Question about HP Photosmart 2710 All-In-One InkJet Printer
Printer keeps saying ''carriage jam error''...
It says,''Carriage Jam. Open Door, Clear carriage jam and then press OK to continue.''
We have done this and nothing seems to be jammed.
  • flcracker Apr 25, 2009
    i have same problem,there is some cotton gauze underneath the cartridge dock(i guess it is there to catch spilled ink)mine was swelled up from ink and tangled in the drive shaft that moves the cartridge dock.I had to cut part of it away with a razor and remove it.works fine now.don't see any easy way to replace it,without consulating a service manual.rreynolds
  • copiersplusw
    copiersplusw May 11, 2010
    I like you to do this , I want you to openter and physically the print cartidge assembly manuelly and see if itmovrs free back and forth, is it does then thiers something worng with the home position sensor and actually may not be worth repairing.
  • 24 Answers
Friends,
The encoder strip may also be dirty, this causes the printer to believe that the carriage moves less than it actually does and tries to compensate by moving the carriage even further - slamming into the left side of the printer as a result.
Carefully leaning the encoder strip with a lint-free cloth wetted with luke warm water (it should not drip!) can fix this problem.
If the carriage stays in the middle of the printer and doesn't move, the carriage drive belt may be broken. Usually this is not replaced so the printer unfortunately has to be scrapped. But contact your local HP support for further advice.
//Al
Posted on Mar 08, 2009
Mine did the same thing and I just cleaned the white strip with a warm cloth and it was fixed!
Try it before you throw your printer out the window! DB
Posted on Apr 11, 2009
How do i clear a carriage jame an ,sg find nothing wrong
Click the link below to go to the hp printer support page for your printer paper jam. Pay special attention to the rear door , as many people miss that detail when clearing paper jams.Also , you can click on the troubleshooting link at the top of that page, followed by "solve a problem " in the drop down box to get answers for other problems,
Clear carriage jam and press OK to continue Error Message Appears for HP...
Feb 14, 2015 | HP OfficeJet 7310 All-In-One InkJet...
My hp photosmart printer is saying Error carriage jam, open dorr clear carriage jam and then press Ok to continue. Which door should I open and how do I clear the carriage jam? Linda
Without any paper in the machine I would try powering off and powering on. Lifting the scanner lid will clear so the carrige goes back to the correct side of the printer. Even rebooting the printer and loading the software will sometimes cause the carriage to go back to where it was supposed to be.
Jan 16, 2010 | HP PhotoSmart C4180 All-in-One Color...
I keep getting an error message on my printer for a CARRIAGE JAM. THe message says to open door, clear carriage jam and press OK to continue. I've followed the HP steps and no luck. Can anyone help?
Hi and welcome to FixYa,
If you have verified that there is no obstruction, nothing preventing the carriage from moving, then most likely fault is dirt, ink smudge or bits of paper on the encoder strip. The encoder strip would be the narrow long plastic strip with barcode like markings. These has to be clear in between markings as they serve as guide for the carriage to tell the printer where the print head is. Cleaning could be done with a soft cotton cloth that leaves no lint.
Good luck and thank you for using FixYa.
Feb 24, 2009 | HP Photosmart C6100 All-In-One Printer
Carriage jam error
The Jam error is most likely cause by one or more of the sensor flags these are the plastic usually black things hanging along the paper path. One of those are either stuck or broken. Check the path and look for those items.
Feb 13, 2009 | HP Photosmart 3210 Printer
Carriage jam on HP Photosmart 3210 Printer
most likely the sensor on the paper path out of position, chech it out and put it back to where it have to be, good luck!
Dec 13, 2008 | HP Photosmart 3210 Printer
How do I get fix a "carriage jam"?
I was able to run run a piece of photo paper through a couple of times and printer now seems to be working again. The theory was that running a heavy piece of paper through might help clear little piece of paper that was not visible. The photo paper is less likely to tear if it gets jammed too.
Apr 18, 2008 | HP Photosmart C7180 All-In-One InkJet...
HP Officejet 5110 - Carriage Jam Message
I have an Hp Officejet 5110. I have an error message saying "Open door,clear carriage jam, then press enter". But where is its door? How can I clear the carriage jam?
I tried pressing the # & 6 at the same time, but the error message still there.
Mar 09, 2008 | HP OfficeJet 5110 All-In-One InkJet...
Carriage Jam error always - how do I fix it?
Try resetting the printer (pressing the cancel button and connecting the power supply, check in the HP website if this is correct for your printer model) , after the reset the printer will clear any errors and will recalibrate the mechanism including the paper feed mechanism and the carriage.
Also check if the carriage is moving freely by disconnecting the power and moving it by hand.
Jan 21, 2008 | HP Photosmart 2710 All-In-One InkJet...
HP Photosmart 2710 All-In-One InkJet Printer Logo
1,045 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
