Question about Frigidaire PLHS269ZD Stainless Steel Side by Side Refrigerator
The water dispenser is not working. It buzzes, but nothing comes out. The filter has needed replacing for a while. Will it eventually shut down until I replace the filter?
  • 163 Answers
I would change filter and see if it takes.if not then your water valve could be bad.if you hear it humming it should be calling for water.also check lines to water valve to see if their are any dry rotted spots,you will have to pull ref. out and take back cover off and you will see the valve.the tubing is what you want to check.have someone push for water and see if their is a leak,but try filter first.
Posted on Mar 07, 2009
Water filter gets water but does not feed ice maker or water outlet.
Good Morning Joseph,
I see that you are having trouble with water dispensing and ice being produced on your Frigidaire refrigerator, even after replacing water filter, model# ULTRAWF, twice. I would suggest to reset your refrigerator, by either unplugging it, or shutting the power off at the circuit breaker for at least 2-3 minutes. Once power is restored try to get water out of the dispenser. If you are still having trouble with the water dispenser, remove the water filter and replace it, making sure you hear two clicks and the filter is flush with the filter housing. If these suggestions do not work, I suggest contacting your local authorized technician for further assistance.
-Best Regards-
WP
Mar 26, 2014 | Frigidaire ULTRAWF Frigidaire PureSource...
Water dispenser on Frigidaire FRS6R5E refrigerator is not working but ice maker is working fine.when i open the filter area & press the water dispenser button water comes out from that area & when i put in...
At the back cover of the fridge you will find a double electric valve. The easy way to find valve is to follow water supply tube to your fridge
Unplug fridge and check with multimeter if one of the coils burned out and should be replaced. Make sure you close water shut off valve before removing solenoid. Good luck
Nov 14, 2013 | Frigidaire FRS6R5E Stainless Steel Side by...
Will not dispense water, but still makes ice
Sounds like either the water valve is bad or the line is plugged or frozen somewhere. To check the valve pull the water line off where the water feeds the reservoir have somebody try to dispense water you should have water coming out.If not try to dispense water again and listen for a slight buzzing noise if you hear the buzzing noise and you get no water the valve is bad.Always check the lines for freezing or restrictions before you replace the valve.
Jun 10, 2012 | Maytag MFD2561HE Stainless Steel Bottom...
Several days ago i replaced my water filter - i do not know if this is a coinsidence but now i hear a buzz every once in awhile like something charging - also, the water dispenser is not working and just...
There are two electric water valves which might buzz (especially if dry). One for the ice cubes. One for the water dispenser.
Since both are incorrect, they are probably not the problem. You are not getting water pressure.
It might not be the filter. Time to get wet and test. Could easily be the valve which feeds the fridge. It is probably a self piercing valve which makes a very small hole to get the water from the larger pipe. Close it all the way down (re-pierce the hole) and open it again.
Jun 03, 2011 | Maytag MFI2568AES Stainless Steel Bottom...
Hear icemaker solenoid buzz when water is to come on.....no water in tray???? Water dispenser does work though
Hello
Possible water is frozen in troth.Use a hair dryer to melt ice where water comes into ice tray.
Check your water filter also,possibly replace if necessary.
Apr 25, 2011 | Kenmore Refrigerators
Water and ice work intermittently. Is it freezing up? what position should the wire device be in to work? up,or down? Is that an on/off switch? It has had water,and made ice,but now there is no water...
The ice maker arm should be down for the ice maker to operate. How was the water dispenser flow rate when it did work? You may have a restricted filter, a frozen water reservoir (located behind crispers in fridge) or possibly a bad valve (at the back of the fridge where water connects) . You should also check your shut-off where your water connects, saddle valve type connections are prone to restrictions- try closing and opening it a few times.
Hope this helps!.
Jun 14, 2010 | Amana SXD524VW Side by Side Refrigerator
Kitchenaid model ksrs25ilss02 water filter
Are you saying water is dripping out the ice dispenser or the water dispenser, a water filter would have nothing to do with this, it only filters water, it does not pump water nor does it shut it off. If water
is dripping from the ice dispenser, it is because the rubber gasket
is bad on the flap that seals after ice is dispensed. If water is dripping
from the water dispenser, it is the shut off for the water, you can put a glass under it and push for water a few times,on and off and see if this makes it stop, if not you would need to have this replaced. Any questions please post back.
Mar 27, 2009 | LG LRSC26940ST 36" Side-by-Side...
Kenmore 57033 Water Dispenser Broken
I had a similar problem on a frigidaire side by side. I think the water line may be freezing. My solution was to remove the filter inside the refridgerator and drain it and reinstall. This causes the water to flow into the filter and eliminates any ice in the tubing. I have not had the problem in a while. While not a true fix, it may help narrow it down.
Later on, I eventually replaced the microswitch on the door dispenser for an intermittent dispenser problem.
Hope this helps.
Dec 28, 2008 | Kenmore 57029 Side by Side Refrigerator
Water does not come out of the refrigerator door, but the ice works
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
You said, When the water dispenser is pushed you can hear it try to work (a humming or pumping sound) but nothing comes out.
Below is a list of reasons that the water may not be working that are easily checked and remedyed by you! Is there a water shut off on your fridge?If so the dispensor will still make noise as if it is trying, even if it is locked!!!!!!!!!!!!!!!!!!!!!!!
1. When did you change the internal water filter last?
You can remove the water filter and still use the water dispenser to check if the filter may be the problem!If nothing changes reinsert the water filter.
2.Flushing the water system after replacing filter
Use a sturdy container to depress the water dispenser bar until
the water begins to flow. Flush the water system by dispensing
and discarding 2 to 3 gal. (8 to 12 L) of water. Cleaning the
system will take approximately 6 to 7 minutes and will help clear
air from the line. Additional flushing may be required in some
households.
NOTE: As air is cleared from the system, water may spurt out of
the dispenser.
3.***Read this:
The dispenser lock (on some models)
Your dispenser can be turned off for easy cleaning or to prevent
accidental dispensing by small children and pets. To turn off the
dispenser, press the LOCK button. The indicator will appear
above the LOCK button and the ice and water dispensers will not
work. To unlock the dispenser, press the UNLOCK button until
the indicator appears. Then continue to dispense ice or water as
usual.
NOTE:********** The lock feature does not shut off power to the product,
to the ice maker, or to the dispenser light. It simply deactivates
the dispenser levers.
4.The water dispenser will not operate properly
 Has the water system not filled? The water system needs
to be filled the first time it is used. Use a sturdy container to
depress the water dispenser bar until the water begins to
flow. Flush the water system by dispensing and discarding
2 to 3 gal. (8 to 12 L) of water. Cleaning the system will take
approximately 6 to 7 minutes and will help clear air from the
line. Additional flushing may be required in some households.
See the “Water and Ice Dispensers” section.
 Is the water shutoff valve not turned on or the water line
connected at the source? Make sure the water shutoff valve
is turned on and the water source is connected to the
refrigerator. See the “Water Supply Connection” section.
 Is the water shutoff valve clogged or incorrectly installed?
See the “Water Supply Connection” section. If clogging or
installation is not a problem, call for service or contact a
plumber.
 Is there a kink in the home water source line? If you find or
suspect a kink in the water line, call for service.
 Is there a water filter installed on the refrigerator? The
filter may be clogged or incorrectly installed. First, check the
filter installation instructions to ensure that the filter was
installed correctly and is not clogged. If installation or
clogging is not a problem, call for service.
Please remember to leave a rating before you go!
Thank you,
Huuum
Sep 29, 2008 | Whirlpool GD2SHGX Refrigerator
Open Questions:
Frigidaire PLHS269ZD Stainless Steel Side by Side Refrigerator Logo
83 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
