Question about Kenmore 18 in. 14432 / 14439 Built-in Dishwasher
Leak under door
I have a kenmore model 665 portable dishwasher and it is leaking at the bottom of the door in the center
  • Kenmore Master
  • 43,501 Answers
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
s7657usut
Posted on Sep 29, 2010
DISHWASHER LEAKING FROM CENTER OF BOTTOM OF DOOR
It's possible the bottom spray arm isn't rotating, and all thenwarermis being sprayed directly at the center of your door. Check this first. end, check the spray arm isn't damaged, as this can alter the spray pattern.
Jan 12, 2018 | Kenmore Dishwashers
Kenmore portable dishwasher leaking on corner and side of bottom right side (facing the dishwasher)Can this be fixed?
Without model # I cannot give you part # but most likely the door gasket needs replacement
Jan 17, 2017 | Kenmore Dishwashers
Kenmore dishwasher model 665-16629000 is leaking out the front. Checked the gasket, ok. Checked the door screws, took the door off, no cracks.
Before I took the machine out from under the cabinet, I would take a really strong light and some hand mirrors and try to see it leaking with the front cover off.
There is not a good chance this can be done.
Other than that, I would pull the machine out from the hole and test it where I could look underneath.
Should be either a drain hose of an inlet hose giving you trouble.
God bless your efforts.
Apr 15, 2016 | Kenmore Dishwashers
Dishwasher leaks during fill cycle
Just to be sure..take a look on that tube..it shoul be easy to remove the side pannels ..
Jul 01, 2013 | Kenmore 665
Kenmore Dishwasher Model 665 leaking from bottom of door during wash cycle. What do I look for and what can I do? Thanks
This can be due to the seal being dirty, missing, and or worn. Check for the seal and its condition
Dec 01, 2011 | Kenmore Dishwashers
My Kenmore under counter ultra wash dishwasher model 665.15825691 has started leaking at the lower corners of the door. The leaks seem to occur during the final rinse while the water is being heated. I...
Happened on my dish washer too. Remove lower rack, remove lower spray arm by removing the center plastic nut, check screws (torx) on outside edge of pump. Tighten these as necessary, mine were loose causing water to spray forward against the tub causing leakage.
Jun 27, 2009 | Kenmore Dishwashers
Kenmore portable dishwasher won't drain model # 665 17799990
Service person said is is not supposed to drain all the way. Something about it helps something not dry out.
Jun 24, 2009 | Kenmore Dishwashers
Dishwasher leaks during rinse cycle
it sounds like you need to adjust the door latch so that the top of the door will close tighter. when in the rinse cycle try pushing door at top to see if leak stops. if that doesn't let you know something then you got me. you have changed all that i can think of. Good luck
May 01, 2009 | Dishwashers
Kenmore 665-15962 Elite 8 yrs old
Won't start nor drain. what could the problem be? please help.
Apr 02, 2008 | Kenmore 15872 Dishwasher
Kenmore Ultra Wash 3 Leaking
Got a possible solution from a brilliant guy named Jake on another website and thought I would post it back here.
"Check the door vent on the inner side of the door, that should just snap out, I have seen those clog and start making more pressure inside to make it leak from the bottom. Jake"
I checked mine and got a nasty surprise. Who knew it could get so dirty.
Nov 01, 2007 | Kenmore 15129 Built-in Dishwasher
Kenmore 18 in. 14432 / 14439 Built-in Dishwasher Logo
817 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
