Question about Dell Vostro 1000 Notebook
Touchpad too sensitive
My Dell Vostro, Windows XP, touchpad moves itself, selects text and deletes emails when I've hardly touched it. I went to the touchpad settings screen and set it to act only when I click, and to minimum sensitivity, but that did not help. How can I fix it?
  • DougHndrx Mar 29, 2009
    I've got a very similar problem with my Vostro 1000. The touchpad worked great for well over a year, but the one day all of a sudden when I try to use the touchpad the cursor started jumping up and down and now it does that very frequently. It seems odd that the problem started up so quickly after being fine for so lone. I wonder if there's some software conflict. I've noticed that when booting the computer the touchpad works OK but then after booting is complete then the problem returns. Anybody got any ideas for fixing it that don't involve using an external mouse?
  • 741 Answers
I have a Dell Vostro also..awesome units..but that's another subject..unfortunately the area you changed is the only place to manipulate the touchpad. What I ended up doing was buying a USB wireless mouse. Now I can control it and it doesn't have a mind of its own..it just a little glitch in the computer make-up...sorry couldn't provide a better answer but this time there is no better answer. Good luck, let me know if you have any questions.
Rate with 4 diamonds before logging off.
Posted on Mar 07, 2009
Unlock laptop mouse
Examine your "Function"/"F" keys and look for a touchpad icon.
If you find one, hold the "Fn" key and press the touchpad icon button to unlock the touchpad.
Move on to Step 2 if your laptop doesn't support this feature.
Plug a USB mouse into an open port on your laptop. Click the Windows "Start" button.
Click "Control Panel" in Windows XP and double-click "Device Manager." Type "Device" in the search box in Vista and Windows 7 and click "Device Manager" from the results.
Click "+" next to "Mice and other pointing devices." Right-click the touchpad and select "Enable."
Your touchpad is now unlocked.
hope this helps
Oct 25, 2012 | Dell VOSTRO 3350
Cannot change touchpad sensitivity
you could try and down load the chipset for your system you should find it on the dell support page
May 06, 2012 | Dell Inspiron N7010 Laptop Core I3 2.4ghz,...
I have a new Dell Latitude E6410. While typing the cursor moves automatically causing inserting/erasing text. How do I fix this?
I'm assuming you are using some version of MS Windows.
I found this on the Dell support website;
  • Click Start.
  • In the Search box type main.cpl, click main.cpl in the list of programs.
  • In Windows XP click Run, type main.cpl in the box next to Open, click OK.
  • Click the Dell Touchpad tab.
  • Click on the picture of the touchpad.
  • Click Touchpad Settings.
  • Make sure there is a check in the box to the left of TouchCheck, move the slider bar all the way to the right (this can always be adjusted back).
  • Uncheck the box to the left of b>Tap to Click.
  • Move the slider in the Touch Sensitivity area to the right until it is 3/4 of the way toward Heavy Touch.
  • Click Apply, then click OK.
  • Click the X in the upper-right corner to close the Dell Touchpad Utility.
Hope this helps ;)
Feb 02, 2011 | Computers & Internet
How can I disable the mouse tapping function on my dell latitude e5400?
  1. Click Start.
  2. In the Search box type main.cpl, click main.cpl in the list of programs.
  3. Click the Dell Touchpad tab.
  4. Click on the picture of the touchpad.
  5. Click Touchpad Settings.
  6. Make sure there is a check in the box to the left of TouchCheck, move the slider bar all the way to the right (this can always be adjusted back).
  7. Uncheck the box to the left of Tap to Click.
  8. Move the slider in the Touch Sensitivity area to the right until it is 3/4 of the way toward Heavy Touch.
  9. Click Apply, then click OK.
  10. Click the X in the upper-right corner to close the Dell Touchpad Utility.
Sep 23, 2010 | Dell Latitude E5400 Laptop
I'll move the cursor to one spot on the desktop and it will move itself to another....windows 7
You mean, the cursor is erratic and moving all around here and there?
Decrease the Touchpad Sensitivity...
I see that your Laptop was shipped with Windows Vista and it seems you are using a Retail version of Windows 7. Specially, HP/Compaq Laptops is designed for Retail versions and you can face some device/driver functionality issues. But, you can still try the followings.
As per my knowledge, your Laptop has the Synaptics Toucpad.
To Change the Sensitivity of the Touchpad:
1. Right-click on the desktop and select Personalize > Mouse Pointers . The Mouse Properties settings window will open.
2. Select the Device Settings tab. Select the Synaptics TouchPad device and click Settings. In the Properties for Synaptics TouchPad window, expand the Sensitivity topic.
3. Select the PalmCheck option to adjust the sensitivity (decrease it) of the touchpad to avoid erratic cursor movement caused by accidental touching of the pad during normal typing.
If the Device Setting tab is missing.....
1. Click Start, in the Start search field type Msconfig and press enter.
"System Configuration Utility" box will pop up on the screen.
2. Click the Startup tab.
3. Search for "Syntpenh" entry and select the checkbox beside it.
5. Click OK. Restart the computer. Perform above step.
If you are still not able to perform the steps, update the driver from following link.
Synaptics TouchPad Driver: ftp://ftp.hp.com/pub/softpaq/sp44501-45000/sp44969.exe
Restart the Notebook and check for the problem. It should be resolved now.
Aug 22, 2010 | HP Pavilion dv9000z Notebook
I have Windows 7 on a Dell Inspiron lap top. My
Update the driver for your Keyboard/Touchpad. Got to Dell's Download Page. Enter your Service Tag, underneath your laptop, to get the correct list of drivers for the corresponding model of your laptop. Make sure to select the correct operating system. The touchpad drivers are located in the Input Device Drivers section, listed as Dell Touchpad / Pointing Stick, Alps - Driver or Synaptics - Driver.
After installation, go to the Windows 7 Start or Orb then in the
1. Click the Dell Touchpad tab.
2. Click Touchpad Settings.
3. Make sure there is a check in the box to the left of TouchCheck, move the slider bar all the way to the right (this can always be adjusted back).
4. Uncheck the box to the left of Tap to Click.
5. Move the slider in the Touch Sensitivity area to the right until it is 3/4 of the way toward Heavy Touch.
6. Click Apply, then click OK.
7. Click the X in the upper-right corner to close the Dell Touchpad Utility.
Please comment if the information provided has been helpful for the improvement of my support assistance. Thank you and regards.
Jul 16, 2010 | Dell Inspiron 1525 Notebook
I have a Dell laptop computer with Windows Vista Basic. The mouse on the screen has become very sensitive and sometimes it clicks on an item when it scrolls across the screen. How can I make it less...
  2. Alternately, click Start and type Mouse in the Search field, and select Mouse when it becomes available in the program list. The Mouse Properties settings window will open.
  3. Select the Device Settings tab. Select the Synaptics TouchPad device and click Settings . In the Properties for Synaptics TouchPad window, expand the Sensitivity topic.
  4. Select the PalmCheck option to adjust the sensitivity of the touchpad to avoid erratic cursor movement caused by accidental touching of the pad during normal typing.
  5. Select the Touch Sensitivity option to adjust how much finger pressure is required to move the mouse on the screen and how responsive the touchpad is to taps.
Jul 12, 2010 | Dell Vostro 1000 Notebook
The curser keeps jumping from the current spot back to somewhere where I've already typed
Are you relatively new to this laptop?
I'm asking, because I suspect that you suffer from the same problem many laptop users have, namely too sensitive touchpad. I myself had this problem with one or two laptops...
When you keep your hands low and parallel to the keyboard, it sometimes happens that when moving the hand slightly to reach keys in the upper keyboard regions, the base of your thumb just barely touches the touchpad, resulting in moving the cursor :) The base of a thumb is protruding lower than the thumb itself, and is not very sensitive to touch, so one does not feel the base barely sliding up the touchpad.
There are two solutions.
First is to go to touchpad settings, and make it less sensitive to light touch. Better yet, some touchpad drivers have a function to prevent from accidental dragging objects by light touch, which needs to be enabled.
If the driver lacks such adjustments, the only remedy is to try and position the hands a bit higher than you currently do. It may be hard at first, but it's relatively easy to form a habit of it :)
Good luck :)
Jul 10, 2010 | Dell Inspiron 9300 PC Notebook
Cursor skipping and jumping back into previously typed text
Have a D600 myself and found anothe post that worked for me!
First, my problem was replying to emails the cursor would jump when typing usually back up into the middle of the text somewhere.
If this is similar, read on.
First, go to Dell's website, downlaod the latest driver for the Alps Touchpad: http://support.dell.com/support/downloads/download.aspx?c=us&l=en&s=gen&releaseid=R113813&SystemID=LAT_PNT_PM_D600&servicetag=&os=WW1&osl=en&deviceid=2514&devlib=0&typecnt=0&vercnt=7&catid=-1&impid=-1&formatcnt=1&libid=17&fileid=149404
Download the driver but do not install yet. Note, this is for a Dell Latitude D600, Windows XP. Vista may have a different driver.
Open Control Panel/Mouse/TouchPad Tab/Touch Sensitivity Button. Open Touch Sensitivity, adjust below the halfway point on the slider. Try different settings, you may also want to check the "Tap off when typing" box.
If you do not show these properties as above, you probably don't have the latest driver installed. In that case, install the driver you downloaded above then come back and refer to the instructions.
I spend 90% of my day on this D600 and really love it, not a speed demon, but light enought to carry with one hand and is a great email/browser machine as you probably already know!
Before installing tis driver
Apr 04, 2009 | Dell Latitude D600 Notebook
Sensitive touch pad
Hi, click on start and control panel. go to mouse properties. Try to look for a tab that says either touch or touchpad. you can change the sensitivity settings there. however if this doesnt work, this could only mean that this is a physical problem with the toucpad. try to apply pressure on the outer side of the touchpad. if it moves, you're gonna need a replacement palmrest.
Oct 02, 2007 | Dell F3534 Touchpad
Dell Vostro 1000 Notebook Logo
546 people viewed this question
Alun Cox
