Question about Panasonic PT-51G54 51" Rear Projection Television
Convergence circuit Panasonic PT-51G54CA
Where do I purchase convergence circuit for my Panasonic PT 51G65CA and how much will it cost? London, ON and is this a repair I can do myself??
  • 111 Answers
Look for 3 black things about the size of 2 matchbooks on a big heat sink. The part will begin with STK. You can buy at MAT electronics.com for around $12.00 each. Can you do the repair, yes if your skilled and have a steady hand. If you find the STK's then also look for 6 green round fuses or coils that are burned. change them also. Good luck..
Posted on Mar 08, 2009
Picture out of line Problem with the Panasonic PT-53WX42 53 in. Rear projection. Possible convergence circuit? How do i change it
Picture colors lines R,G,B mis alingments,have colors shadows pictures or 3D pictures look alike?Yes.The tv convergence board is dead,the board require changes 2 STK convergence ICS and some or all of it resistors too.To fix the tv convergence board.U must have tools like a soldering iron,a desoldering pump or a roll of desoldering braids and also can do soldering work?Yes,tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a convergence kit belong to ur tv model and make to repair it ur self.Or the shop will cost u like $300-350 for parts and labors.
Mar 23, 2011 | Panasonic PT-53WX42 53" Rear Projection...
I have a Panasonic pt-53x42 projection tv. I believe i have a convergence problem. I have double lines running along bottom of screen..Any help please...
Yes,this problems is 100% convergence problems,it dead.The tv have colors lines R,G,B mis alignments anywhere in the pictures,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to solved the tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 23, 2010 | Panasonic PT-47WX53 47" Rear Projection...
2002 Panasonic PT-47WX52F - Power button now just blinks 3 times
thats the convergence circuits needing repair. You can repair it yourself for around 50.00 with the convergence repair kit for your model from www.tvrepairworld.com the kits contain the parts and the CD with instructions.
Mar 28, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Green color projection is lifting from the bottom left corner of the screen. Convergence adjustment for the green projection is unresponsive
Howdy,
The TV has a convergence problem; the IC’s for that circuit will need to be replaced. The cost for this repair runs around $450.00 or more.
Replace the defective Convergence Output IC Part Number (STK392-110. When Convergence Output failure is
detected, it’s recommended that both IC’s be changed.
Thanks for choosing FixYA, Big Irish.
Dec 22, 2009 | Panasonic PT-51HX41 51" Rear Projection...
Panasonic 51 " projection big screen.[ May 2001]. Convergence chips have gone. Can this be fixed and if so what would it cost for new chips?
A projection Tv convergence amps can be fixed/replaced and a competent tech will also test the yoke return resistors as well as various other components. The amps themselves are about $20.00 a piece (usually two in the circuit) depending on where they're pruchased. I suggest ACME out of Florida - only because it's real easy to buy fakes. Get only Sanyo originals and to do that you need to make sure they're purchased from a reputable supplier.
Good Luck!
William Rayburn, CET
Premium Technologies
Oct 05, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Convergence On Panasonic PT-47WX54j
Did you do a repair on the convergence circuit? If so it would be ok to do an adjustment in the service menue. But if you have a problem in the conergence circuit and you dont repair it first, making adjustments in the service menue can do damage to the DCU and cause you major problem in the future. If you have already repaired the convergence circuit then let me know and i will get you the codes.
Tim nolan
experttv@comcast.net
Sep 24, 2008 | Panasonic PT-47X54 47" Rear Projection...
Convergence problem
replace the stk-392-110 (x2) and any burnt resistors. cost 20$
Nov 19, 2007 | Panasonic PT-47WX42 47" Rear Projection...
Where can I get parts?
STK392-110=CONVERGENCE IC USE TWO FOR REPLACECEMENT PART= WWW.bdent.com Product Details: The STK392-110 is a convergence correction circuit IC for video projectors. It incorporates three output amplifiers in a single package, making possible the construction of CRT horizontal and vertical convergence correction output circuits for each of the RGB colors using ust two hybrid ICs. The output circuit use a class-B configuration, in comparison with the STK392-010, realizing a more compact package and lower cost. www.partstore.com
Apr 12, 2007 | Panasonic PT-56HX41 56" Rear Projection...
Power comes on then goes back off.
More than likely, the two convergence IC's have to be replaced.
Jan 28, 2007 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic PT-47WX49 Convergence IC
usjavelin. I have the pdf files for the tv. I own the same one. I can send them to you if you'd like.
Dec 16, 2006 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-51G54 51" Rear Projection Television Logo
186 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
