Question about Toshiba 50HX81 50" Rear Projection Television
REd light blinking on my 50HX81 CRT TV- Toshiba,no
REd light blinking on my 50HX81 CRT TV Toshiba,no picture,no sound
  • rglg Apr 16, 2009
    I have the same problem. Turned the tv off and it wouldn't turn back on- red light flashing.
Toshiba 46h84
Sounds like you have an internal fault (probably on the power supply board) This is the board that generates the various voltages for the various parts of the tv circuitry. The best is to take it to reputable tv repairer(just what you didnt want to hear hey)
May 04, 2013 | Televison & Video
Have an older Toshiba theaterview TV, when turn on, we have no picture, no sound, just black screen and blinking red light that just continuously blinks.
Theaterview suggests a rear projection--in that case it most likely is in the convergence circuit--unsolder chips (convergence) and see if set turns on.
Some of their regular TV sets (picture tube) if the light is just blinking means the same thing=shutdown because of a short/problem but a model number would tell me which you have.
May 23, 2012 | Toshiba Televison & Video
Red blinking light on the toshiba tv and the picture will not come on
i have toshiba dlp and green and red light keeping blinking model 52hm94
Jul 31, 2009 | Toshiba Televison & Video
Toshiba 50hx81 no picture or sound
If you managed to find a manual or have resolved the problem, please post it back here to benefit others. You probably had a partial or complete power supply failure.
Thanks-
Dec 16, 2008 | Toshiba 50HX81 50" Rear Projection...
Toshiba TV 50HX81
Check fuses on Power Supply board (F850, F851, F852) and all other fuses. Replace blown fuses (will need an ohm meter to check fuses). I would also replace the two convergence amps (STK392-110's on the signal board, the big black ICs on the two heat sinks). This worked for me.
Mar 30, 2008 | Toshiba 50HX81 50" Rear Projection...
Toshiba 50hx81 power light just blinks
Go to Powered Products List view all in my profile and read
Toshiba entries........Let me know how it is going.........T.
Mar 15, 2008 | Toshiba 50HX81 50" Rear Projection...
Power light blinks and no picture
No picture - screen is empty. Sound is ok
Check IC101 (BA7630F), if video signal comes to input (pin 1) but not present at output (pin 14) then replace this IC
No picture and sound, only a high pitch sound at switch on
Remove horizontal transistor and measure the resistance across any two pins. This value should be no less than 200ohms
Picture fades away few seconds after start-up till no picture. Sometimes no picture at all. Sometimes picture OK for longer. Sound unaffected.
Faulty joints on CRT pcb. Cracked solder joints at tube socket connections on CRT circuit board. Caused variable supply to CRT heaters. Resolder all socket pins to pcb.
Nov 24, 2007 | Toshiba CZ36V51 36" TV
Toshiba 50
1) Blown fuse ( soldered in) = caused by bad solder connects.
2) For repair = pull chassis, solder connects,replace fuse
3) Replace convergence IC's ( possibly damaged)
4) Re-assemble,test
Oct 22, 2007 | Toshiba 50HX81 50" Rear Projection...
199? toshiba 46" projection tv
we could that problem on timer.most of that problem is cause by defective vertical ic.
Oct 17, 2007 | Toshiba 36A40 36" TV
Toshiba 50HX81 50" Rear Projection Television Logo
513 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
