Question about Intel D865GLC Motherboard
Problems with my mother!
Hello everybody, my board d865glc was working all right until 2 days ago, it works with 2 OS`s in two different hard drives. The case is this i buy another board and when I moved the slave drive to the newest the old board didn`t recognize the secuence of boot, then i tell to my mother that recognize the drive automatically in the BIOS program, and then listen to this: "computer shows a black screen with any kind of response! I proceed to turn off manually, 5 minutes later in turn on the board just showed a green ligth inside with no fan speed, without video, nothing but a dead mother.
I will appreciate any kind of diagnosis so much, because technicians in my country don't take into account this kind of damage, and i`d like to recover my d865glc is almost my life.
PUT YOUR OLD COMP BACK THE WAY IT WAS .IF IT BOOTS AS ALWAYS,GO TO CONTROL PANEL.SELECT "SYSTEM",SELECT DEVICE MGR,SELECT DISK DRIVES.RIGHT CLICK ON YOUR SLAVE,SELECT UNINSTALL,FOLLOW INSTRUCTS.TURN OFF COMP AND REMOVE YOUR SLAVE.REBOOT.HOPE IT WORKS FOR YOU!
BUME
Posted on Jul 25, 2009
I had just purchased a Dell Inspiron N4010 laptop 2 months ago. It work well until few days ago. It hangs whilst at the screen 'starting windows'. After that it showed the message of 'check cable...
hello miss sally, hi, the operating system error may be caused by a faulty hard disk or hard disk connection cable, and the hanging thing is caused by a faulty memory module, so check then out first, swap a new memory module, and for your hard drive, take it out from your laptop and use a PC to test the drive (applicable only if your hard drive is sata.)
Nov 19, 2010 | Dell Computers & Internet
No sound .multimedia audio driver controller not installed. mother board D865GLC
Go to this page: Intel D865GLC Support
For drivers go down and click on "Search for all the latest drivers"
Narrow the list by selecting your Operating System and Drivers.
Thanks for using Fixya.
Apr 01, 2010 | Intel D865GLC Motherboard
When i login my computer I just get black screen try to reset or confiuate says primary and scondary drive 1 not found
HI Dear,
This is a hardware related issue. This might be due to following problems :
1. The data cable that connects your hard-drive to the mother board might have picked up some fault.
2. The mother board is not working.
3. The Hard-drive might be corrupted.
To see what exactly is causing this. Remove your Hard disk and try to on your friends computer. If its working fine then its the other two issues.
To check for the mother board and the data cable. remove the hard drive aand try t with another one. If the motherboard reads this hard drive then it is sure there is no issue with the motherboard and the data cable.
Now if trying above you see that HD is not detected. then replace the data cable and then try the HD on your computer. If it reads then there is no fault in *********** board. So replace the data cable and get a new one.
And if it does not reads then the motherboard have some issue. In that case i would suggest you to take your comp to nearest service station.
hope this works out. If it does not and if you have more queries that need to answered then please do write to us once again.
Have a nice day.
Nov 11, 2009 | Dell Dimension 2400 PC Desktop
Swapped hard drive into new casw and now it wont boot up
This is due to a hardware conflict.
The system drivers on the hard drive are for the old mother board and devices,You will have to reinstall OS while it is install on the new mother board,The computer cannot boot to a drive that is loaded to another system unless all the devices and drive are identical.
Please rate this a fixya
Feb 13, 2009 | EliteGroup 848P-A Motherboard
THE SCREEN SMEARS NAD SHUTS DOWN
Hi eakesj:
A number of things here should be checked.
First shut down and remove all cards, and power connections to all the drives such as cdroms, hard drives.
The power supply should also be looked at and tested for correct voltages on each wire. This can be done with a voltage meter.
Turn on the power and see if you can get the machine to start to the bios screen. (this will work if you have a video processor on board, if you have a video card, you will need it to use the monitor).
If that will not work, then you have more problems than you thought at the beginning.
If the mother board will not work at this point, then you have problems with either the mother board or the cpu processor. There is a possibility that there are problems with the memory modules.
So, if you have only one memory module, then I would remove the memory, carefully clean the contacts, (a clean pencil eraser can work, if you are careful, and do not press very hard) and then plug the memory back in and try again. Also if you have extra modules of the same type, try one for testing.
If you are still having the same problems, then the mother board or the cpu is the problem. At this point you should consider if you want to continue and repair or buy another mother board of the same size. If you buy another kind of mother board, remember you will have to re-install your operating system over the original one to get the complete setup and the bios to work correctly with it. Many times this can be done, but you risk losing data (you will lose all data in MY DOCUMENTS), and may have to completely re-install the OS. You may want to install the drive in another computer as a slave and back up any data you want to save before you proceed.
If you decide to continue with your original mother board, and still have problems, then the cpu or the mother board is suspect. To test the cpu, either test your board with another cpu which is compatible, or check the mother board with another mother board of the same exact model.
Hope you find the problem.
Feb 03, 2009 | eMachines T6534 PC Desktop
K9mm-v via k8m800 + vt8237r / amd athlon / running ubuntu 7.10 video problems
MY GUESS IS THE NORTH BRIDGE ON MOTHER BOARD IS BAD, REPLACE MOTHER BOARD.
Dec 16, 2008 | Computers & Internet
About Linux fedora and XP
Without knowing more about your system, the key rule is to install XP first, then Fedora.
If that doesn't work then it's time to put more partitions on your hard drive, and install the 2 operating systems on different partitions, again, remembering that Windows XP has to be the first installed.
Mar 31, 2008 | Intel D102GGC2 Motherboard
CD ROM DETECTION PROBLEM
LEAVE YOU hard drive on primary master port on your main board set as master or single drive ( IF YOU HAVE A STATA HARD DRIVE THEN DONT WORRY ABOUT THAT PART)
SET YOUR FIRST DRIVE AS MASTER
SET THE SECOND AS SECONDARY
use the jumber in the back of the drive to set them the propper setting is labeled on the drive it self
Connect them to the secondary port on your motherboard
so you should have
HARD DRIVE - MASTER OR SINGLE *jumper settiing* connected to the primary port on your main board
DRIVE 1 = MASTER *jumper settiing*
DRIVE 2 = SLAVE *jumpersetting*
connected to the secondary port on your mother board
IF YOU HAVE A SATA HARD DRIVE FORGET THE PARTS ABOUT HARD DRIVES ABOVE
i assumed you had a IDE hard drive
JUST USE THE SETTINGS FOR THE DRIVES and it should work :)
Dec 25, 2007 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
LaCie 500GB external HDD stoped working ?
It sounds like its an internal problem with the pcb board inside,which may not be an actual problem with the hdd it self but the mother board.my advice would be to change the board that links between the hdd and the usb cable.
Jul 19, 2007 | LaCie (300728U) 250 GB Hard Drive
Acer Travelmate 291LCi problem
how much free space left on hard drive? also check virtual memory settings and finally run scandisk and defrag on hard drive.
Jun 07, 2007 | Acer TravelMate 290 Notebook
Intel D865GLC Motherboard Logo
199 people viewed this question
Top Intel Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
