Question about Bosch Washing Machines
No drum action from my Bosch Maxx for Kids
My Bosch Maxx for Kids will not wash. I can hear clicking noises but not rotation takes place. Water will pump in and out of the drum but no rotation takes place.
  • james56847 Mar 08, 2009
    Hi
    Thanks for getting back to me. The machine is about ten years old and we have never had this problem before.
    I have taken the back off and will try to strip the motor out next. Is it a motor problem then because it sounded as if maybe the control switche
    Hi
    Scholar:
  • 86 Answers
Hi, How old is your maxx? Have you ever experienced this before?
This is quite a common problem and can be sorted quite cheap to. You will need to take the back off depending on which model you have to access the motor! Take the motor off and then we can sort the problem.....
Get back to me....
Posted on Mar 07, 2009
  • Kris Seymour Mar 09, 2009
    Well it is easier to check to motor first then work back! Let me know what syage your at then we can test the motor!
    Thanks
How do I fix my Bosch Maxx 6 washing machine. The drum wont rotate? Can I reset it?
Check the drum motor power supply if its OK then problem can be in the control box try to figure out the trouble. And trouble shoot it
Jul 19, 2016 | Bosch Maxx 6 WAB28260GB White 600 mm...
Bosch Maxx WFL 2260 making intermittent noises. Our machine works well but of late it has taken to making a graunching noise (similar to what you get in a car when you don't use the clutch properly). It...
you have a coin or a hairclim or metal part of a zip that is stuck in the filter where the wings of the water pump rotates against it.
Open the filter and try to remove it. Unplug the power first.
Good luck
Bye
Jan 24, 2015 | Bosch Washing Machines
Bosch maxx drum not turning during any cycle
What is the model number of your unit?
Nov 18, 2012 | Bosch Washing Machines
Bosch Axxis WFL 2060 Front Load Washer - DRUM DOESN'T CYCLE
This seems to be a fault with the program controller unit or the water level sensor. The program does not advance further after the inlet is filled but operates the drain to exit water. Now the water level sensor must be checked as if this is not working in the stipulated time it will drain out. Also unless the water level sensor contacts on reaching of set level the motor must start.http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Mar 14, 2012 | Washing Machines
Hi, my Bosch maxx 900 front loader washer was in the process of doing a load when a really loud bang happened..now it won't spin..makes all the right noises, but barrel won't move. Took off back panel and...
If you rotate the pulley on the back of the drum does it rotate the drum? i have seen these snap the back of the drum off. also they can have issues with the controller board for the motors which would require a technician to determine.
Oct 24, 2010 | Bosch Washing Machines
Bosch maxx
CHECK THE SAFETY SWITCH! YOU WILL SEE IT AT THE BOTTOM PART OF THE COVER !
Mar 29, 2008 | Washing Machines
Front load washing machine would not spin now won't wash either.
Sounds like you have a broken belt or a bad motor. The easiest way to tell if the belt is bad is to reach inside the drum and turn it. If it turns very easily, you probably have a bad belt or something has caused the belt to jump off, such a s a loose pulley or bad bearing. If it feels like there is a good amount of resistance, or a kind of "winding up" noise, then the belt is still on and you likely have a bad motor. Also, you could just scoot the macine out, unplug it, and remove the back cover a look inside to see if the belt is still on the pulleys. Good Luck!
Oct 17, 2006 | Bosch Exxcel WFO 2465 Front Load Washer
Washing Machines Logo
818 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
