Our heating timeswitch Sunvic select 107XL has suddenly stopped working; not red lights on any setting; so no heat. But it has power, and let's me change the settings. I've tried re-set and gone back to 2 PU...and started again, but still no joy. It did happen once before and then magically re-started some hours later; but no idea what's going on/. Can you suggest? thanks
  • 154 Answers
Check out power plug and the power cable.
Posted on Mar 07, 2009
    Genius:
  • 1,550 Answers
You have a defective heating element .
need to replace it .
Mod.Hp980PT, red and top green light flash, no heat
This is a very common feature on these types of simple, high-volume, low-cost home appliances known as a safety fault. This fault will temporarily (or permanently) disable the appliance and happens for several reasons: (1) an over-temp (high heat) occurrence, (2) an over-power (power surge) occurrence, (3) an under-power (power outage or trickle power) occurrence, (4) an over-time occurrence (auto-off fails), (5) a short-circuit occurrence (exposed/crossed/frayed wires, etc.). Fortunately, it uses a digital "fuse" system and can be reset by the user. However, there is no universal reset process on SoftHeat products so you just have to play with it until you figure it out (customer service dept is no help). Mine is a Kaz SoftHeat HP980PT, with a red power indicator/power-off button and 4 green heat setting buttons. Mine faulted after a heavy storm caused multiple power outages and power surges in my neighborhood. The green light on the highest heat setting button was flashing on mine. Here's how I fixed it: (1) unplugged both ends of power cord and straightened out the cord, then plugged back in to the heating pad end. (2) While holding down the flashing light button, I plugged back in to the wall outlet. (3) While still holding down the flashing light button, pressed and held down the red power-off button, then while still holding down the red power button, I released the flashing light button, followed by releasing the power-off button. This stopped the flashing green light and caused the red power indicator light to stay on (steady-on). It works fine now. Note: Some models have an actual hard fuse in addition to the digital fault feature or possibly only a simple fuse (without the digital fault system). These fuses can the found at many retail stores and then very easily replaced. I hope this helps some of you!!!
Jan 27, 2014 | Softheat Heating Pad HP218 12 3P
Vibration coming from room thermostat
Transformer or relay going out.
Apr 10, 2013 | Heating & Cooling
I can't find an instruction manual for a Sunvic 307 xls online
This is simple to light. Turn the selector switch to pilot and push it down then push the striker button and watch it light. Hold for 30 seconds and then let off. Turn the selector switch to the desired comfort level and it will work.
Jan 24, 2011 | Desa International CBN30T Central Heating...
Ideal classic boiler no heating only hot water when heating is switched to on there is no sound from system but there is when water switched on. the rads upstairs were warming up but not downstairs now...
Hi it sounds like the pump is not working or diverter valve not working check to see if pump is working on ch mode as well as valve , pump could be stuck ,
Apr 12, 2010 | Heating & Cooling
My jenn-air JEC9530 is red light blinking.
you will need a new heating element in and if that dosent work you need a new one
May 30, 2009 | Jenn-Air JEC9530 Electric Cooktop
Creda Night Store Heater model 79154
The dial on the wall with 1-24 on it, with the red pins, is the timeswitch to turn the heater on for night-rate hours (when the electricity is cheapest). Hour 1 is 1am --> Hour 24 is midnight.
Set the red pins to turn the heater on from 11PM (23) to 7am (7). The 'on' symbol is normally a '1', with off being '0'. Otherwise, on can be symbolised with a staright line with circles on it, while off is like a little barrier-arm part up.
As for the knobs on the heater, one is for the amount of heat which goes in (how much the heater 'charges'), and the other is for how much it lets out.
Genrally in winter you set the input (nite-store, second knob) to full (6), but in spring or autumn you may reduce this as required.
The other knob (room temp) is for how much heat comes out of ther heater. If you work during the day, you will want to conserver the stored heat in the heater.
Turn the room temp knob down to about 3 when you leave for work, and wind back up to 6 when you get home. This will stop all the heat leaving the heater during the day (and maybe use less power to recharge at night).
Good luck with the time switch. Check your night-rate hours on your power account.
Apr 03, 2009 | Heating & Cooling
Dreamland electric blanket not heating
Yes we had an electric duvet from this company and it stopped working. Was replaced very kindly and no fuss by John Lewis and the same thing happened. (They had said they wouldn't replace again) . Spoke to the company but the woman was very rude. Said that if we lived in a rural area that was our tough luck basically. (A power surge or something). I don't think that's acceptable but we have given up on it now. I think there are 'known' issues with these products that are beingswept under the carpet.
Dec 17, 2008 | Heating & Cooling
Need help to change the programme settings
what kind of thermostat do you have
Nov 13, 2008 | Heating & Cooling
Heating & Cooling Logo
340 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
