Question about EliteGroup P4VXASD2 Motherboard
P4vxasd2+ motherboard DDr memory
There is a row of pins by the memory modules that need to be shorted for the ddr memory to work, does anybody know what size jumper caps will fit them.. or which ones i need ?? none came with the mobo, and the ones that were used elswhere on the mobo are to big.
  • 1879 Answers
The motherboard will read 1GB DDR400 memory per slot only.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Posted on Jun 19, 2008
  • 6966 Answers
SOURCE: VIA P4M266 Motherboard
Appreciate the direct "Ask Me".
Unfortunately, this first generation P4 motherboards are a bit strict on the memories that they recognized. Your particular motherboard to my knowledge only accepts either PC100/133 SDRAMs or DDR200/266 which were made on or before 2002. This has nothing to do with frequency but with the recognition architecture of these older boards. Often newer memories would not be recognized or even if they are, the capacity would be halved.
Depending on the specs of your processor and replacement availability, you might be better off purchasing a newer motherboard.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 21, 2008
  • 18 Answers
SOURCE: p4vxasd2+ motherboard
This option should not need to be enabled through jumpers, the bios should automatically detect the ram type on the motherboard, make sure you are using compatible memory.
Posted on Mar 07, 2009
  • 16 Answers
SOURCE: Switching Between SDRAM & DDR Slots
All of those jumpers are either currently on or off. If you are switching RAM from SDRAM to DDR, you need to swap all of them. There appears to be 11 sets of jumpers. They are basically like 10 normal jumpers all stuck together as one piece. Move them all over, and switch your RAM, and you're set!
Posted on May 07, 2009
  • 14 Answers
SOURCE: problem for ecs m810d
it's between ddram n sdram connector.
Posted on May 14, 2009
What kind of RAM ( ie DDR , DDR1, DDR2 )is supported by d856gsa ;
Intel D865GSA has two 184-pin DDR SDRAM Dual Inline Memory Module (DIMM) sockets It Support for DDR-I 400, DDR 333, and DDR 266, Support for up to 2GB of system memory max CreativeTECH
Jan 05, 2011 | Intel D865GSA (BOXD865GSAL) Motherboard
Can i use a ddr2 400mhz ram on a GA8ipe1000 motherboard?
According to the Gigabyte website
that motherboard only has DDR slots (4 of them), so, no you cannot use DDR2 RAM modules.
If you do manage to make it fit, the pins won't line up because DDR can be 184pin or 200pin, and DDR2 can be 214-pin, 240-pin, 244-pin.
Since your memory slots or only DDR, there is no way that the DDR2 would make the connections that it would need to make in order for it to work.
I hope this helps! If not, please comment back and let us know!
Dec 30, 2010 | Gigabyte GA-8IPE1000-G (MBGA81PE1000G)...
I have a k9n4 sli motherboard with 4 places to put 2 gb strips of memory. i have 2 of them installed and working but cant get the other 2 to work what am i doing wrong?
A number of things could be happening.
Correct memory type?
The mainboard provides four 240-pin 1.8 volt non-ECC DDRII DIMMs.
DDRII modules are not interchangeable with DDR and the DDRII standard is not backwards compatible. You should always install DDRII memory modules in the DDRII DIMMs and DDR memory modules in the DDR DIMMs.
- In dual-channel mode, make sure that you install memory modules of the same type and density in different channel DDR DIMMs.
For more information on compatible components, please visit
Here's a link to a manual for your motherboard:
Sep 18, 2009 | MSI Computers & Internet
DDR 266 is DDR, not DDR 2 . The 266 is the frequency value in Mhz.
Try having the memory refunded or resell it on Ebay, so that you do not lose your money.
Here is supported memory, many older motherboards do not accept modules of over 512Mb each, ask to the seller:
PC2100 Memory DDR266 DDR-266 184-Pin Upgrade (266MHz) Memory Upgrades
Aug 22, 2009 | Computers & Internet
P4VXASD-R VIA Apollo P4X266-new 1G DDR gets 3 beeps
Well you said you used 256+128 and thats lower than 1gb. So try sticking in one of the stick and run it, see how it is. Then try the other, if both are working fine by themself then try cleaning your board with a nonscrathing cloth (or q-tip).
Lastly, just double check if your motherboard runs that kingston type, the pc2100.
As for your memory goes, os 2k can run up to 4gb of ram.
Jun 11, 2009 | EliteGroup ECS P4VXASD2 VIA P4X266A...
How to install additional 256 MB memory
You simply just push the memory into the DIMM socket on the motherboard. You need to use DDR SDRAM but should check what your I/O bus speed is set at. They make 4 different types of DDR SDRAM. They are DDR-200 (PC1600). DDR-266 (PC2100). DDR-333 (PC2700) and DDR-400 (PC3200). The following links should help you out:
Mar 20, 2009 | EliteGroup P4VMM2 Motherboard
D865GSA intel mother board supports DDR1 or DDR2 ram
Straight from intels web site...
Two 184-pin DDR SDRAM Dual Inline Memory Module (DIMM) sockets Support for DDR 400, DDR 333, and DDR 266 Support for up to 2GB of system memory
Mar 09, 2009 | Intel D865GSA (BOXD865GSAL) Motherboard
Mar 07, 2009 | EliteGroup P4VXASD2 Motherboard
ECS k7SOM+ 1.0 Motherboard, 1.3 AMD DURON
According to the manual the board supports 1 gig of either SDRAM or DDR .
Click on the link click on USA
On page 6, I believe is the following specs.
• Two 168-pin DIMM slots for SDRAM memory modules
• Two 184-pin DIMM slots for DDR memory modules
• Support SDRAM up to 100 MHz / DDR up to 200 MHz memory bus
• Maximum installed memory is 1GB
Note: You cannot use SDRAM and DDR simultaneously.
Mar 26, 2008 | Intel Motherboard
ECS M925 1.0 sdramm to ddr memory
The normal DDR Ram is supported..It doesn't support DDR2..
Nov 03, 2007 | PC Chips (M925G) Motherboard
EliteGroup P4VXASD2 Motherboard Logo
585 people viewed this question
Top EliteGroup Computers & Internet Experts
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
