Question about Pentair Mastertemp Heater
Pump problems? Pump starts up and everything works for approximately one minute. The the pump stays on, but there is no pressure to the spa jets, the skimmer is not working, the cleaner is not working. The filter was just cleaned. We have a Pentair 4000 series filtration system, and a master temp 400 heater, the pump is a 2hp Pentair.
    Problem Solver:
  • 10 Answers
Their can be a number of things.. Is the pump priming. Hopefully it did prime. what usually happens after running for awhile, with no cool water coming in. The water inside the pump basket starts to heat up, then the tubing turns to brownish on the input side of pump and exhaust side. (you could have air leaking in throught the input side, which could result in the pump never priming) Or if it is priming and no pressure (can mean your empellar is clogged up)
Posted on Mar 11, 2009
Heat pump does not work
can some one help me i have a spa quip sq1500 and my heater light will stay on for say 5 or 10 min but soon as i put jets on again the heater will go off and stay off untill i turn off jets again ????
Jun 08, 2013 | Pool & Spa
Why doesnt my leisure bay spa get hot
This could be caused by a couple things. In order for your spa to heat your pump must be working, your heater and heater sensors must be good. If your heater is bad usually the breaker will trip. If that's not happening read below...
Does water shoot out of the jets when you press the jets 1 button? If not then you have a bad pump or the pump is air locked. The heater can't turn on if the pump does not push water through the heater. You'll know if this is happening because you'll get an error code on your control pad.
So your jets are working but no heat. This is the most common problem. Your spa has a sensor that tells the spa if it's ok to turn the heater on. That sensor is prone to failure so everything can be fine but the heater will not turn on. Get the model number off your spa pack and click the link below. Call and tell them you need a pressure switch and give them the model number. Install the new switch and you're back in action.
Mar 10, 2013 | Pool & Spa
;turn coleman hottub on - flashes "pr" for a few min. then it shuts off
If your Coleman has Balboa electronics 'PR' is to notify you that it is in priming mode.
It could also be your pressure switch. On most tubs the pressure is mounted on the heater. If this switch is not reading correctly it could shut the spa down to prevent heater overheating.
Sep 18, 2012 | Pool & Spa
QCA Spa Contol Panel Issues
Flow issues can be frustrating, check each of the following
1. Low GPM.
2. Low Water Level.
3. Blocked Suction Fitting.
4. Blocked Skimmer.
5. Dirty Filter. (Try run system w/o Filter)
6. Too Many Closed Jets.
7. Closed Slice Valve.
8. Heat Related Pump Not Running.
9. Heat Related Pump Not Primed.
10. Malfunctioning Impeller.
11. Incorrect Heat Related Pump.
12. Circ System Misconfigured.
13. Sensor Malfunction.
If none of those help try this. There is a link to s Balboa site for service tech diagnostic help. There are step by step instructions for diagnostics.
Jan 23, 2012 | Pool & Spa
Heater wont stay on. HELP!
Have the Hayward guys come out and prove to you that it is indeed low pressure and then get an estimate for repair costs. Assuming there is no warranty in effect, you might want to locate the heater manufacturer for guidance. They may have a website that may be of help.
Mar 20, 2017 | Hayward Comfort Zone Electric Spa Heater...
2 hp Swimming Pool - Jet / Well Pump Motor / Century B124: Water pump from swimming pool to filter lost it's ...
May 17, 2010 | AO Smith 2 hp Swimming Pool - Jet / Well...
Intermittent jet problem on Spa form hot tub - low speed jet works, when button is pressed for high speed, it starts runs for a few minutes then switches back to low speed, then back to high speed again - ...
Hmm, that's an odd one. It could be either a fault with the PCB or the pump.
The first thing to check is the voltage to the twin speed pump. If that's ok the motor is probably the cause of the fault.
As always, with anything electrical you need to be very careful with what you're doing and if you're unsure seek professional help.
Apr 14, 2010 | Pool & Spa
No jet flow hot springs highlife 1990
you might have an air lock, when you first start filling the spa, start the water running in the skimmer first. that should force air out of the pump and should pick up prime right away. if not, you may have a valve problem.
Mar 30, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
The pump works for a minute with the jets, then sops, then starts
You need to check the door on the skimmer and the water leavel on the pool. If the door is stuck or the leavel is low the pump will **** the skimmer dry and cause the problem your describing. Try these first and good luck.
Mar 17, 2009 | Sta Rite Sta - Rite 2hp Max - E Pro...
"high pump" (jets) shutoff
look at circit board see if it s burnt replace
Sep 30, 2008 | Waterway 1 Hp 115 Volt 2 Speed Side...
Pentair Mastertemp Heater Logo
296 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
