Question about Nokia N73 Cellular Phone
I cant format my memory card...command shows memory card correpte
How can i solve this problem
    Scholar:
  • 35 Answers
Remove your memory card from phone then format it through windows or dos and again put it in phone & again format it.
if it doesn't work that means your card is really corrupted & you have to change your card.
Posted on Mar 09, 2009
I cant format transcent sd memory card
In that case the memory chip inside it has failed and cannot be repaired. The card is dead, junk it.
May 04, 2011 | PNY 2GB microSD Memory Card
I erased all the files on my memory card and when i put it in my camera it says the card is still full
Solution overview: You need to "clean" the SD card by using the clean command in Diskpart and then format the card in Disk Management. This solution will show you how to accomplish this.
1. Plug the SD Card into the computer.
2. Press Win+R to open the Run command.
3. Type "cmd" into the dialog box and press enter to open a command prompt.
4. Type "Diskpart" into the command line of the command prompt to start Diskpart. Wait for Diskpart to load.
5. Type "List Disk" and press enter.
6. Take note of the number of the disk that's associated with your SD card.
7. Type "Select Disk X" where X = the number of the disk that's associated with your SD card and press enter. Make sure the command prompt reports that Disk X is selected.
8. Type "Clean" or "Clean all" and press enter. Clean will be faster but might not solve your problem. If using the clean command doesn't solve your problem, then repeat steps 1-8 and type "Clean all".
9. Wait for Diskpart to complete the cleaning operation - this may take some time so wait until it's completed!
10. Close command prompt.
11. Press Win+R to open the Run command.
12. Type "DISKMGMT.MSC" into the dialog box and press enter. Wait for Disk Manager to load.
13. In Disk Manager, scroll down and select the SD Card.
14. Right click and select "New Simple Volume".
15. Select Next, Assign Drive Letter, and select "Next" again.
16. Select "FAT32" for File System and "Default" for Allocation Unit Size. Fill in whatever you want for the Volume Label. Make sure "Perform quick format" is checked and click OK.
17. Wait for formatting to complete and remove SD card from computer.
18. Plug SD card into camera to see if the problem is solved.
Good luck and thanks for using FixYa. Post back if you have any questions or problems.
Mar 23, 2011 | PNY 4GB microSD High Capacity Mobile Media...
I have been using my PNY OPTIMA HC 4gb memory card to upload pics for months and all of a sudden it will not read or allow me to upload
Solution overview: You need to "clean" theSD card by using the clean command in Diskpart and then format the card in DiskManagement. This solution will show you how to accomplish this.
3. Type "cmd" into the dialog box and press enter to open acommand prompt.
4. Type "Diskpart" into the command line of the command promptto start Diskpart. Wait for Diskpart to load.
7. Type "Select Disk X" where X = the number of the diskthat's associated with your SD card and press enter. Make sure the commandprompt reports that Disk X is selected.
8. Type "Clean" or "Clean all" and pressenter. Clean will be faster but might not solve your problem. If using theclean command doesn't solve your problem, then repeat steps 1-8 and type "Cleanall".
9. Wait for Diskpart to complete the cleaning operation - this may take sometime so wait until it's completed!
12. Type "DISKMGMT.MSC" into the dialog box and press enter.Wait for Disk Manager to load.
16. Select "FAT32" for File System and "Default"for Allocation Unit Size. Fill in whatever you want for the Volume Label. Makesure "Perform quick format" is checked and click OK.
Good luck and thanks for using FixYa. Post back if you have any questions orproblems.
Mar 15, 2011 | PNY 4GB Secure Digital High Capacity...
I Format My Nokia N72 1GB Memory Card cause of virus then I put it into my mobile it shows memory card correpted what shall i do to clear this problem & how to download the system software for memory...
First: better use kasperaskey anti virus.
If your desktop pc or laptop has antivirus,
have your pc scan your for memory through bluetooth, or usb cable
OR:
If you have Virus On mobile
1 - remove memory card.and format with PC,
2 - dial *#7780# or *#7073*
3 - It format your Phone
4 - Format memory card.
and enjoyyyyyyyyyyyyyyyyyyyyyy
OR
FORMATTING PHONE
Formatting a phone is the same as flashing a phone to remove VIRUS infections on phones.
You can use this link to flash the phone and remove any VIRUS infection on the phone.
Read and learn more about flashing and how to flash a phone on this link.
unlocktotalk.com/UnlockCodeInstructions.htm),
Take care.
Aug 16, 2010 | Nokia N72 Cellular Phone
If hdd is correpted then how to formate a pc... it is showing that check disc; hdd correpted how to get over it
Copy all the files that you can to some other device (external disk-drive, or USB memory-stick), and then "reformat" the disk-drive, and reinstall Windows.
Jun 11, 2010 | Computers & Internet
Nokia 6600 memory card got correpted, but it is working in other device
remove the memory card,hard reset your phone,after that re-enter the memory card,re-format your memory card,,(don't 4get to back up your all data before do this)
Oct 07, 2009 | Nokia 6600
How to unlock a micro sd memory card
memorey card locked . how to unlock my memorey card tell me
Sep 26, 2008 | Cell Phones
Memory card problem
format your memorycard using card reader by FAT16 filesysytem
format your phone also
Jul 17, 2008 | Nokia N73 Cellular Phone
Nokia N73 Cellular Phone Logo
77 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
