No transmitter light on Element EWOS1 Indoor/Outdoor Wireless Spe
Any wirelless transmitter that serve as a substitute for the non working transmitter
  • Anonymous Apr 04, 2009
    TRANSMITTER LIGHT ON ELEMENT EWOS1 DOES NOT LIGHT. SPEAKERS DO NOT WORK
  • Rene Terrazas May 12, 2009
    I bought this new from Circuit City and unfortunately one of the speakers works fine, but the other dosen't work at all ebven when you plug in AC adaptor or insert batteries. the light dosen't go on either. Does anyone think this can be fixed and where?
ginko
  • 19396 Answers
SOURCE: Sharper Image Wireless transmitter deal
Do not restart them with the button, that won't reset settings, unplug everything from power for 5 minutes and plug them back.
Posted on Jul 19, 2008
SOURCE: model 6312026 Nexxtech 433MHz wireless
Hello, you have to push few second the mode button and after date, hour etc it will be possible to change F for Celsius. He will flashing and after push one of the two button up or down.
Bye from Quebec Canada
Posted on Nov 20, 2008
  • 3289 Answers
SOURCE: Connection compatibility
Connect the supplied short RCA "Y" adapter cable to the mini jack of the transmitter base unit. Connect the "Y" adapter plugs to the TAPE 2 "REC" L and R jacks. These jacks will supply "line out" levels of any source selected at the Kenwood to the EWOS1 internal amplifier. The line out levels are "fixed" so changing the volume levels of the Kenwood will NOT change the volume out of the EWOS1 speakers. The EWOS1 volume will be controlled by the volume up / down buttons on the front of each speaker, or by the incuded remote when directed at the speaker(s).
The signals from the TAPE 2 jacks are ALWAYS on regardless of the source selected, so the Kenwood volume can be turned to minium and still provide an unchanged sound level from the EWOS1 speakers. Likewise, if listening to FM, Phono, CD, etc. in the room that the Kenwood's speakers are located, the OWS1 speakers will by playing the same FM, Phono, CD, etc program - unless they have been powered off. The point is, that unlike having to choose FM, CD, etc to listen to those soreces, you should never select TAPE 2 as a source. If TAPE 2 is selected, the KENWOOD would attempt to amplify TAPE 2's "PLAY" jacks, which I assume are not being used.
Posted on Jun 14, 2009
  • 81 Answers
SOURCE: U4 System transmission between indoor and outdoor units Daikin
Sounds like an interconnecting wiring error. Check wiring connection i.e. wires are connected in right order 1 to1 2 to 2 etc. from indoor terminal board to outdoor terminal board. Also check for slack or loose connections.
Hope this helps I take the time to answer your question so please rate me
Posted on Jun 28, 2010
SOURCE: Element Electronics Wireless speakers (model#EWOS1) do not work.
I have the same exact problem!!! HELP!!! If you found out how to fix this, please please please let me know!!
divawoman1@yahoo.com
Posted on Jul 09, 2010
Changed batteries,now weatherstation does not receive outdoor imformation
La Crosse is very specific about what you should do and how you should do it for a battery replacement.
Begin by removing all batteries, both outdoor and indoor. Install new batteries in the outdoor unit. Allow the time it takes to get from the outside to the inside for the outside unit to initialize and begin sending data. Install batteries in the indoor unit and observe outdoor temperature. You should see indoor temperature as well. Finally, set the time. This last can be tricky as it seems difficult to set an exact time. I have two different La Crosse receivers connected to one transmitter and the one in front of me now is indicating 70 deg F indoors and 80 deg F outdoors.
Sep 11, 2016 | La Crosse Technology The Weather Channel...
Modelws 7013u how to replace and reset batteries
In systems with an outdoor transmitter and an indoor receiver, the usual battery replacement procedure is to start with the outdoor transmitter first, allow time for it to start sending data, then install the replacement batteries in the indoor unit. You should see the outdoor temperature being displayed.
Jan 03, 2015 | Measuring Tools & Sensors
Sharper image indoor/outdoor wireless speakers and transmitter has no audio.
First, determine if the TV device is putting out sound by plugging in a headphone into the audio out of the TV. If audio is there then the
transmitter and wireless speakers system may be at fault.
You can also plug in a CD player playing a disc into the transmitter to see if that source then transmits the audio.
Aug 21, 2012 | Audio Players & Recorders
The wireless transmitter doesn't work
Mine quits working when the batteries in the outdoor part need changed .
Dec 15, 2017 | Centrios Audio Players & Recorders
Mar 20, 2009 | Audio Players & Recorders
Feb 23, 2009 | Electronics - Others
Cylinder Like Sharper Image Indoor/Outdoor Wireless Speakers
ask google or you tube or go to car toys they can help. good luck
May 18, 2017 | Sharper Image SR277 Speaker
Jul 19, 2008 | Audio Players & Recorders
247 people viewed this question
 Grubhead
Grubhead
