Question about Gateway M305CRV Notebook
Gateway 400vtx replaced its broken screen
Okay I had to replace the screen in my 400vtx everything went great put it back together boot it up and the screen shows up but it is not centered it looks like an old tv with a bad vhold but its stable just off any ideas?
    President:
  • 2,653 Answers
The resolution on the new lcd is probably different than you're previous model.
Right-click any free space on the deskptop and choose Properties.
Then just choose a resolution that works for you.
Let me know if you run into any problems.
Best of luck!
Posted on Mar 07, 2009
I have a Gateway M340UA Laptop and I can not get it to boot up
Hook a spare monitor to the video output usually on the back of the laptop, if picture okay! the LCD panel is defective, but if both screens show the same symptom, the Video Graphics Card is bad usually built into the motherboard. From the description the motherboard is the issue and I would replace the laptop for a new one.
Mar 26, 2012 | Acer Computers & Internet
Put in replacement spool cutting great as usual went edge the head with spool of line wont turn went back to normal position spool will not spin to cut motor runs spool head not engaging how can I fix
pull the head completely off and make sure that the shaft is not broken, if not then line it back into the head slot and put back together and test it out, Tim
May 29, 2011 | Black & Decker 14" Grass Hog Xp...
I have a gateway 400 VTX that powers on to the Bios screen then goes to another screen that says operating system not found. I have tried to load the os cd and it looks like its loadind and says windows is...
Sounds like u need to go into CMOS (System Setup) upon boot & make sure that the HARD DRIVE is the FIRST item in the BOOT ORDER and NOT your CD DRIVE. Also, make sure your Hard Drive shows up in the CMOS. If it does, then note what it says about the hard drive as it boots... If it is a bad hard drive, then nothing will install to it unless it is fixed or replaced.
Sep 22, 2010 | Gateway 400VTX-3501335 Notebook
I am looking for the manual for a Gateway laptop
safemanuals.com/user-guide...owner-manual/.../400VTX-_E
Nov 06, 2009 | Sewing Machines
Power windows, mirror, door locks inop. also have had ro replace every window motor in my 04 jeep
That happened to my jeep to so when i opened the door an looked where the wires were @ int hat black rubber thing i had a wire snapped i put em back together an everything worked great so jus check your wires it could be somethin that simple!
Jun 30, 2009 | 2004 Jeep Grand Cherokee
I have a 2004 Jeep Grand Cherokee limited edition and the drivers door control panel doesnt work at all(power windows, locks,mirrors) The controls on the other doors for the windows dont work either but...
I had same problem it is a ground wire broken in the harness rubber boot between dthe driver door. Peel back the rubber that protects wires and you will find broken ground wire(black) add a piece of wire solder and wrap with electrical tape put rubber boot back into door everything should work.
Mar 15, 2009 | 2004 Jeep Grand Cherokee
Gateway 400vtx - Reconnecting laptop monitor to laptop base
Find the location of the GPU. The connector should be located near it.
Mar 14, 2009 | Gateway 400VTX-3501335 Notebook
Gateway - No Beep - No Display
Try resetting the cmos..unplug the computer remove the battery for a minute or two then replace and plug back in. There is also a way to clear it by moving a jumper normally right near the battery it should say "clear" or "cl" or "cmos" there will be 3 pins normal mode is how it is now just move the jumper to short the unused pin and then put it back the way it was. As before unplug the computer first
Jun 30, 2008 | Gateway GT4016 Desktop PC
Computer not letting me open or close anything.
In some cases, the motherboard causes the screen to go blank and not load any program. Thats what happened to my HP Laptop. I called the company and explained them that nothing will load up and the screen went blank and they replaced the Motherboard.
So In tis case I think You need a new Motherboard.
Thank You and have a Great Day!!!!!
Jun 23, 2008 | Gateway 504GR PC Desktop
Gateway M305CRV Notebook Logo
121 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
