAL mode (You may have to follow the user manual and try to look at the screen carefully while following to menu flow)..
Some APEX units have a button on the remote to switch the systems.
2) I have also seen some TV's that will not handle the progressive scan mode...
Try switching in the menus.
Mar 01, 2009 | Apex Digital AD-2500 DVD Player
Cannot remove progressive scan mode
I turned on the dvd player and pressed down on the play button and counted to 10, but before I got to 10 the progressive light went of and the image on my tv set came back on.
Mar 29, 2008 | Sanyo DVW-7100A DVD Player/VCR
press stop and keep hold of the stop button while you eject the dvd, it worked for me, i played around with it and found pressing stop and holding it while ejecting works
Sep 30, 2007 | Televison & Video
GOLDSTAR DVD/VIDEO PLAYER
Remove any discs from the unit. Make sure your tv is on the blue screen. It should say "Progressive Scan Mode"....After removing the disc(s) from the disc changer, close the changer, press and hold the stop button on the unit, not the remote, for 5 seconds or more and it will reset to normal playing mode. Progressive Scan is typically only for TVs that use Progressive Scan....most normal TVs do not use progressive scan mode. Hope this helps...It worked for me!!!!
Jan 20, 2007 | Goldstar DV7411N DVD Player
DVD/VCR combo player won't work
I had a similar problem and corrected it with a solution found on another site. Try hitting the I/P button on the remote which controls whether "Interlaced" or "Progressive Scan" is used to display the image on the TV. Mine worked when "Interlaced" was used. but no picture was displayed when "Progressive Scan" was used. The I/P button toggles between the two settings.
Dec 19, 2006 | Apex Digital ADV3800 DVD Player/VCR
LG 42LG50 42 in. LCD HDTV Logo
168 people viewed this question
Computer Repairing
Computer Repairing
