Question about Fantom Vacums Lighting Canister Vacuum
My fantom vacuum stopped sucking stuff up
My Fantom vacuum sounds and looks like its working but it won't **** anything up, I used to have to empty the canister daily, but now its always empty. What should I do? I tried taking it apart a couple times but can't find the problem. Ive had it for a few years and its never done this before. It seems like there should be a simple solution i just don't know what it is, please help!
  • moneyjc May 22, 2009
    Doesn't **** and has a whistling sound. Can't find the blokage and have taken all the top screws off. Can't get to the motor.
  • 4 Answers
Most likely there is a clog, either in the 'knuckle' between the power head and the wand, or in the connection where the hose comes into the canister. In either case, unplug the hose and you should plainly see it.
Posted on Oct 25, 2009
I have a Fantom 500 DX and it seems that it doesn't pick up anything anymore. It looks like machine is working well, but it doen't pick up. I would like to take to the repair guy, but I don't know where to...
The type of bagless that has sharp turns in the hose and plastic parts are easy to become stopped up. You have to follow the path of the air flow to find the blockage.
Mar 29, 2011 | Fantom Vacums FM760 Twister 500DX Bagless...
My Fantom Fury vacuum does not pick up dirt. [The
You will have a blockage in the vacuum hose. Take it of and outside and push the garden hose from one end to the other.
May 01, 2010 | Fantom Vacums XT450K Upright Vacuum
Cant find one
Hello. You can call the Fantom company directly at 800-798-7395. Or use their website http://www.fantom.com/fantom/default.aspx
please rate my answer as very helpful. thanks. Joe800-800----
Apr 21, 2010 | Fantom Vacums Lighting Canister Vacuum
My Fantom Fury upright beater bar stopped working.
Hi at the bottom of the vac were the roller brush is there is a cover you would have to take that off and then you will see were the belt is located
Oct 07, 2009 | Fantom Vacums XT450K Upright Vacuum
Nedd power head wand for Fantom Model BPSRLC51
the best bet would be to look on ebay. the fantom line was discontinued
Jul 28, 2009 | Fantom Vacums Lighting Canister Vacuum
How do I change the fantom fury belt?
Fantom Vacuum site. Find the Model #-usually
on the back of this model,type it in and you can
read and look at diagram .Good Luck.
Belt ordered at Totalvac.com.
Dec 29, 2008 | Fantom Vacums XT450K Upright Vacuum
Fantom Cyclone XT Vacuum Cleaner
Here is the owners manual which goes over some troubleshooting problems.
http://www.fantom.com/fantom/manuals/Cyclone.pdf
At first I would think it was the thermal overload, which is covered in the manual. But I would guess that you have let it sit for 30 minutes to cool down and tried again and the vacuum still didn't work.
I would think you may have one of four problems.
1. Your thermal overload was tripped and is stuck and will need replaced.
2. You have a clog in your vacuum lines or the brush roller is froze, which keeps causing the thermal overload to trip.
3. Your power cord has a short, which would need replaced.
4. Your power switch is bad, which would need replaced.
Out of these 4 possible problems I would say the only one you could fix on your own would be problem #2. Make sure the vacuum is unplugged and take the brush roller off and clean it, make sure it moves free. Check your vacuum lines to make sure you do not have a clog, other wise the motor does not get air flow to cool it down causing the thermal overload to trip. As for problem 1, 3, and 4 I would suggest taking it to a repair shop.
Hope this helps, post back.
Jul 11, 2008 | Fantom Vacums XT450K Upright Vacuum
Vacuum won"t turn on with the switch
could be the cord, switch or the motor
check them with a ohm meter
Jun 28, 2008 | Fantom Vacums FM760 Twister 500DX Bagless...
Fantom vacuum
sounds like a partly clogged filter
Mar 10, 2008 | Fantom Vacums FM741 Twister Bagless...
Fantom Vacums Lighting Canister Vacuum Logo
422 people viewed this question
Top Fantom Vacums Vacuums Experts
Richard Agent
Charles T Nevin
Charles T Nevin
Are you a Fantom Vacums Vacuum Expert? Answer questions, earn points and help others
