Question about Canon PowerShot A75 Digital Camera
Can't take a picture, black screen lit for short time than blacks out
  • Anonymous Mar 12, 2009
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    what is exact model of Canon camera and let me know , can you see live-view in LCD to take picture?
    Problem Solver:
  • 5 Answers
  • Wey Seal
    Wey Seal Mar 07, 2009
    I apologize for posting in the wrong thread but I can't figure out how to delete my message. Sorry..
After some time LCD going to black screen till again power on
Do you have a Video Picture for a short time and soon after the picture drops out and the screen goes black?
If so, when the LCD gets warm/hot a Diode shorts out and the screen can shut down. If that is the case, you may need to replace the screen. A technician needs to test the circuit board to see if a short is occurring in that hardware as this could be another fault.
Dec 25, 2013 | HP W1907 19-inch Widescreen Flat Panel LCD...
I posted a problem on how to remove panel but I solved it. Now as I mentioned the tv comes on goes green then black no picture just sound. I followed instructions on adjusting G screw but it doesnt work...
Its possible one of two thing have occurred, you have maladjusted the G screen control on the high voltage screens and focus assembly. Turn down (counterclockwise) all three of the screen drivers. Adjust each until a light appears in the each lens, red green and blue. Go slow or lines will appear if set too high. If all three lamps stay lit after this adjustment the look at your screen with color level down to zero using your remote and the picture menu. Adjust the three color drives to get a good black and white balance appearing on the screen. Now adjust the color level from the picture menu back up to normal range.
If you still get green diagonal lines after this adjustment then I would suspect that the green lens has a heater to cathode short in the tube.
Oct 12, 2017 | Televison & Video
Monitor does power up but no picture??
heck342, Your monitor may have the common "black screen of death" that will occur to ANY AND ALL cold cathode-fluorescent-lamp, back-lit, lcd monitors sometime during their lifetime. You will need to do a lot of reading in my fixya profile and those of "buddymc" , "budmrtn" and then you will understand what you will or will not do with your unit. I'll even bet you haven't been to YOUTUBE to view any DIY repair videos yet! Come back here for more info after you do a little research on the WEB, and can tell us tech's that you know the difference between a "black screen" and a "blank n black screen" monitor. Remember this, your CCFL back-lit lcd unit" design and principle of operation isn't any different than any other brand. Have you done the "flashlight test" that every CCFL back-lit lcd monitor owner should know how to perform and interpret the resulting info when black screen of death occurs? Bye for now. 12fixlouie
Jun 13, 2010 | X2Gen MG19MY 19" LCD Monitor
Image goes to black on Sharp flatscreen.
An LCD unit? Sounds like the backlight is failing. When it goes black next time, use a strong light next to the screen and look for a faint image on the screen....
If it is the backlight, its a service shop issue.
Mar 23, 2010 | Sharp 19 in. LCD HDTV
Gateway FPD1750 monitor's keep go black screen, no picture at al
tgordon60, If you know how those NEW "CURLIE-Q" energy efficient CFL light bulbs produce WHITE LIGHT, then you will know what makes an LCD display panel produce all the pretty colors and the WHITE BACKGROUND of the FIXYA web page!!! Only difference is that your "cold-cathode-fluorescent-lamps" are thinner and straight, and hung on rear of LCD glass panel and have a DC to AC electronic ballast called an "INVERTER" circuit to produce 600 to 1000vac to light them up. Get to my FIXYA profile and read my responses to other BLACK screen lcd owners to learn about all your options for repair. Follow any of the links to other web pages you find there. Your monitor not any different than ACER, DELL, VIEWSONIC, BENQ, SONY, AOC!!!!! 12fixlouie aka louie12fix
Dec 30, 2009 | Gateway Computers & Internet
Screen goes black
I think your battery might not be shorting out the lcd.
Leave the battery out and see if the lcd stays lit without going black, if it does it probably is the battery thats bad.
Try a known good working battery and see if the lcd stays lit. If the lcd stays lit then you know the battery was bad. if you get the same symptoms from another battery then you know its something with the motherboard at that point.
Jun 20, 2009 | Toshiba Satellite A45-S151 Notebook
The picture is intermittent, stays for a long time,
is the backlight staying lit even with the picture out? I had the same problem with my Aquos LC32DA5U my backlight was always on but no picture at all, just a lit up black screen, the problem is the LCD controller, I replaced that and it's perfect now.
Jan 09, 2009 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Takes photo but black screen
Are you sure the camera is set so the LCD (the screen) is lit? Check if the EVF (electronic viewfinder) is working. At the right of the screen, you will find two buttons on top of each other. Press the top one once or twice and see what it does.
Jun 02, 2008 | Fuji FinePix S7000 Digital Camera
Canon PowerShot A75 Digital Camera Logo
75 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
