Question about GE Profile WPRE6100G Top Load Washer
Leaking oil from the bottom of the machine
Started making a loud noise while agitating and is now leaking oil on the bottom
  • 86 Answers
Hi, Your problem is quite terminal, but easy to fix. You will need to replace the gearbox in the machine will cost around £150.00.
Posted on Mar 07, 2009
My washer is making a loud nosie when agitation starts
That is a normal sound when the transmission shifts from the last spin cycle to go into the agitate cycle. It should make a loud click sound that does not last longer than a second. There is nothing wrong with your washing machine.
Aug 07, 2015 | Kenmore 24032\24036 Top Load Washer
Loud noise during the spin cycle
Did you have an oil leak at the bottom of the washer? If yes, chances are your transmission oil leaked and your transmission needs changing or repairing.
Jan 15, 2014 | Kenmore Washing Machines
Loud noise when agitating
Did your machine leak out some oil on the bottom lately?
Jan 14, 2014 | Washing Machines
Whirlpool clean touch top loading washer suddenly makes very loud noise. Pump works but agitator and drum won't spin. Also seems like oil leaked out of motor. I'm thinking motor seized.
If you found oil underneath it, then you have a broken transmission case, or a bad seal. The electric motor does not contain oil. This should be something that yuo can confirm visually.
Dec 27, 2012 | Washing Machines
The agitator seems loose on my Maytag top loading machine.. model LAT9206BAE it started this after one of my kids overloaded the machine.. works fine but makes a loud clanging noise while washing.. almost...
Use a 1/4 inch nut driver to tighten the set screw to the agitator shaft. It is about 3 inches up from the bottom of the agitator on the side of the agitator.
Dec 28, 2010 | Maytag Washing Machines
Maytag top-loader making very load creaking noises from agitators
it could be you lelft something in the pocket of your pant that fell out an didnt drain out an si in the bottom of washer tub you have to remove the agitator an the basket if you dont know how call a techican ok are try an take a flashlight an see if you see any thing stuck in the bottom are the side of the basket ok
Oct 21, 2017 | Maytag Ensignia MAV4758AWW Top Load Washer
Loud while agitating
CHECK COUP-LER BETWEEN MOTOR AND GEARBOX.if coupler good,then gearbox bad.
Feb 12, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool washer agitates but makes a very loud noise
It sounds like the agitator teeth, that are plastic, are worn out. To check this, take the agitator cap off with a strong knife or flat-head screw driver, and check the circular teeth inside, to see if they are worn out. These plastic teeth are the agitator part of the washer, where as the spinning part is a metal set of teeth, at the bottom of the agitator. You see the metal teeth, when you take the agitator completely out. You will have to replace the agitator if the teeth are worn out.
Jan 11, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
KitchenAid washer Model#KAWS700jqsr fills but won't agitate
if it's making a loud buzzing noise while its suppose to be agitating or spinning its the motor coupling
Dec 20, 2008 | KitchenAid KAWS700L Top Load Washer
Loud noise while agitating in wash cycle
If you begin dissassembly from the tub down, you wil come to the transmission with the spindle sticking out of it. If you undo the bendable tabs all around the transmission it comes apart in two halves. Careful, its full of oil. The spindle has a plastic gear bolted to the bottom of it. It meshes with other gears in the tranny. It has sheered teath and is making the noise.
Sep 24, 2006 | Admiral AAV7000A
GE Profile WPRE6100G Top Load Washer Logo
263 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
