Question about General Electric WBB2090G Top Load Washer
GE WBB2090 Not spinning but working otherwise
I thought it was the cycle switch, so I tried to open the switch and the parts fell out. Are there some instructions that show how to reassemble this switch.
Also, thanks for the advice on the pressure switch.
  • 283 Answers
By "cycle switch" I assume you mean the timer. That part is not normally serviced, but replaced as an assembly. See if it spins after you replace it. If not, check the lid switch, motor switch, wiring, connections and start capacitor.
Posted on Mar 07, 2009
Top Loading Hydrowave. Washer fills but won't agitate. After a few minutes water is pumped out and it spins normally.
It almost sounds like the lid switch is working backwards but I have never seen that happen on a GE. The switch either works or goes bad. One other possibility is a defective water level switch. Thats also called a pressure switch sometimes.
Apr 17, 2015 | GE Washing Machines
I have a GE washer which the agitator and tub do not spin. I can turn both freely by hand. The belt is in tact. During the cycle, the motor just osillates a minute amount in both the clock and counter...
it might be the safety switch under the door.
it is a switch that will not allow the spin cycle to spin unless the door is closed - like when you look in your washer while its spinning and as soon as you open the door the spinning stops until you shut the door again.
if its damaged it will not allow the spin cycle to work.
try look under the lid.
costs around $3.00 put in with a screw driver good luck
aloha
Feb 13, 2011 | GE Washing Machines
No spin cycle
check the lid switch,if they go open it will not spin due to safety reasons, you can bypass this switch for testing the spin cycle,then if things work,just replace this switch
Apr 25, 2010 | GE WBSR3140DW Top Load Washer
GE Spacemaker No Spin
Most washers use a lid switch that closes the contacts when the lid is closed, look for a "probe" on the lid that pushes a "pad" that closes the switch, it's possible the switch pad or linkage is bent causing erratic contact closing, any way that is the first place to start. THIS IS A SAFETY DEVICE, DO NOT BI-PASS IT. Good Luck
May 21, 2009 | GE Spacemaker WSLP1100D Top Load Washer
Spinning doesn't take place during spin cycle
One possible problem is the door interlock switch. This switch prevents spinning when the door/lid is open. If the switch is bad (open/off all the time) it sends a false signal that the door is open and washer will not spin.
Does the machine just sit there when it's not spinning or does it sound like it's trying to spin but can't?
Apr 21, 2009 | Washing Machines
GE Profile washer won't spin cloths after wash or rinse cycle
My GE washer model number WLSR2000G3WW washes and pumps water out but will not spin...can someone help me to solve my problem PLEASE?
Jan 23, 2009 | GE WBSR3140DW Top Load Washer
GE Washer top-load WLDSR416FOWC
Actually, I think I do remember having one do this before, and I believe on these GE models the spin cycle goes through the water level switch, so if your water level switch is sticking, then it won't spin, thinking its still full of water.
Here's the water level pressure switch for your model:
Manufacturer part#WH12X10065 is RepairClinic item#2205
don't forget to rate me in main page,it is the only way i get paid for my works..
Jul 23, 2008 | GE WDSR2080D Top Load Washer
GE top load washer will drain but not spin
you both need to have the switch replaced or you can open top of washer and combine the lid switches wires together as a bypass and electrical tape
the lid switches are put in the washers to keep kids from opening the washer machine this is automatic shut down
for xenazoe
you require this part for your washer
Part Number: WH12X10065
SWITCH PRESSURE
Apr 01, 2008 | GE WBB4500EWW Top Load Washer
GE washing machine, wont spin
Same problem (but without any smell). You should try to reset the two computer boards in the washer. You do this by 1) unplugging machine and wait for 30 secs; 2) plug in machine; and 3) open and fully close the lid at least 5 times. This resets computer boards, which can get messed up by power surges, etc.
Mar 24, 2008 | Washing Machines
General Electric WBB2090G Top Load Washer Logo
346 people viewed this question
Top General Electric Washing Machines Experts
Dan Webster
Dan Webster
Are you a General Electric Washing Machine Expert? Answer questions, earn points and help others
