Question about Lenovo 3000 N200 Intel Pentium Dual Core T2390 1.86GHz Notebook Laptops
I have windows 7 OS which not support any driver Gide me from ware i found my driver
  • Randall  Trahan
    Randall Trahan May 11, 2010
    Windows 7 is beta not released..only drivers are on microsoft website under Windows 7..since its beta yes there are problems and should be reported to Microsoft that's why they release it as beta to fix problems.
  • paul_662 May 11, 2010
    Since Windows 7 is still in beta, you will not find general release
    Have you tried the Vista drivers? I believe the kernel (core) of windows 7 is essentially the same as Vista.
I could not found biostar N68S3B driver for windows 7 ultimate 32-bit os
Hi
I went to the download drivers page of the BioStar website for your mobo here:
N68S3B
and the VGA driver for Vista and Windows 7 is the same one 8.15.11.8634 (the "x86" indicates 32-bit, but the driver looks to be the same for both 32 & 64 bit).
Your question about the AMD Athlon can be answered quite easily. It is a CPU and does not need any specific driver. You should however download and install the chipset drivers for the mobo.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 24, 2014 | Biostar Computers & Internet
Key of fn is not working, combinations of fn key like fn+f1 = sleep it's not working. can you kindly please give me a good solutions?
You may need the Lenovo one key recovery download, the one for windows 7 may work with windows 8 ? There is not a one key downloadable driver for windows 8 on your system the one offered for windows 7 is available in 32 or 64 bit. The power profile for your device sleep wake ect can be adjusted through windows power management it may also need to be adjusted through the nvidia soft ware if it has nvidia graphics. All your troubles would be present if you re installed an OS or upgraded if so there may be several missing drivers ect.
Oct 21, 2013 | Lenovo Ideapad Z370 102578U 13.3-Inch...
Trying to install windows 7 from flashdrive and get as far as "no driver for hard drive" to install OS and one can't be found anywhere on line. All I need is the driver and I'm home free. I
I had a look at the specifications of your computer and it might not meet the requirements to install windows 7
If your computer is 5 yrs or older it might not support windows 7 also you will need a minimum of 1 GB of RAM for 32 bit or 2GB of RAM for 64 bit to install windows 7 http://windows.microsoft.com/en-AU/windows7/products/system-requirements hope this helps
Jan 10, 2013 | ASUS Eee PC 900 Notebook
Can't download and install printer driver HP Deskjet 1220C for window 7
There is no downloadable driver for this printer. You just need to update the Windows 7 list on your computer with the latest update. Here are the instructions from hp:
The drivers for your HP product are already included in the new Windows 7 operating system! You do not need to download drivers to use the product . Simply connect the printer to your computer with a USB cable, and Windows Update automatically installs the driver for your product. With the in-OS The driver located in the Windows 7 operating systemdriver, some of the buttons on the product do not function and some of the advanced product features are not available. For more information about your in-OS driver, and to see workarounds for lost functionality, go to our Frequently Asked Questions below. Install the Windows 7 in-Operating System (in-OS) print driver When you connect your printer to the computer, Windows 7 detects the hardware and automatically installs the correct driver. A notification lets you know when installation begins and when it is complete. You do not have to download any software or insert the product CD. Step one: Install the in-OS driver Follow these steps to install the in-OS driver in Windows 7. NOTE: The computer must be connected to the Internet for Windows Update to detect and install your product.
  1. Turn the product on.
  2. Connect the USB cable to the printer, and then to the computer. Figure 1: USB cablec01704933.gif NOTE: When you connect the USB cable to the printer, and then to the computer, Windows 7 activates Windows Update. Windows Update searches online for the most recent product driver on the Windows Update site. If the online driver is more recent than the driver stored in Windows 7, the computer downloads and installs the updated driver.The Windows Update process takes place automatically. Therefore, you might not notice that the process is in progress.
  3. Windows 7 detects the hardware and automatically installs the correct driver. A notification displays on your computer to let you know when installation is complete.
Your basic Windows 7 driver is now installed. Some functions might not be available, but you can use workaround procedures instead. See our Frequently Asked Questions section below. Step two: Print a document Print from any software program to make sure your printer is working correctly.
  1. Open a document in the software application in which it was created.
  2. Click File , and then click Print .
Jul 26, 2011 | HP DeskJet 1220c InkJet Printer
Wondering what my canon mp450 is compatible with. Need to install it and can't find it on the list
You can get the software/drivers here: http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp450#DriversAndSoftware . Use the drop-down menu to select Mac OS X or Windows 98 through Win7 (32- or 64-bit).
For Windows, any generic driver from the OS will not run the scanner. Uninstall this driver then disconnect the data cable before installing the Lexmark software.
I hope this helps.
Jan 16, 2011 | Canon Pixma MP450 All-In-One InkJet...
I am trying to install the Singer professional Sew-Ware software on my new computer that us running Windows 7, I had to purchase a Serial to USB cord which I attached and installed the cord. When running...
Singer.com's FAQs provide the following:
Q. My computer only has USB ports. Can you recommend a Serial (nine pin) to USB converter cable that will work with the Professional Sew Ware™ 2.00a? A. We have found that the PSW works best on newer computers when the USB serial adapter cable has not only compatible drivers for the Windows operating system but also a FTDI chip. We have found this FTDI chip in the cable which is listed below:
CUSB-232A available from Computerplug.com and Cablesalesusa.com.
Any USB to serial adapter with an FTDI chip will work. These cables will work for Windows XP, VISTA, and 7.
Sep 22, 2010 | Singer Professional Sew Ware Options 2.0...
I had my webcam installed when i had windows 7 now i have installed windows xp my webcam will not show new hard ware found but it dus find it on windows 7
1st You download Webcam Driver.
I had my webcam installed when i had windows 7 now.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
May 20, 2010 | Mri WebCam
Specific Canon LBP2900 driver for Windows 7 RC
Not yet, If neither the Vista driver nor the XP driver do not work, you will have to wait until one is released.
You could try another canon driver, or a driiver for HP laserjet 4, which seems to work with alot of lasers on v7.
Jun 23, 2009 | Canon LASER SHOT LBP-2900 Printer
Lenovo 3000 N200 Intel Pentium Dual Core T2390 1.86GHz Notebook Laptops  Logo
149 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
