Question about Microsoft Zune JS8-00001 Digital Media Player
Connecting zun to car stereo
I have Ipod connection can I use that same cable w/converter?
  • 38 Answers
Short answer, nope. Completely different connections. You'll foul the Zune if you try it. Unless the iPod connection plugs into the headphone jack, but even then, I wouldn't.
Posted on Mar 08, 2009
I want to connect my ipod to the radio
According to Apple, over 90 percent of new cars retailed in the United States are equipped with iPod connectivity.
The iPod has become such a popular device, that many car stereos are now furnished with a 30-pin dock connector cable in order to link to the portable media player.
But this built-in compatibility is not essential for connecting your iPod to your car stereo. In fact, there are numerous options for integrating your iPod with your car.
Recently manufactured vehicles can support an iPod connection through an auxiliary input.
And FM transmitters can be used to stream your iPod's audio files through an FM frequency. iPods can even be connected to much older car stereos with the use of a tape adapter.
Connect an iPod to a Car Stereo Through the Auxiliary Input
Insert an extension cable with 3.5 mm stereo connectors on each end into the headphone output of your iPod. Insert the other end of the 3.5 mm stereo connector cable into your car stereo system's auxiliary input. Press the "Aux" button on your car stereo. Turn on your iPod and select media to play. The stereo will now stream audio from your iPod. b> Connect an iPod to a Car Stereo With an FM Transmitter Insert the FM transmitter into the 30-pin dock connector of your iPod. Turn on your iPod to activate the FM transmitter. Select the FM frequency you want your device to stream audio to on your car stereo. Turn on the car stereo and tune it to the same FM frequency as the FM transmitter attached to your iPod. The stereo will now stream audio from your iPod. b> Connect an iPod to a Car Stereo With a Cassette Adapter Plug the jack connector of the cassette adapter into the headphone output of your iPod. Insert the cassette into the car stereo. Turn on your iPod and select media to play. The stereo will now stream audio from your iPod.
http://www.apple.com/ipod/car-integration/ http://www.pcmag.com/article2/0,2817,1865467,00.asp
Feb 10, 2013 | Apple iPod Audio Players & Recorders
Tip
How do i connect my iPod to a Pioneer Car Stereo
<p>It is advisable to listen to your iPod through headphones while driving in the car. Not only is it dangerous to completely cancel the sounds of the road as it is often illegal in many cities across the country. There is an alternative, however. In just a few steps you can use your iPod to your car stereo speakers and use the car to listen to your music, podcasts and audiobooks. No brand car stereo makes it easier to connect these beautiful than Pioneer. <br /> <p><br /> <p>1. Connect one end of the mini-jack on your iPod headphone jack. Once done, set your iPod or on your dashboard or your car seat so that it will not tip over while driving. <br /> <p><br /> <p>2. Find your sound system's auxiliary input Pioneer. It is often located in front of the front panel stereo, but can also open the front or back of the unit completely. If the extra connector on the back of the stereo itself, then you remove the panel. When it comes to this, see the instructions that came with your sound system is provided for further guidance. <br /> <p><br /> <p>3. Connect the other end of the cable mini-jack for stereo aux port. This will allow your iPod to the audio signal through the cable to the stereo and the stereo signal will pass to the car speakers. Most often, when something is plugged into the stereo aux jack will work in stereo. In some models a setting to select the additional connection. Whatever the case, now you can sit and enjoy your iPod for that long car ride. <br />
on Aug 09, 2011 | Apple iPod touch
Tip
How do I connect my iPod to a stereo Kenwood
<p>The superior audio quality thanks to the Kenwood stereo system is as good as any on the market. However, many of Kenwood audio receivers contain no iPod connection port. Even the business hubs of high-end entertainment that interface with the computer via USB cannot provide connectivity to an iPod. But that does not mean you cannot high-quality audio through your stereo Kenwood iPod. <br /> <p><br /> <p>1. Put your Kenwood stereo. Connect devices with the stereo turned on may lead to spikes in volume that can damage the speakers and even your ears. Turn up the stereo, so you can use the set of connectors on the back to see. <br /> <p><br /> <p>2. Connect the end of 3.5 mm 3.5 mm to RCA cable for the headset from your iPod. If you do not have a cable 3.5mm to RCA, you can buy one of the sound equipment stores or electronics stores like Radio Shack. <br /> <p><br /> <p>3. Connect the RCA end to your cable 3.5mm to RCA in an available port on the back of your Kenwood stereo. Put your Kenwood stereo, so you can access the buttons on the front. Turn the sound and select the channel of your iPod is connected. <br /> <p><br /> <p>4. Test the connection. Lower the volume on the Kenwood stereo and start a track playing on your iPod that you can recognize. Turn your volume until you play the iPod through the stereo to listen. If you hear no sound, check the "Monitor CD2/TAPE2" is active, and "Mute" is off <br />
How do I connect an ipod to my EPA900 ? also, I have a digital recorder with a USB connect. Is there a converter product that I can purchase that will allow me to connect this recorder to the system?
It is unlikely to find a compatible USB convertor for that digital recorder. If it has audio input you can probably use a similar cable to that for the IPOD described next. For the IPOD, get a 1/8 inch STEREO splitter cable that splits to 1/4 inch plugs or RCA plugs to connect to the PA system. Radio Shack will probably have a suitable one.
Jul 15, 2011 | Behringer Europort EPA900 Ultra compact...
IPod connexion to Alpine CVA 1003R
Yes it can work. but you can only use the audio feature of your iPod and not the video. Try to look for a cable with RCA (red/white) connector and a stereo jack on the other end. Connect the RCA cable where the cd changer connects and the stereo jack to your iPod.
^_^
Jun 07, 2010 | Alpine CVA-1003 Car Video Player
Tip
How to connect your iPod to a Car Stereo
Many car stereos have more new connections that MP3 playerslike the iPod can be connected and played through the stereo. For new carradio, you only need to connect the device and the MP3 player. If you have anold stereo, connect your iPod or connect a 3.5 mm stereo cable or FMtransmitter. Connect iPod directly to the stereo with a stereo cable willresult in better sound quality on the FM transmitter, which can be interruptedor static signal.
AUX
1. Find an AUX port. The AUX is a hole, only small to belocated on your car radio face. (The size is perfect for connecting headphonesor an auxiliary cable.)
2. Connect the 3.5 mm stereo cable into the hole in front ofyour car.
3. Connect the other end into the hole stereo AUX jack /headphone jack on top of your iPod.
4. Connect your iPod.
5. Activate the AUX input. This will be different for eachcar. You may need to field through your input options (e.g., FM, AM, CD, etc.)to access the AUX. Or you may need for your stereo pressing the Menu button.Then, the options for auxiliary input field to the AUX input as possible.
6. Find a song on your iPod and press the Play button whenthe auxiliary input is activated. If you do not hear anything, make sure thevolume on the iPod device and radio. If the iPod is playing your song, you'llsee the song progresses on the iPod screen.
FM Transmitter
1. Find an FM transmitter that is compatible with the iPod.So let your FM transmitter near your car radio.
2. Connect the iPod to the FM transmitter.
3. Tune the radio to your car radio has a frequency thatonly static, then the vote of the same frequency channel using the buttons +and -.
4. Connect your iPod. Then a number and press"Play." Make sure to turn all your volume on your iPod. You should beable to use his music. If not, find a new frequency until you find one thatworks with the iPod and the transmitter.
Tip
How to connect my iPod to an Amp & Subwoofers
<p>If your iPod to your amplifier or subwoofer that connects to a stereo receiver. This can be done through an additional cable. <br /> <p><br /> <p>1. Locate the auxiliary input on your stereo connected to your amplifier and subwoofer. These entry, small and round is labeled "AUX". Usually this entry is available in front of the stereo, but some devices can be found on the back. <br /> <p><br /> <p>2. Connect another cable to the auxiliary input of your stereo. <br /> <p><br /> <p>3. Connect the other end of extra cable to the headphones of his iPod. <br /> <p><br /> <p>4. Press the "AUX" input button on your stereo. Now when you play a song on your iPod you listen to them on your speaker system including subwoofer and amplifier. <br />
Can I connect an ipod to Onkyo tx-ds595?
I connect my iPod to my Onkyo using a stereo cable with mini-plug on one end and RCA L&R outs on the other. Just plug the RCA plugs into the AUX or TAPE IN on the Onkyo, and the stereo mini plug into the iPod and play as usual.
Aug 21, 2008 | Onkyo TX-DS595 Receiver
Jensen vm9412 and ipod classic
The newer generation iPods don't always work with the iPod connection kits in a lot of the car stereos. Some of the problem is due to the fact that the new generation iPods have been changed and the stereos were manufactured before the players were released so they are not compatible.
I bought my girlfriend a Pioneer car stereo with an iPod control cable, and it works fine with her Nano (not the new generation Nano) and it works with my iPod Photo 60 GB but it does not work with my iPhone 2G and I read that it is not compatible with the new Nanos or the Classics. Check with Jensen to see if the model you have is compatible with the Classic and see if there is a solution to the issue. It may not be compatible with the new video portion of the Classic firmware.
Cheers
Aug 20, 2008 | Jensen VM9510 Car DVD Player
Ipod touch connector
Hello serafineb,
The Alpine Full Speed cable for the iPod supports the following versions:
Fourth generation iPod
Fifth generation iPod
iPod photo
iPod mini
iPod nano
According to their website it does not appear that Alpine currently has a cable for the iPod touch. They do, however, make a "generic" cable for most MP3 players that connects directly to the earphone jack. Although this would not allow you to control the iPod from your stereo's head unit, you should be able to connect the iPod touch via this cable to play music through your car stereo.
More information about the "generic" cable can be found here.
Best Regards,
Ken
"Go Ahead. Use Us."
Jun 17, 2008 | Apple iPod touch
Microsoft Zune JS8-00001 Digital Media Player Logo
41 people viewed this question
Top Microsoft Audio Players & Recorders Experts
Mark Chaney
Mark Chaney
john h
Ap12
Ap12
Are you a Microsoft Audio Player and Recorder Expert? Answer questions, earn points and help others
