Question about Vivitar V3800N 35mm SLR Camera
I cant turn off my light meter om my v3800n 35mm camera without taking the batteries out. Is there a way to turn the meter off? Or do I have to take the batteries out every time?
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 149 Answers
Hello...there is most probably a defective switch on the camera...If you are facing the front of the camera, on the camera body, to the right if the lens is the meter button.(near the flash pc socket) Also, you can check the condition of the batteries by pressing the shutter button half way down. If you see a red or green light, the batteries are good. If not, replace them *both* with silver oxide.
Posted on Sep 17, 2009
  • Richard C Cohen
    Richard C Cohen Sep 17, 2009
    Need to clarify--the shutter button is the metering button--pushing and holding it half way turns on the meter, then you make f-stop or shutter speed adjustments as needed. Check the button for anything spilled in or around it, freedom of travel, etc. If the switch inside *is* damaged, you will have to have the cam repaired by a tech facility.
Vivitar v3800n led light will not come on when shutter released button is pressed half way
Try changing the batteries. That camera is a battery driven model and if the batterie go dead it will not shoot or light uop the led's.
Mar 26, 2010 | Vivitar V3800N 35mm SLR Camera
No light meter on Vivitar V3800N
It may be that the batteries that came with the camera are dead. Double check the way you have them installed, both cells should have the positive side up as they sit in the cap. It is best to handle button cell batteries on the round edges rather than the flat sides. The battery cap for your camera should have open slots on the sides so you can place the batteries in using those openings
Feb 01, 2010 | Vivitar V4000 50MM 35mm SLR Camera
How do I use my light meter on my Vivitar V3800N all I see is a red plus
The red plus means you're overexposed. Increase the shutter speed or close the aperture until the middle light turns on.
Sep 29, 2009 | Vivitar V3800N 35mm SLR Camera
I can't see the meter in the view finder? Is
Yes, the V3800N has an exposure meter.
If the red - lights up, you're underexposed. If the red + lights up, you're overexposed. If the green circle lights up, you're right on. If both the red and green light up, you're within one-third stop of the right exposure.
If you don't see either the green or red lights, then you need batteries. The camera uses two LR44 alkalines or two SR44 silver-oxides. But the only thing that uses the batteries is the exposure meter: everything else on the camera is stil fully functional.
Sep 28, 2009 | Vivitar V3800N 35mm SLR Camera
Vivitar v3800N battery holder missing
rcv7,
this camera has at least two different names that i know of (phoenix, vivitar ) .The battery covers are the same.
most camera repair shops have repair manuals with part numbers from the manufacturer. the only other way is to take a cover to a machine shop and have them make some from aluminum. we had this done for the pentax spotmatic when parts were no longer available.
Jan 14, 2009 | Vivitar V3800N Zoom 35mm SLR Camera
How to turn on the camera
aeloveforev9
all camera's have a switch, button or lever to turn the power on. look through the finder if any light is on or the meter needle is moving then the power is on. some turn on when the shutter button is pushed in slightly. make sure the battery is good and no corrosion is in the battery compartment.
Sep 07, 2008 | Vivitar V3800N 35mm SLR Camera
Taking photos
jeep111
be sure batteries are good. pull up on the rewind knob to open film door. load film ,push down rewind knob. pull enough film to connect to take-up spool. close film door. advance film to counter # 1. look through finder and set meter ( push shutter button to turn on meter ) focus subject and fire shutter repeat to end of film. push rewind button ( bottom of camera ) rewind film.
remove lens by pushing button and turn lens left to remove.
Apr 28, 2008 | Vivitar V3800N 35mm SLR Camera
Turn it on
Actually, you don't have to "turn on" the Vivitar V3800N. Just be sure it has working batteries in it (takes two small alkaline button cells, unscrew the cover on the bottom with a coin--put new cells into the holder with the + side up). If the batteries are working, when you press the shutter button halfway down, you should see an LED light up in the right side of the viewfinder. This is the readout for the exposure meter: a red + indicates overexposure, red - is underexposure, a green dot means you've got the exposure correctly set. You just change the shutter and aperture settings until you get the green light, then shoot. When you load film, you also need to set the ISO film speed setting. Pull up on the outside ring of the shutter speed dial and turn it until the number in the window is the same as the ISO number on the film you are using. The batteries, by the way, only power the exposure meter. The shutter is fully mechanical (just like in the good old days), so you can use the camera without batteries if you have a separate exposure meter, or if you can estimate exposure. Film loading is about like any other 35mm manual camera: pull up on the rewind knob to open the back; insert the new cassette of film on the left and pull the film leader out a couple inches and hook the film to the takeup reel on the right. Move the film advance lever a bit to be sure the film is firmly hooked onto the reel, then close the back. Wind and shoot three shots to get the exposed film leader out of the way, and then start shooting. When the film is finished, press in the rewind button on the bottom of the camera and rewind the film into the cassette before opening the back of the camera. Good luck--these are pretty good little cameras. We buy a lot of them for the photography program where I teach, and I've only ever had one with a problem (meter was bad). The lenses are quite good, and they are "K-mount," which means that any Pentax bayonet lens, and gazillions of others with this mount, will all fit. --Michael R. Sawdey
Sep 03, 2007 | Vivitar V3800N Zoom 35mm SLR Camera
Internal LED inside camera.
Try using an external light meter.
Apr 30, 2007 | Vivitar V3800N 35mm SLR Camera
Vivitar V3800N 35mm SLR Camera Logo
265 people viewed this question
Top Vivitar Photography Experts
JP Services
JP Services
JOHN TOPLISS
Are you a Vivitar Photography Expert? Answer questions, earn points and help others
